Bed Lining This Weekend - JeepForum.com
post #1 of 5 Old 08-05-2013, 10:27 PM Thread Starter
Fluevog
Hey guys I got myself a gallon kit of the monstaliner diy bed liner. I am planning on doing the project this weekend. However, every time I go out to my 2012 2 door I see a new bolt that I don't know what size it is and where the others are located. I also cannot find any clear instructions on how to remove a 2012, or jk in general, middle console or fronts seats. If someone could give a detailed description of what i need to do in terms of removing seats and consoles and what tools I will need it would be awesome! Thanks
/l , [____],
l------L--[]lllllll[]-_ ɹǝʌo ǝɯ dıןɟ 'sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
()_) ()_)==♠=)_)
Fluevog is offline
post #2 of 5 Old 08-05-2013, 11:02 PM
ancientspear
You will need a set of metric sockets and torx bits. Apart from that the centre console has two torx bolts in the rear. Move the front seats forward to access them. Once that is removed, you start by pulling up on the cup holders and when they are unseated you pull firmly up on the whole centre console. They have a number of clips holding them in. Be carefule though, the lights in the front/back cup holders are connected, you don't want to tear them out! Apart from that, I believe the shifter nob heads remove by pulling up on them as we'll, they will need to be removed before doing the console completely. Sorry, I haven't done the shifter part before so get info from another who has just in case there are set screws or something. Usually those guys need a BIG pull. Good luck!
ancientspear is offline
post #3 of 5 Old 08-06-2013, 12:16 AM Thread Starter
Fluevog
Does anyone know the exact torx sizes that I will need?
/l , [____],
()_) ()_)==♠=)_)
Fluevog is offline
post #4 of 5 Old 08-06-2013, 01:12 AM
ancientspear
Just buy a set, there's a ton of torx fasteners in Jeeps, or cars in general, and usually a set costs the same as buying 2-3 individual bits.
post #5 of 5 Old 08-06-2013, 05:40 AM
bogleparsons
Don't get a cheaply made set.
You can thank me later.
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
