B&M Transmission Cooler Help! - JeepForum.com
post #1 of 17 Old 06-30-2013, 11:20 AM Thread Starter
MoonyJohn
Hey guys, I got the aux cooler and Im not exactly sure which lines tag into eachother. On the side of the radiator there is a white and black line. Any help from someone whos does this would be alot of help. Its pushing low 90s today so Id like to get started on this as soon as I can.
Thanks
MoonyJohn is offline
post #2 of 17 Old 06-30-2013, 11:21 AM Thread Starter
MoonyJohn
A couple pictures of what Im talking about
post #3 of 17 Old 06-30-2013, 12:00 PM
greenrover
I have one installed.
The upper line (white) should be the "return" line from the factory cooler that you want to splice into (double check me, it will also be the upper line into the transmission), there will be a small rubber section where you can do this.
After you cut this line, the radiator side of the splice should go to the IN side of the B&M and the transmission side should connect to the OUT of the B&M.
Hope that helps.
07 2dr Rubi*2.5" Lift*5.38's*35's*ARB Diff Covers*ARB Bumpers*Milemarker 9.5SX*IPF 900XS Lights
greenrover is offline
post #4 of 17 Old 06-30-2013, 01:34 PM Thread Starter
MoonyJohn
Hope that helps.
Ok gotcha, thankyou! I just got it mounted where it needs to be, but Ive got to run a few errands before I get going on the tubing. Just getting it mounted took me a little bit, this hot weather sucks because my hands get really sweaty lol.
Looking forward to getting this done, I can tell that the transmission isnt shifting like it should. I want to eventually get a tranny temp gauge, do you have one installed?
post #5 of 17 Old 06-30-2013, 03:10 PM
Butterjeep
2015 WK
You could also run an in line oil filter with an oil filter relo kit. Then clamp a magnetic heat sink to the oil filter for even more fluid capacity, cooling and protection.
2014 Mustang GT Track Pack
2015 WK2 Limited 4x4
Butterjeep is offline
post #6 of 17 Old 06-30-2013, 03:29 PM
Jiblet
if you need extra tubing be sure to get transmission line, not fuel line. You want the line to handle the heat.
I use an aeroforce gauge plugged into the OBDII port. Other options are a temp gauge attached into the trans pan. There are threads on that set up.
Jiblet is offline
post #7 of 17 Old 06-30-2013, 04:14 PM Thread Starter
MoonyJohn
Oh really? Can you get me a link on a temp gauge that plugs into the port? Seems less hassle if you want a gauge.
I went to autozone and asked for some 3/8" radiator tubing. I got 3 more feet. The job wouldnt have been doable with just the tubing that came with it. I cut off about 10 inches off the one that it came with.
post #8 of 17 Old 06-30-2013, 04:25 PM Thread Starter
MoonyJohn
Thanks for the help guys, I was cringing when I was cutting the hose the first time haha. All turned out good. Only a couple things to look out for. They only give you 4 hose clamps, when really you need 6. The other two I used on the cooler itself. So just something to look out for, because you will need 4 at where you make your splices. Also, needed 3 feet more line, worked out perfectly, only had less than a foot of hose leftover.
Also, make sure that the hose splicers are tight, i had a leak in no time so I added some thread sealer on the supplied parts and it seemed to fix the problem. All in all, it would be a really easy project if it wasnt so damn hot outside!
post #9 of 17 Old 06-30-2013, 05:46 PM
Jiblet
I use the aeroforce interceptor. They are a bit pricey but it do a lot more than just the trans temp.
http://www.aeroforcetech.com/products_interceptor.html
Jiblet is offline
post #10 of 17 Old 06-30-2013, 06:03 PM Thread Starter
MoonyJohn
Looks nice, maybe when I have some funds.. I need to save for a bumper somehow.
post #11 of 17 Old 06-30-2013, 06:28 PM
PlatinumOre
That looks like quite the bend... is it just the picture angle?
I ran mine a bit differently..need to redo it.
PlatinumOre is offline
post #12 of 17 Old 06-30-2013, 07:48 PM Thread Starter
MoonyJohn
Probably just the picture. Its actually pretty loose
post #13 of 17 Old 07-01-2013, 07:27 AM
JIMBOX
Heh Heh, I went redundant with my aux coolers (2)--
Eight 1" hose fittings, but no leaks after 3 years-
Ya just gotta be careful/w install, course I bypassed the stock cooler (warmer)--
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #14 of 17 Old 07-01-2013, 08:15 AM
jchappy
2011 JK Wrangler
why didn't you just use a barb? Instead of the treaded fittings.
MY NEW JEEP- 2011 JEEP JKUR, Body Armor front bumper, Warn XD9000I winch, Synthetic winch line,XRC Rear Bumper W/Tire carrier, OBA W/1Gal Tank, Terafex 2.5in spring lift, Bilstein 5100 shocks,GY 315/70R17 Duratracs, 4.88 G2 gears, Cobra 75 CB
MY OLD JEEP-1999 Wrangler Sport 4.0L, 4" Pro Comp Lift, 33" BFG's, 8K winch, SYE, Viking soft top, onboard CO2 and all the recovery straps and equipment
jchappy is offline
post #15 of 17 Old 07-01-2013, 09:46 AM Thread Starter
MoonyJohn
Came with the kit, had no problem using them.
