Axle swap to run 37s? - JeepForum.com
post #1 of 13 Old 10-10-2012, 10:40 AM Thread Starter
smartbutlazy374
2011 JK Wrangler
Im on a 2011 JKU (not a rubicon) and I am looking to go with 37s soon, Is it possible for me to just sleeve, trusset and gusset the d35? I plan on doing a re-gear to 5.13s so im set there. I'm just curious if i need to upgrade to a 44 upfront to roll 37s, or if I can just mod the existing 35.. and another question, will the stock rubicon 44 fit on my sport? Forgot to mention, yes this is jeep is used to crawl, but not often. Thanks guys!
"This is why you do all your mods before you get a wife." - WhiteOut
"I have come to the conclusion that the wave is NOT a Jeep thing- it is a WHEELER thing." -N2rock
smartbutlazy374 is offline
post #2 of 13 Old 10-10-2012, 11:52 AM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
First, you have a D30, not a D35. Yes, you can sleeve, gusset and run Chrome moly, but that might still be marginal for 37s, esp after regearing which will use a smaller pinion gear IMO. Yes, you can upgrade to a D44 and even a built D44 while at it, and yes, the D44 off of your JK sport will fit, not from a TJ sport though
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 13 Old 10-10-2012, 12:58 PM Thread Starter
smartbutlazy374
2011 JK Wrangler
Always get confused on the whole d35 d30 stuff, im told both. My friend said she would give me her 44s when she runs some 60s, so thanks for the input!
post #4 of 13 Old 10-10-2012, 01:26 PM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
You have a Dana 30 and a Dana 44. Most TJs came with a Dana 30 and Dana 35 set. Still, I would beef up the front end substantially to even begin to talk about running 37s reliably
Sent by Paper Planes
My builds:
and
or follow us on
spyder6 is offline
post #5 of 13 Old 10-10-2012, 02:07 PM
SoK66
2009 JK Wrangler
You can beef up the housing to be as strong as a sleeved & gusseted JK Rubi front D44. You can add an ARB and you can also run RCVs. However, your final weak spot is going to be the ring & pinion itself. I threw a ton of money at my Rubi's front axle, but if I had to do it all over again I'd just get a Pro Rock 44 and be done with it.
SoK66 is offline
post #6 of 13 Old 10-10-2012, 03:38 PM
ArticRubi
Arrogant SOB
ArticRubi's Avatar
I would recommend running a full width axle truss. Artec sells a whole "front axle armor" kit that gives you the truss, control arm skids, and gussets for your inner knuckles.
Need parts? Need product advice? Contact Jason at
ArticRubi is offline
post #7 of 13 Old 10-10-2012, 03:44 PM
1AAdam
X2
Adam
1aauto.com
888-844-3393
1AAdam is offline
post #8 of 13 Old 10-10-2012, 06:22 PM
1222
RIP John
1222's Avatar
Lots of options here, take your time, do your homework and donít cut corners.
(2011-2016)
1222 is offline
post #9 of 13 Old 10-11-2012, 08:13 AM
SoK66
2009 JK Wrangler
Ditto. Against our advice, one of my wheeling buddies has built his '93 YJ's D30 to nuclear bunker strength with trusses, gussets, chromolys, CTMs, etc. Although he has a D44 sitting in his garage he refuses to replace the D30 it until it grenades, utterly. He runs Carnage (Buena Vista, CO) with it regularly. So far it makes it through every time.
SoK66 is offline
post #10 of 13 Old 10-11-2012, 08:25 AM Thread Starter
smartbutlazy374
2011 JK Wrangler
Cool, thanks guys. I probably will just build up my 30 until it goes, then I'll just build up the 44 when I get it.
post #11 of 13 Old 10-11-2012, 08:32 AM
jeephidelt
I just helped a buddy from another forum put this kit on last weekend and I definitely recommend it. Beefy as hell, great price ($200ish?)
2007 JKU X
-Tyler
jeephidelt is offline
post #12 of 13 Old 10-11-2012, 09:40 AM
Godholio
It always does, until it doesn't. That's very nice of him to put it on the people around him to get it out when his time bomb goes off.
Utah Jeep Crew #148
No powerball here? How am I supposed to finance the mods?!?
'12 Sport...miss my YJ for all the wrong reasons though
Godholio is offline
post #13 of 13 Old 10-11-2012, 09:52 AM
HappyTrails
HappyTrails's Avatar
The only difference between the D30 and the D44 is the size of the differential housing. Everything else is the same. The D44 can run up to a 5.89 gear.
I'm running a stock D44 up front, but is gussetted and sleeved and am on 37's. Chromoly axle shafts are on my must-have list. Already snapped an axle shaft. But that was due to running 4.10's and 37's with a supercharged engine while crawling.
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel, Rancho 9000XL shocks, 37" Nittos, 5.38's, RR skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
Political Correctness offends me.
HappyTrails is offline
