been gone for 10 days (jk mods) - Page 13 - JeepForum.com
post #181 of 577 Old 04-28-2009, 10:32 PM Thread Starter
b_c
found another good view of that rancho for ya'll
...i need some d-rings.
b_c
greater love hath no man than this, that a man lay down his life for his friends -john 15:13
b_c is offline
post #182 of 577 Old 04-29-2009, 06:20 AM
Niceface
Originally Posted by b_c View Post
thanks
i'm also looking into a 1" body and 2" suspension lift combo. i think i've got the one's i want lined up. what do ya'll think about poly performance suspensions?
b_c
With the money train still flowing into this rig, why not just go for the glory. 6" long arm on 35"'s, belly up kit, redo gears. Play with the big boys.
Niceface is offline
post #183 of 577 Old 04-29-2009, 06:55 AM Thread Starter
b_c
maybe once the jk's paid off...and i've got another one in the drive.
...you should've seen this rig at 4x4 nut's buddy's place. the bottom of the truck door was at like 6' (yes, feet). un-freakin-believable
b_c
b_c is offline
post #184 of 577 Old 04-29-2009, 07:07 AM
Niceface
b_c
Those are fun to look at, or when I was single, pick up women with, but their so worthless off the concrete. I use to drive a huge *** chevy. Only thing it was good for was turning heads.
Niceface is offline
post #185 of 577 Old 04-29-2009, 10:25 AM Thread Starter
b_c
which should i get for the body lift...daystar or performance accessories?
...supposedly both work w/ manual transmissions w/o having to cut anything (read: shifter boot)???
b_c
b_c is offline
post #186 of 577 Old 04-29-2009, 03:35 PM Thread Starter
b_c
b_c
red or black d-rings?
...i have a preference for red...but black would look stealthy. whatcha think?
b_c
b_c is offline
post #187 of 577 Old 04-29-2009, 06:47 PM
Niceface
b_c
What about just hot dipped galvinized?
If you paint them, you'll have to "touch" them up everytime you use them. if that's not a problem, I'd do red.
Get a steering box skid plate (red) and do your draglink/track bar red too!
Niceface is offline
post #188 of 577 Old 04-29-2009, 06:48 PM
Niceface
b_c
Mine is daystar I believe. Both have the same hardware. You can do it yourself in a garage with a floor jack and a couple hours. I did it the dumb way and paid my buddies $400 bones to do it. After that I learned....i can do it on my own.
Niceface is offline
post #189 of 577 Old 04-29-2009, 09:38 PM Thread Starter
b_c
pack rat
i like these...
crosby's 5/8" shackle w/ 3/4" pin
ups-claus dropped off a little something something today...
mod 26 - M-PAC SPRINGTAIL JK RACK AND POUCH COMBO -
i liked the way that it looked online, so i ordered it. installed it tonight.
springtailsolutions.com ($191-ish)
before
during...not too happy about drilling and screwing into the tailgate, but ???
after
...i'm gonna put the quickfists in tomorrow.
b_c
b_c is offline
post #190 of 577 Old 04-30-2009, 01:13 PM Thread Starter
b_c
...yeah, sold my hardtop yesterday for $1200. $200 to the wife and $1000 to the jeep.
just trying to decide where i want to drop it. liner or lift?
...i need some info on which lift to get. i'm looking at the poly performance synergy stage 1. it comes w/ all sorts of shiz that the other ones don't; for instance, rough country spring suspension lift (poly is $1400 vs rough country ~$400)
do i need all the extra shiz that the poly performance includes?
this is what's in the poly kit:
PPM-8004 - JK 9/16" Control Arm Cam Bolt Kit
PPM-8063-XX - JK Front Lift Springs
PPM-8064-XX - JK Rear Lift Springs
PPM-80XX - JK Front Bump Stop Spacer Kit
PPM-80XX - JK Rear Bump Stop Spacer Kit
PPM-8061 - JK Front Track Bar
PPM-8056 - JK Rear Track Bar Bracket
PPM-8083 - JK Front Brake Line Relocation Kit
PPM-8084 - JK Rear Brake Line Relocation Kit
PPM-8085 - JK Rear Sway Bar Drop Bracket Kit
PPM-8059 - JK Front Sway Bar Links
PPM-8081 - JK Front Sway Bar Relocation Kit
it seems like i could piece together this kit for far less. if you agree, help me figure out who i need to go to for this stuff...IF THIS STUFF IS REALLY NEEDED.
