Batty says...i need lift! - JeepForum.com
post #1 of 8 Old 09-10-2013, 09:43 AM Thread Starter
neumsky
Alright ya'll...I want to lift my front end to match the the height of my rear end on my 2013 2 door sport. I'm guessing 2 inches...not sure? Is it as simple as putting spacers on top of the coils without any issues of alignment and or shocks? Thanx in advance....Jeff
neumsky is offline
post #2 of 8 Old 09-10-2013, 10:21 AM
JoonHoss
2011 JK Wrangler
Yes, though it's likely less than two inches. It can be as simple as a coil spring spacer, or as involved as a full budget boost/leveling lift kit with shocks, trackbars and a few other parts.
I'd try the coil spacers first. Measure your jeep at the bottom of the body, behind the front fender flare, and in front of the rear flare, at the pinch seam.
What is your current set up, and what do you plan to change and or add, if anything?
Hoss
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is online now
post #3 of 8 Old 09-12-2013, 07:43 PM
wilgeno
wilgeno's Avatar
You have options. This leveling kit is one.
http://www.quadratec.com/products/16190_1100_07.htm
I think this is about as low $$ as you're going to get unless you went with just spacers.
TeraFlexed '13 Commando Green JKU Black Hardtop roll'n on 35's!
Bug-Out!
I don't always go topless, but when I do I go Commando!
wilgeno is offline
post #4 of 8 Old 09-13-2013, 10:17 AM
Lenny7
2006 WK
I put the front of the teraflex leveing kit on last night. 2" in the front. I haven't put the 1" on the rear yet. With just the front spacers in it still has a slight rake to it. Not sure I'm gonna do the rear.
Lenny7 is offline
post #5 of 8 Old 09-15-2013, 07:48 PM Thread Starter
neumsky
Hoss
Right now...I have plans to probably get some nice wheels albeit...probably stay at the 16 inchers. Otherwise...not much of anything...thanx for your reply.
neumsky is offline
post #6 of 8 Old 09-15-2013, 07:54 PM Thread Starter
neumsky
I'll consider it...thankyou
neumsky is offline
post #7 of 8 Old 09-15-2013, 07:56 PM Thread Starter
neumsky
Ok...very good...I think that's what I'll do...thank you
neumsky is offline
post #8 of 8 Old 09-16-2013, 12:52 PM
roadrat
I'd highly recommend coils for better ride quality
roadrat is offline
