Ball Joints and Tie Rod Ends - gone at 25K?? - Page 2 - JeepForum.com
post #16 of 18 Old 11-05-2012, 10:04 AM
SoK66
2009 JK Wrangler
If you have the bucks, Dynatrac Pro Steers for the win. Bombproof.
SoK66 is offline
post #17 of 18 Old 11-05-2012, 10:27 AM
spedly
2011 JK Wrangler
I'd get a second opinion to be sure, but it is not unheard of. My stock balljoints lasted 8k miles.
Poser Jeep.
spedly is offline
post #18 of 18 Old 11-05-2012, 11:20 AM
ronjenx
ronjenx's Avatar
Since this thread is back from a couple months ago, I'll add the following.
The tie rod and drag link ends may seem loose if you can easily twist them.
However, if you grab the rod and get no up and down movement in the joints, they are perfectly fine.
Here's how to test the ball joints:
Radial (side-to-side) movement in the upper ball joint should not exceed 0.060" (1.5mm).
Axial (up and down) movement in the lower ball joint should not exceed 0.050" (1.25mm).
A dial indicator is the best instrument to measure ball joint play.
Jack the front tire off the ground.
Place a jack stand under the axle next to the jack.
Lower to put some weight on the jack stand.
Place a long pry bar under the tire, from the side.
Have someone pry the tire up and down while you watch the lower ball joint for up and down play.
Have someone grab the tire at top and bottom to wiggle the top in and out while you watch the upper joint for side play.
Even if the upper joint checks good, change both if the lower checks bad.
ronjenx is offline
ball joints , replacement
Ball joints and tie rod ends BigRodney TJ Wrangler Technical Forum 27 03-29-2012 09:45 AM
Tie rod ends & ball joint replacement-WHEN? wallwm TJ Wrangler Technical Forum 5 03-25-2012 09:12 AM
Axle u-joints & maybe ball joints. CityJeep90 YJ Wrangler Technical Forum 2 06-04-2006 05:23 PM
Help with front end work... ball joints, u-joints kaffeene YJ Wrangler Technical Forum 5 04-27-2005 08:45 PM
