Ball Joint Warning!!! - Page 3 - JeepForum.com
post #31 of 54 Old 08-05-2010, 12:48 PM
Hellbound13
Originally Posted by PIG View Post
PIG,
How do these stack up to the Prosteers? What are the differences?
Hellbound13 is offline
post #32 of 54 Old 08-05-2010, 01:21 PM
DeepSky
Originally Posted by Hellbound13 View Post
But the pages upon pages on the other forum of multiple ball joints failing and even AEV engineers and my local dealer saying these are a very weak point on the JK...
When the dude at 4Wheel Parts asked me why I thought I needed to replace my ball joints he thought I was crazy and said "We've done/seen tons of JK's and none of them had any problems with the ball joints". Sigh....
Problem solved...
Badass...I had no idea PP was making ball joints. I'm still a huge fan of them just from the HD tie rod I got from them.
2003 Patriot Blue Wrangler SE - RCX 2.5" Kit on 31x10.5 Firestone M/Ts and stock the rest of the way.
2007 Flame Red Wrangler Unlimited X - Skyjacker 4" Kit on 35x12.5 Cooper Discovery STT(
DeepSky is offline
post #33 of 54 Old 08-05-2010, 01:42 PM
Poor Boy
All Around Nice Guy
Poor Boy's Avatar
I love you guys, and love your stuff, but I'd be careful of hawking without a vendor account.
Originally Posted by Hank Venture
It's like someone with a fever is yelling at my pants!
USN Hull number 54
Poor Boy is offline
post #34 of 54 Old 08-05-2010, 02:06 PM
PIG
Sorry man... I thought we had a vendor account here. I am not the regular guy from our company who posts here. I'll look into it.
www.SynergyMfg.com
PIG is offline
post #35 of 54 Old 08-05-2010, 02:08 PM
PIG
PIG,
Not exactly sure but the Prosteers go for $600 plus $125 every time you need to rebuild them. I think these will offer similar performance @ a fraction of the price.
www.SynergyMfg.com
PIG is offline
post #36 of 54 Old 08-05-2010, 02:11 PM
PIG
Cool man... Glad the TR worked out for you.
www.SynergyMfg.com
PIG is offline
post #37 of 54 Old 08-05-2010, 03:39 PM
Poor Boy
All Around Nice Guy
Poor Boy's Avatar
yep, i follow your updates pretty regularly over on jkowners, and those on this forum that aren't over there wouldn't suffer for your passion and expertise, so i'd hate to see PP disappear from here over something little overlooked
USN Hull number 54
Poor Boy is offline
post #38 of 54 Old 08-03-2011, 08:03 AM
rhacal60
Ball Joint
Hi I have a 2008 wrangler with 23,000 miles. Have had to replace tires last week(they were worn bad). went for inspection sticker and now told my ball joints need replacing. Dealer says 3 year warranty up two months ago. Have had all maint done at dealer. Has anyone else had premature failure of their ball joints?:
rhacal60 is offline
post #39 of 54 Old 08-03-2011, 10:07 AM
JIMBOX
There are several new "Ball Joint" mfgs--I have SYNERGY (Zirk) ball joints--
So far so good !!
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #40 of 54 Old 06-29-2014, 07:11 AM
JeepNOwave
2009 JK Wrangler
my 2009 Jeep Wrangler at 48K miles now needs ball joints, and recommendations on improved replacements
JeepNOwave is offline
post #41 of 54 Old 06-29-2014, 07:20 AM
ncb
Synergy.
ncb is offline
post #42 of 54 Old 06-29-2014, 07:28 AM
1222
RIP John
1222's Avatar
Synergy (reasonable) and Dynatrac (very expensive but for good reason) are the considered the best although there are a couple of other players to throw into the mix.
(2011-2016)
1222 is offline
post #43 of 54 Old 06-29-2014, 10:53 AM
222Doc
222Doc's Avatar
Originally Posted by ncb View Post
Synergy.
stock lowers were toast at 20k.
Reading back on this thread i see some clarification; checking ball joints, lift the tire up a few inches, place a pry bar under it. Pop it up and let it down, is should hardly move UP at all at the lower ball joint. If it makes a popping sound it is far gone.
You do not just grab the tire and shake it. That is for a Unite bearing.
222Doc is offline
post #44 of 54 Old 06-29-2014, 03:26 PM
ronjenx
ronjenx's Avatar
Here's the full story:
Radial (side-to-side) movement in the upper ball joint should not exceed 0.060" (1.5mm).
Axial (up and down) movement in the lower ball joint should not exceed 0.050" (1.25mm).
A dial indicator is the best instrument to measure ball joint play.
Jack the front tire off the ground.
Place a jack stand under the axle next to the jack.
Lower to put some weight on the jack stand.
Place a long pry bar under the tire, from the side.
Have someone pry the tire up and down while you watch the lower ball joint for up and down play.
Have someone grab the tire at top and bottom to wiggle the top in and out while you watch the upper joint for side play.
Even if the upper joint checks good, change both if the lower checks bad.
ronjenx is offline
post #45 of 54 Old 06-29-2014, 04:01 PM
222Doc
222Doc's Avatar
mine was so bad there was need for technical measurement. i mean it was like 3/16 of an inch. made popping sound that was distinctive. i would bet they would have been out of spec at 15k. BUT the jeep see's a a lot of trail time, long distance trails and local DD.
once the lowers were removed they rattled like skeleton in a trash can. they were toast and it is product of more back space 3.75 wide tires and a lot of rocks. I did not go to the dealer and plead my case for a warranty fix. I replaced them. Bought the right tool that cost more than the synergy joints.
222Doc is offline
Ball, joint, U-joint, control arms? Clunking noise. FritzTJ TJ Wrangler Technical Forum 11 09-18-2009 10:59 AM
U-Joint and Ball-Joint question gcally TJ Wrangler Technical Forum 5 02-18-2009 10:28 AM
Lift Control Arms: Ball joint vs Heim Joint types? CB3 TJ Wrangler Technical Forum 5 04-21-2007 12:27 AM
new ball joint jeep lif TJ Wrangler Technical Forum 5 03-05-2007 04:20 PM
front wheel problems (u joint, ball joint etc) ohhpe YJ Wrangler Technical Forum 0 06-05-2005 03:40 PM
