-   JK Wrangler Technical Forum (http://www.jeepforum.com/forum/f96/)
-   -   Bedlining on a Budget (http://www.jeepforum.com/forum/f96/bedlining-budget-1071724/)
DeepSky 07-18-2010 03:17 PM
I got tired of constantly worrying if it was going to rain while I had the top down, doors off, just the safari top on, or any combination of those three so I decided to take my carpet out and bedline the tub.
I was aware of all the bedlining kits available for this project but I wasn't sure if I was going to have the patience to use one considering the heat we've been having so I decided to use the Rustoleum brand spray on truck bed coating. This is the same stuff that I used to do my door hinges and not only has it held up great, but its also really great if you need to do any touchups.
Anyway I completed the entire project between Monday and Friday last week spending about 2 1/2 hours every evening that week after work.
Some pics:
I discovered a couple pounds of sand under the carpet after it was removed so for the first time I had the pleasure of cleaning the interior with a garden hose:
http://www.deepskye.com/images/Jeep/...linedTub02.JPG
The same night I removed the carpet I also took out the back seat. The following night I completed the passenger's section:
http://www.deepskye.com/images/Jeep/...linedTub04.JPG
The next night I did half the back behind the passenger seat; then on Thursday the other side:
http://www.deepskye.com/images/Jeep/...linedTub05.JPG
Friday night I finished up with the driver's side and put everything back together:
http://www.deepskye.com/images/Jeep/...linedTub07.JPG
And here is how it looks finished:
http://www.deepskye.com/images/Jeep/...linedTub09.JPG
http://www.deepskye.com/images/Jeep/...linedTub10.JPG
http://www.deepskye.com/images/Jeep/...linedTub12.JPG
http://www.deepskye.com/images/Jeep/...linedTub13.JPG
http://www.deepskye.com/images/Jeep/...linedTub14.JPG
http://www.deepskye.com/images/Jeep/...linedTub15.JPG
http://www.deepskye.com/images/Jeep/...linedTub16.JPG
Vin 07-18-2010 04:58 PM
Do the tailgate! Do the tailgate!
It looks sweet!
Scooter_Trash 07-18-2010 05:00 PM
Looks great. I was planning on pulling all the roll bar padding off and doing those when I do my tub. I was also thinking of taping off along the rails where the hardtop hardware goes and and doing the top part. I've got a ton off scratches along that section.
Why do you have a c-clamp on your door frame?
DeepSky 07-18-2010 06:55 PM
Funny you mention; after I was finished I immediately thought 'man, the tailgate just looks out of place now'; which doesn't make a whole lot of sense considering the carpet was black as well.
The roll bar isn't a bad idea; I only went up to where the padding comes down on the roll bar. I do plan on doing the top part of the tub too; I have a crapload of scratches there as well.
The c-clamps on the rear door surrounds are to keep the door surrounds flush against the tub rail. Without them the safari top pull them up about 1/2" while driving. Just a little pet peve of mine lol.
Rescue13 07-18-2010 07:48 PM
Was it hard to get the front seats out, what tools did you have to use? Im doing this tommorow. How much was the spray? How many cans did you use?
DeepSky 07-18-2010 07:54 PM
Wasn't too bad to remove all the seats; 4 bolts per front seat (plus a torx head for the seatbelts), 7 total for back seats. Breaker bar was a necessity followed by a normal ratchet.
The rattle cans were about $9 a piece from Autozone (cheaper @ WalMart) and I used about 6 cans. If you have any other Q's lemme know and I'd be happy to give you any advice I might have. Good luck, it's totally worth it!
Farmdiesel 07-18-2010 07:54 PM
How many cans did you go through for the job? one coat or two? I really want to do this on my 2dr for the same reason, I like the idea of spraying vs the kits. Looks great man!
DeepSky 07-18-2010 07:57 PM
Rustoleum recommends two coats, but I'm anal and did three.
Rescue13 07-18-2010 08:03 PM
Thanks alot. I love the interior colors too. Looks sharp.
Whats a breaker bar? And did you have to use and sort of Wd-40 to make the bolts come off better? I have an 07 so it might be harder. (I didnt notice what year you have)
DeepSky 07-18-2010 08:21 PM
NP a breaker bar is basically just a long ratchet wrench that gives you a lot of leverage to "break" really tightened hardware loose. I didn't need any WD 40 or liquid wrench; the breaker bar was enough. You may want a 3-4" extension though; it came in handy.
Vin 07-18-2010 08:43 PM
you can also use a pipe around your socket wrench for a Ghetto breaker bar.;)
Rescue13 07-18-2010 08:53 PM
Odds of me using that is quite large haha. Im too cheap to buy anything like that. :cheers: :highfive:
Mark4883 07-18-2010 08:56 PM
Looks good, I used the same stuff on mine.
fernjack 07-18-2010 09:49 PM
Very professional looking job ....... Well done dude . How long did you let it sit between coats ? Again awesome job . :cheers::wave:
stanware 07-18-2010 09:57 PM
Looks good, I'm thinking of doing my jeep like this too.
The time now is 08:34 PM.
