Bad Luck or are JK Windshields Prone to Cracking? - JeepForum.com
post #1 of 31 Old 04-19-2010, 03:37 PM Thread Starter
RedArrow10
My latest of 5 Jeeps that I've owned is a 2009 Sahara Wrangler Unlimited. I've owned one YJ Laredo, two TJ's, and a Cherokee. I've never had a problem with the windshields cracking from stones until I got my JK. I'm getting ready to replace my fourth windshield in less than 8 months! All of them due to stones hitting the windshield because it's obvious where the impact was and crack started. Is this just my bad luck or a design flaw in the JK? Has anyone else experienced this? This is getting expensive to pay $100 deductable every time. Thanks.
"There is nothing so likely to produce peace as to be well prepared to meet the enemy."
105th Cavalry - OIF 07/08 - 101st Airborne
RedArrow10 is offline
post #2 of 31 Old 04-19-2010, 03:41 PM
Hornsby
2010 JK Wrangler
I got a rock crack the first week I had had it. Luckily it hasn't spread and I haven't gotten any more in the 6 months after.
Hornsby is offline
post #3 of 31 Old 04-19-2010, 03:51 PM
rjt36
rjt36's Avatar
2009 JK Wrangler
I haven't gotten a crack in mine yet, but every time I drive it sounds like it. I guess the pressure difference causes the windshield to contract and expand and it makes a sound like a crack should have appeared across the glass.
I've only been hit by stones a couple times, and nothing here, but I've heard the windshields are easily cracked. I've made it a point not to drive behind dump trucks or get too close on certain pavement types.
rjt36 is offline
post #4 of 31 Old 04-19-2010, 04:06 PM
MrOrange
2009 JK Wrangler
With the JK, they curved the windshield to try and help with aerodynamics as well as rock chips. I've had several rocks hit my windshield at highway speeds and I haven't had any chips or cracks. You should try one of those guys on the corner of a gas station that fill in the chips. It may be cheaper and prevent the chip from turning into a crack.
'09 X Unlimited, 4WD, auto, half-doors, soft-top
RC 2.5" Series II BB, JKS Quick Discos, JKS adjustable front track bar
15x8 Unique 297 (Soft 8), Goodyear MTR/Kevlar 35x12.50R15
5.13 gears, ARB front locker, Currie front shafts
Bushwacker flat flares, Rubicon rails with steps added
MrOrange is offline
post #5 of 31 Old 04-19-2010, 04:10 PM
jeb3
No chips or cracks on mine yet, just alot of bugs.
jeb3 is offline
post #6 of 31 Old 04-19-2010, 04:18 PM
MattJK09
2009 JK Wrangler
Got a big peck in mine a few weeks ago on the freeway. It will crack across if I don't get it filled soon...
09 X 23S Flame Red 2door, tinted, Black Rock 997's, BFG 32" MT's, grab handles, RR XHD front bumper,BW trail armor,4door springs up front, KC's
MattJK09 is offline
post #7 of 31 Old 04-19-2010, 04:23 PM
CoriolisSTORM
WHAT?!
CoriolisSTORM's Avatar
2010 JK Wrangler
Got mine repaired by safelite today... And I can't find an auto insurance company in Alabama that waives the glass deductible. It's always whatever your comp is...
1998 TJ Wrangler SE - Stone White, 2.5Ls of screaming lifter clacking power, AX5, 31" BFGoodrich All Terrain T/A KOs
2010 Wrangler Unlimited Sahara - Deep Water Blue, 3.8Ls of oil consuming fury, NSG-370, BFGoodrich Rugged Terrain T/A 265/70/R18s
CoriolisSTORM is offline
post #8 of 31 Old 04-19-2010, 04:39 PM
jd_goldcombat
2010 JK Wrangler
I have a 2001 TJ and a 2010 JK Unlimited. Not sure if it's just bad luck...but these appear to be FOD (foreign object damage) MAGNETS! Probably because they are slightly less aerodynamic than full sheets of plywood. TJ: Rock strike on the windshield in the first two weeks of ownership. One week later the the strike spider-webbed the whole windshield.
JK: Rock strike on the windshield in the first week of ownership. Learned lesson from TJ. Had safelite repair the chip within two hours. Seven weeks later. rock strike on the driver's side windshield pillar. Result: pencil-eraser sized chip in the paint right down th the bare metal.
All three rock strikes occured on I-5. Two in Seattle, one in Tacoma. I should sue WA-DOT. I think it's because they won't enforce seasonal use of studded tires and the roads get chewed to pieces.
Never confuse effort with results......
jd_goldcombat is offline
post #9 of 31 Old 04-19-2010, 05:31 PM
JeffinWesternWA
2010 JK Wrangler
Look at the angle of the JK windshield! It's gonna take hits that glance off most others, but, small "bullseyes" are often fixed by most every insurance co at NO charge NOR deductible w/ filler and pressure and it works., but, once the crack starts runnin' it's just a matter of time....
JeffinWesternWA
JeffinWesternWA is offline
post #10 of 31 Old 04-19-2010, 05:49 PM
997s4ken
I got one on the lower passenger side. It spread out faster than peanut butter on a sandwich.
997s4ken is offline
post #11 of 31 Old 04-19-2010, 05:49 PM
Double Dog
Back from da stinkin' box
Double Dog's Avatar
Two windshields so far. One rock and one piece of debris from a truck.
Double Dog is offline
post #12 of 31 Old 04-19-2010, 05:56 PM
PlatinumOre
i have two wicked dings on my windshield frame and one nick on the windshield itself.
the ones on the frame..holy cow.. I'm so glad they hit the frame! massive one took a chunk of paint the size of 3/4 a dime, and the other is under the windshield and looks like someone punched it with a big center punch.
PlatinumOre is offline
post #13 of 31 Old 04-19-2010, 05:59 PM
bubba2u
2009 JK Wrangler
had to replace mine too
bubba2u is offline
post #14 of 31 Old 04-19-2010, 07:44 PM
xracer
My first one cracked for no apparent reason, no stone chips or anything that I could find. I had a local windshield shop replace it and the new one had a whistle from 35mph up to about 55mph so they put in a new one for me and the new one cracked when I let the wiper blade slap down on the windshield after washing it. Again the glass shop installed another one and I got another whistler, they took this one back out and installed a different type of seal that flush trim going around the perimeter that seemed to eliminate the whistle. All of this occurred in a matter of about a month and was very frustrating, thankfully the glass shop was very accommodating and was very expeditious in repairing each time.
xracer is offline
post #15 of 31 Old 04-19-2010, 08:28 PM
mandalayjim
Like most of you guys, I also have had a windshied replaced. Mine was caused by a stone that hit at the lower edge of the glass and spread in a long line. The glass guy told me it is because there isn't any metal trim around the glass and the slightest ding on the edge of the windshield will usually result in the long line crack. Lucky for me, here in AZ, regardless of your glass deductible the replacement doesn't cost any $$ if the damage happens within the state. State law.
mandalayjim is offline
Are 2.5l exhaust manifolds prone to cracking? EABiker YJ Wrangler Technical Forum 10 03-15-2010 10:24 PM
no carpets, more prone to rust? MC_NickP TJ Wrangler Technical Forum 11 02-27-2009 01:08 PM
TJ's prone to rust???....... dali555 TJ Wrangler Technical Forum 12 06-22-2005 09:11 AM
Rust prone spots??? Timbo TJ Wrangler Technical Forum 7 01-20-2004 11:19 AM
