battery light came on this morning? - JeepForum.com
post #1 of 2 Old 02-22-2013, 06:51 AM Thread Starter
xraypat23
So my battery light came on this morning. Truck started without hesitation, and drives and runs fine. Any clue what I need to do? Drop in a new battery? is it covered under my extended warranty?
xraypat23 is offline
post #2 of 2 Old 02-22-2013, 06:59 AM
ronjenx
ronjenx's Avatar
The light indicates a charging system problem, or a low battery.
Is your battery the original one? If so, you are lucky to have had it this long.
Put a volt meter on the battery with the ignition off. It should be around 12.6 volts if it's been off for a while.
Put a volt meter on the battery with the engine running. It should be around 14 volts.
Then, have a load test done on the battery.
ronjenx is offline
battery issue , charging system , indicator light