b_c
i posted the above quote in the "houston get together" thread, but i think this topic should be in here too...(just in case)
...so can anyone help me out?
b_c
b_c is offline
post #191 of 577 Old 04-30-2009, 04:27 PM
Rescue1
2009 JK Wrangler
I'm not stalking you but... get the rough country. ask N2Rock, that's what he's running. he can give you a real world take on it. plus he has a 2" BL.
chris
Rescue1 is offline
post #192 of 577 Old 04-30-2009, 05:16 PM Thread Starter
b_c
chris
stalker!
but what's the deal w/ all the extra stuff in poly's kit???
...do i need those components or not?
i need more input
i'm not trying to cut-corners or save money. i want to do this right and understand why i'm doing it (i.e. what are the advantages/disadvantages of getting them vs not?).
then there's this "optional" list, too:
Optional Components:
PPM-8062 - JK Rear Adjustable Track Bar
PPM-8006 - JK Steering Stabilizer Relocation Kit
PPM-8051 - JK Front Lower Control Arms
PPM-8052 - JK Rear Lower Control Arms
PPM-8090 - JK Rear Track Bar Bracket w/ Cam Bolt
b_c
b_c is offline
post #193 of 577 Old 04-30-2009, 06:04 PM
Rescue1
2009 JK Wrangler
paging N2Rock... you are needed in the checkout lane. N2 to the checkout lane please.
quick breakdown...
bumpstops are not needed as the 2.2 shocks have internal stops (i read it on the internet so it must be true)
breakline brackets, i believe, come with the kit as does the new rear sway bar links.
if you don't use the the trackbar relocation brackets or the adjustable trac bars then your axels will be shifted (front to one side, rear to the other) by about 1/8". welcome to the club, as most lifted guys run like this.
don't need the control arms until you go up higher, but you'll also need a new drive shaft too.
haveing not bought this kit myself...yet i can' only speak (or type)from what i've read from others. so i could be completely wrong.
Rescue1 is offline
post #194 of 577 Old 04-30-2009, 11:32 PM Thread Starter
b_c
lift is on hold for 9 days...
...i don't want to jinx myself so i'm not going to say what i've got going on, but if it happens you all are going to poop your pants. stay tuned!
as for the lift, i'd still like to hear a tech/mech savvy person has to say about the lift and how all the components listed above make (or don't make) a difference.
b_c
b_c is offline
post #195 of 577 Old 05-01-2009, 07:55 AM
N2rock
N2rock's Avatar
Not knowing what size lift you're going with, some of these things may or may not need.
- Judging by this, I'm assuming you're going with a 3.5" or higher kit. If so, I would skip the cam bolts and go with adjustable control arms. More expensive yes, but will serve you better in the long run
doesn't indicate that it is adjustable. If not, I would skip this and get an adjustable one. Again- it will serve you better in the long run
- forget the bracket and get an adjustable trackbar
Basically I'm telling you to go ahead and get all the optional components
If you're got the money to do it right the first time, do it. If you don't have the money, get what you can afford and then upgrade components over time (that is what I've been doing)
for details and info on our JK's, check out
His: '07 Unlimited X, Jeep Green, Hardtop, auto, 5.13, 2.5" RC lift and too many mods to list
Hers: '08 X Red Rock, soft top, auto. Bunch of mods
Originally Posted by tlgraham View Post
If you made a snuggy out of a Shamwow, ....would you have to get up off the couch to pee?
Originally Posted by Deepskyy View Post
At this point if Obama tried to move a little to the right, he would trip over Stalin's corpse.
N2rock is offline
JK Wrangler , lift , lift kit , poison spider customs , rancho , teraflex , unlimited , wrangler
Name that rim. I got 3 others but this one has seen its last days Jeepsr4me19 YJ Wrangler Technical Forum 10 04-21-2009 01:46 PM
Since we have a worst mods, how about absolute best mods ever put on!! christrx450 TJ Wrangler Technical Forum 105 05-23-2008 12:37 AM
3 mods in 3 days (Rockhard/AEV for JK) ge2 JK Wrangler Technical Forum 44 05-22-2008 04:18 PM
2 more days!! NaeKid JK Wrangler Technical Forum 2 03-12-2007 04:18 PM
Wet days FastForward108 TJ Wrangler Technical Forum 2 06-06-2005 12:50 PM
