Best Access Point for Ignition Voltage and Instrument Lights - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Best Access Point for Ignition Voltage and Instrument Lights
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNEW JK WRANGLER GRAB BARS NOW at ROCKRIDGE4WDROCKRIDGE4WD Introduces a NEW Jeep Wrangler JK *led* tail
Unread 01-04-2015, 08:07 PM   #1
MikeSD
MikeSD's Avatar
I have a 2008 Jeep Rubicon Unlimited. I'm installing an ARB dual compressor but I'm putting it inside, instead of under the hood. I will be mounting a switch in the post on the left side of the windshield.
I need access to
* ignition voltage
* instrument lights
Where is the best place to access these two, for the easiest connection?
I'm sure I could find a place by just tearing apart the dash but if someone could save me some time, that would be great.
Thanks,
2008 Rubicon 4 dr, Teraflex 4" Elite LCG Long Arm, Teraflex/Fox Shocks, ProComp 37" Xtreme MT2 Tires, 5.13 Gears, Smittybilt XRC M.O.D. bumpers, X20 Winch, Magnaflow exhaust
IRLP Node: 4581 (Jeep)
MikeSD is offline   Reply With Quote Quick reply to this message
Unread 01-04-2015, 08:16 PM   #2
ronjenx
ronjenx's Avatar
Here is a link to a safe way to tap into power for ACC, and RUN/ACC.
I would include a relay, though.
Easy Switched Power Source
2008 JKU Rubicon
42RLE Auto
ronjenx is offline   Reply With Quote Quick reply to this message
Unread 01-05-2015, 06:01 AM   #3
14Sport
2014 JK Wrangler
For the instrument lights (assuming you mean the dimmable ones):
If you have power windows, then the orange/gray wire at the switches
or if no power windows, the orange/gray wire at the HVAC controls.
2014 JK Sport, auto, 35x12.5x17, 3.73s, BR6 BBK.
I jeep therefore I am.
14Sport is offline   Reply With Quote Quick reply to this message
