Bad tie rod? - JeepForum.com
post #1 of 15 Old 11-30-2013, 09:10 AM Thread Starter
orangera1n
2009 JK Wrangler
Bad tie rod?
Hey guys, hit a mud hole a week ago going pretty fast...my bad.
Knocked the alignment out and took it to a 4x4 shop to get it realigned. The guy said everything underneath basically had to be adjusted.
My problem is that after hitting the mud hole the car will swerve when I hit bumps and the steering is very jolty randomly.
Guy said wheel bearings still had a year left and gave me some offset number (1.8), dunno what that means but he said at 2 they replace.
Also my tie rod looks like it's slightly angled, is this normal or should it be stright?
120,000 miles, 4 inch lift
Edit: if it helps, when I hit bumps it pulls sharply towards them.
orangera1n is offline
post #2 of 15 Old 11-30-2013, 09:13 AM Thread Starter
orangera1n
2009 JK Wrangler
post #3 of 15 Old 11-30-2013, 09:53 AM
mudb8
want it rite or rite now?
mudb8's Avatar
The offset is likely camber. 2 is smoking dope.... Ball joint is prolly loose.
Imo... If we cant hit mud holes going fast, how can we do speed bumps at 25? Which is "fast" for some off road.
Your pic is pretty dark. if the rod is bent, the only thing "out" is the toe.
One important thing to look closely at is the axle mount for the track bar.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #4 of 15 Old 11-30-2013, 10:03 AM Thread Starter
orangera1n
2009 JK Wrangler
Can this be fixed for free?
post #5 of 15 Old 11-30-2013, 10:22 AM
mudb8
mudb8's Avatar
Your toe.... Yes.
Your bracket? With time, plate, grinder and A welder. I use polly perf brackets if i have time to order one.
mudb8 is offline
post #6 of 15 Old 11-30-2013, 10:25 AM
mudb8
mudb8's Avatar
Originally Posted by mudb8 View Post
Your toe.... Yes.
Ball joints..... If you are mechanically inclined. Plus the part.
mudb8 is offline
post #7 of 15 Old 11-30-2013, 10:27 AM Thread Starter
orangera1n
2009 JK Wrangler
Just tested ball joints. Jacked the jeep up and I was able to move the right front tire with my hand up and down. With a prob at it had lots of play.
post #8 of 15 Old 11-30-2013, 10:33 AM Thread Starter
orangera1n
2009 JK Wrangler
So should I replace them ASAP?
I was thinking about taking it to Firestone and seeing if they come up with them same thing that I did. (Jeep dealership is out of question XD)
post #9 of 15 Old 11-30-2013, 10:50 AM
mudb8
mudb8's Avatar
Loose, asap.
Be sure its ball joint movement and not unit bearing play. Neither should have play.
Have them show you any movement they claim to find before parts are changed or work is performed. Only Accept the use of Moog ball joints.
mudb8 is offline
post #10 of 15 Old 11-30-2013, 10:51 AM
mudb8
mudb8's Avatar
Im not sure what kind of 4x4 shop would have passed up on a gravy job like that....
mudb8 is offline
post #11 of 15 Old 11-30-2013, 11:27 AM Thread Starter
orangera1n
2009 JK Wrangler
Eh the guy who owns the place didnt want us to buy something we didn't need XD. He try's to be really honest.
It's at firestone now. But do you guys think that bad ball joints would cause the car to be so uncontrollable? And it makes a squeak noise when turning left.
post #12 of 15 Old 11-30-2013, 02:14 PM Thread Starter
orangera1n
2009 JK Wrangler
Update:
Firestone said nothing's wrong and that it drives like it should...HA
Guess I'll be taking back to the 4x4 shop -_-
post #13 of 15 Old 11-30-2013, 03:41 PM Thread Starter
orangera1n
2009 JK Wrangler
MORE UPDATES:
I moved the steering wheel with the engine off and the pitman arm (the think connected from the power steering box to the tie rod???) moves a lot up and down when I turn left and right. Maybe it's loose?? Also I've come to the conclusion that it is steering wheel slop and the wheel has a about an inch of play.
Can someone please tell me if the pitman arm is suppose to move up and down excessively?
The sloppy steering only occurs during the pitman movement.
post #14 of 15 Old 11-30-2013, 07:29 PM
mudb8
mudb8's Avatar
Find someone that wl actually jack it up and check things out. A steering wheel shake is the first thing on the to do list with a helper. If you felt movement when you jacked it up, how can two shops not find anything wrong?
mudb8 is offline
post #15 of 15 Old 11-30-2013, 07:30 PM
Magatetzz
Do you know how to check tie rods, drag links, ball joints, and track bar bushings? Very easy if you have a jack, a pry bar and someone to help.
... and see what it's really going to take to build one...and then I'm going to triple that cost/time estimate and see how I feel.
Best gas milage from my Jeep to date: The time I pushed it across the lot at work.
Magatetzz is offline
bent , bent tie rod , steering , tie rod
