Ball Joint Warning!!! - Page 2 - JeepForum.com
post #16 of 54 Old 12-08-2009, 11:59 AM
MattJK09
2009 JK Wrangler
Does this occur more with lifted than stock JK' or is the ball joint monster indifferent?
09 X 23S Flame Red 2door, tinted, Black Rock 997's, BFG 32" MT's, grab handles, RR XHD front bumper,BW trail armor,4door springs up front, KC's
MattJK09 is offline
post #17 of 54 Old 12-08-2009, 12:53 PM
DeepSky
From what I've seen and heard its indifferent, although the larger the tire/lift the quicker they seem to go.
2003 Patriot Blue Wrangler SE - RCX 2.5" Kit on 31x10.5 Firestone M/Ts and stock the rest of the way.
2007 Flame Red Wrangler Unlimited X - Skyjacker 4" Kit on 35x12.5 Cooper Discovery STT(
DeepSky is offline
post #18 of 54 Old 12-08-2009, 06:44 PM
dsy
39,000 miles and mine are in great shape. But I have been greasing them regularly with one of those needle adapters on the grease gun.
Flame red unlimited Rubicon 5 speed 5-45RFE Auto , 35" KM2's, RCV front axles, 3 1/2" AEV premium lift, AEV snorkel, LoD front bumper with Warn powerplant,Full River Raider Alum skids, Marchal E-Code Lamps, 45qt Engel refrigerator / freezer, 09 Mygig w/ipod interface, Katzkin leather, ya its got a Hemi :-)
dsy is offline
post #19 of 54 Old 12-08-2009, 07:23 PM
Hellbound13
I do not see how it is possible to get grease where it needs to go (between the load bearing surfaces) on the stock ball joints using a grease gun.
Hellbound13 is offline
post #20 of 54 Old 12-08-2009, 07:42 PM
last5liter
Originally Posted by harald-hans View Post
Hi,
by upgrading my Rubicon to the “Alloy USA” - Chromoly front axle shaft kit - #12155 - we found that the front right ball joint is gone.
I changed it to a greasable version - my mechanic told me that this greasable version is the OEM version on the last TJ Jeep - why not on the newer JK
Greetings from Germany
harald-hans
Did you notice anything bad with the ball joint driving wise, or did you notice it was gone after you were under the jeep?
Seems like you would have some sort of clue driving the ball joint was going?
07' 2dr X model. Auto with 4:10's on 35" goodyear kevlar's
Blue jeep club member #305
last5liter is offline
post #21 of 54 Old 12-08-2009, 09:22 PM
robsbluerub
Hellbound13 told you how - with the needle.
I've go 47,000 miles, including 5,000 with a lift and 35s with no issues on the ball joints. Every complex mechanical system can be characterized by a bell curve of experience with failures. Don't paint the whole population of vehicles as flawed becuase yours is the one that failed. Sucks for you but doesn't mean the lot of them suck.
2007 JK 2dr Rubicon, 3" Black Diamond Lift, 35" KM2s, M/T Classic IIs, Rancho shocks, Mopar bumpers, 8000 lb winch, Ace rock sliders, Skid Row engine/oil pan skid, evap skid, Tom Woods driveshafts, Riddler diff covers, rear adjustable upper control arms, chromoly rear shafts, Reid knuckles, Synergy chromoly tie rod, track bar, and flipped drag link.
robsbluerub is offline
post #22 of 54 Old 12-08-2009, 10:19 PM
Hellbound13
Im not. Mine only failed once. But the pages upon pages on the other forum of multiple ball joints failing and even AEV engineers and my local dealer saying these are a very weak point on the JK are enough to convince me. Consider yourself lucky yours has lasted.
Its possible you don't see a lot of salt where you live and it does not eat at the joints.
One member here even had his crumple in his hands when he removed them. The inner part is made of PLASTIC.
You would not see so many posts asking for better ball joints this early in the game if the stock ones were so stout.
post #23 of 54 Old 12-09-2009, 05:12 AM
dsy
May be wishful thinking on my part but no problems so far, so I think I will continue with the program until something better comes along
dsy is offline
post #24 of 54 Old 02-14-2010, 12:48 PM
stoplocknroll
so let me get this ****ing straight we ball joints with plastic centers? WOW
stoplocknroll is offline
post #25 of 54 Old 02-14-2010, 02:35 PM
ronjenx
ronjenx's Avatar
Yes....
http://www.jeepforum.com/forum/f96/o...-study-962013/
ronjenx is offline
post #26 of 54 Old 02-14-2010, 02:45 PM
Hellbound13
Originally Posted by roc4117 View Post
I was just under my Jeep, two of them are leaking again!!!
Ball joints don't leak.
post #27 of 54 Old 02-14-2010, 02:47 PM Thread Starter
roc4117
Go Broncos!!!
roc4117's Avatar
Sorry, wrong thread, thought this was the differential thread.
Rock
Freedom has a taste that the protected shall never know
Colorado Jeep Club Member #115
roc4117 is online now
post #28 of 54 Old 02-16-2010, 03:10 PM
harlequinreef
what kind of damage can a bad ball joint cause? In other words, if I plan on upgrading to adjustable control arms, trac bar, and tie rod,...should I replace the ball joints too? I have no symtoms of bad ball joints btw.
harlequinreef is offline
post #29 of 54 Old 02-16-2010, 04:25 PM
ronjenx
ronjenx's Avatar
No need to replace ball joints until they wear out.
Radial (side-to-side) movement in the upper ball joint should not exceed 0.060" (1.5mm).
Axial (up and down) movement in the lower ball joint should not exceed 0.050" (1.25mm).
ronjenx is offline
post #30 of 54 Old 08-05-2010, 12:43 PM
PIG
Problem solved...
Poly Performance JK Ball Joints
www.SynergyMfg.com
PIG is offline
Ball, joint, U-joint, control arms? Clunking noise. FritzTJ TJ Wrangler Technical Forum 11 09-18-2009 10:59 AM
U-Joint and Ball-Joint question gcally TJ Wrangler Technical Forum 5 02-18-2009 10:28 AM
Lift Control Arms: Ball joint vs Heim Joint types? CB3 TJ Wrangler Technical Forum 5 04-21-2007 12:27 AM
new ball joint jeep lif TJ Wrangler Technical Forum 5 03-05-2007 04:20 PM
front wheel problems (u joint, ball joint etc) ohhpe YJ Wrangler Technical Forum 0 06-05-2005 03:40 PM
