Ball Joint Warning!!! - Page 4 - JeepForum.com
post #46 of 54 Old 06-29-2014, 05:05 PM
ronjenx
ronjenx's Avatar
Originally Posted by 222Doc View Post
mine was so bad there was need for technical measurement. i mean it was like 3/16 of an inch. made popping sound that was distinctive. i would bet they would have been out of spec at 15k. BUT the jeep see's a a lot of trail time, long distance trails and local DD.
once the lowers were removed they rattled like skeleton in a trash can. they were toast and it is product of more back space 3.75 wide tires and a lot of rocks. I did not go to the dealer and plead my case for a warranty fix. I replaced them. Bought the right tool that cost more than the synergy joints.
I kept an eye on mine, measuring them every couple of oil changes. Watched them approach the wear limit, and finally had to change them at 76,000 miles. Installed Synergy...love 'em!!
ronjenx is offline
post #47 of 54 Old 06-30-2014, 01:35 AM
73azbronco
Anyone had success bringing the mentioned good ball joints like Dynatrac or Synergy to the dealer and have them installed under warranty for the bad OEM ones?
73azbronco is offline
post #48 of 54 Old 06-30-2014, 09:12 AM
HOKIES2010
2011 JK Wrangler
Check with your dealer . I know mine will not install a part that wasn't bought through them.
My Build
Couldn't have done it without
HOKIES2010 is offline
post #49 of 54 Old 07-04-2014, 12:19 AM
73azbronco
That's easy, have the dealer parts guy call 4x4 supply and order it? I mean, the dealer puts on Terraflex lift and suspension components, why not something that will help safety and longevity as in they will never have to see you again.
I would be worried that if you are replacing ball joints every 6000 miles you are also wearing out the holes the BJ's press into.
post #50 of 54 Old 07-04-2014, 09:53 PM
Harriedtwo
2011 JK Wrangler
The JK isn't the only Chrysler product with defective ball joints. I own a 2008 Dodge Ram 2500 Quadcab; at 60,000 miles the right and left tie rods were worn out. Since it was no longer under Chrysler warranty I paid to have new Moog ball joints and link installed. This week I received a notice from Dodge my truck was being recalled to replace the ball joints and link. This is an expanded recall from earlier this year. Like many new vehicles these TREs did not have grease zerks. The new ones do.
Harried Harry
2011 Jeep Wrangler Unlimited Rubicon.
Wife: 2014 Grand Cherokee Limited
Harriedtwo is offline
post #51 of 54 Old 07-05-2014, 12:35 AM
73azbronco
So they key here is: Wait for a recall.
post #52 of 54 Old 07-06-2014, 08:29 PM
Harriedtwo
2011 JK Wrangler
Back in January I received notice of a recall. I took the truck so they could inspect it; they took one minute and decided it was not the one being recalled. Then last week I received an updated recall which includes my truck. I tried to get it taken care of in January but the dealership said only certain models had the defective part. Oh well, at least now I have Moog which should last as long as I do or the truck, whichever goes first.
Harried Harry
post #53 of 54 Old 07-06-2014, 11:18 PM
lumpster
lumpster's Avatar
Looks like I should start shopping for aftermarket ball joints, any of the big names better than the others?
lumpster is offline
post #54 of 54 Old 07-07-2014, 12:40 AM
Rmiller31
Synergy here too. No probs so far.
Rmiller31 is offline
Ball, joint, U-joint, control arms? Clunking noise. FritzTJ TJ Wrangler Technical Forum 11 09-18-2009 11:59 AM
U-Joint and Ball-Joint question gcally TJ Wrangler Technical Forum 5 02-18-2009 11:28 AM
Lift Control Arms: Ball joint vs Heim Joint types? CB3 TJ Wrangler Technical Forum 5 04-21-2007 01:27 AM
new ball joint jeep lif TJ Wrangler Technical Forum 5 03-05-2007 05:20 PM
front wheel problems (u joint, ball joint etc) ohhpe YJ Wrangler Technical Forum 0 06-05-2005 04:40 PM
