Back space for 35" wheel - JeepForum.com
post #1 of 12 Old 01-19-2014, 11:50 AM Thread Starter
Meir10
I have surched in the forum, and am not sure with the back space for my JK.
the lift is Rock Krawler Max Travel 2.5" , will put 315/70/17 wheels. Should I go for 4.5" / 4.75"/ 5" back space?
Meir10 is offline
post #2 of 12 Old 01-19-2014, 12:14 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
4.5 is usually the recommendation for a 35 inch tire...5 will stick it way out and add even more stress to the suspension.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 12 Old 01-19-2014, 01:34 PM Thread Starter
Meir10
4.5 will stick it out more than 5...??
Meir10 is offline
post #4 of 12 Old 01-19-2014, 01:55 PM
JoonHoss
2011 JK Wrangler
Correct, 5" BS will tuck it further UNDER the flare, not extend it further out.
IMO- I like the look of them tucked in a bit more, but for clearance, they need to be spaced out a bit. It also depend on the wheel width, and tire itself. Some tires shoulder can actually be an inch or more wider than the same size tire with a different design.
Hoss
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is offline
post #5 of 12 Old 01-19-2014, 04:06 PM
awinski
yes less back spacing means the tire will stick farther out
The ONLY chlorophyll JK
one more horse power than the average pentastar;
twitter/IG - @Becauseracejeep
awinski is offline
post #6 of 12 Old 01-19-2014, 04:29 PM
RockyClymer
RedRock4Wheeler
Opps...my math was backwards....yes, 5 will not be enough.
NRA Life member
post #7 of 12 Old 01-19-2014, 10:42 PM Thread Starter
Meir10
5 is not enough, 4.5 or 4.75? any recommendations?
Meir10 is offline
post #8 of 12 Old 01-20-2014, 06:29 AM
TheBoss
4.5 will give you the option later to upgrade your tie rod. Most aftermarket ends require a minimum of 4.5 for clearance.
TheBoss is offline
post #9 of 12 Old 01-20-2014, 08:06 AM
tslewisz
2010 JK Wrangler
I run 16x8" ProComps with 4" BS. With stock steering stops my 315/75-16's rub the front control arms and sway bar just enough to wear off the paint. I think that's pretty perfect. FWIW, I run an RK Max Travel Pro suspension.
This pic should give you a pretty good idea what it looks like.
tslewisz is offline
post #10 of 12 Old 01-20-2014, 09:20 AM
SLADE
5" is just enough.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline
post #11 of 12 Old 01-20-2014, 09:20 AM
SLADE
If you have your pick, go with 4.5".
2014 Wrangler JKU
2013 Wrangler JK
2001 Dodge Ram 2500
SLADE is offline
post #12 of 12 Old 01-20-2014, 11:15 AM Thread Starter
Meir10
Thank you guys, will go for the 4.5.
Meir10 is offline
