Axle Seal Leaking/07 JK - Page 2 - JeepForum.com
post #16 of 21 Old 05-13-2008, 12:46 PM Thread Starter
oaklane
oaklane's Avatar
Well my jeep survived yet another visit to the dealer to have the axle seals looked at on April 28, 2008. They called during the day to say that they weren't leaking at all and really didn't want to replace them both since they couldn't see any evidence of leakage. I have the evidence I have the pictures and when I come to pick it up, I'll show you. Good thing I took pictures. The passenger side has been now replaced 2x and the driver side once. I find myself looking every time I get in and out. Im hoping this isn't going to be a lemon item.
It's A Jeep Thing.......,
oaklane is offline
post #17 of 21 Old 05-13-2010, 01:12 PM
LBarcher
Dredging up an old thread...
My 09 Rubicon is headed for its 4th seal replacement in under 40 thousand kilometres.
Hopefully I can talk the dealer into finding the cause this time.
The Jeep is stock and has only seen gravel roads so I don't think they can claim abuse.
If they don't find a better fix, I'm tempted to trade it off for something else.
LBarcher is offline
post #18 of 21 Old 05-13-2010, 02:27 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Since the seals are located at the differential end of the axle shaft, then you would really have to suspect burr or something on the shaft itself is tearing or wearing the seal - they should really check the inner end of the shaft for some abnormality that is causing premature wear. I have sleeves in my axles that also provide an integral seal at the outer end to prevent water, dirt and debris from entering the inside of the axle tube altogether.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #19 of 21 Old 05-13-2010, 03:04 PM
McKBrew
JK Wrangler
Seems like it is often the right sides on these. I've had the right side fixed once. Thought it was leaking again, but it ended up being left over residue.
McKBrew is offline
post #20 of 21 Old 05-13-2010, 03:17 PM
LBarcher
The "left over residue" was brought up. Left over residue won't drip on my garage floor.
I told them that the job isn't done until the mess is cleaned up.
Honestly, any mechanic worth his papers shouldn't let something like that happen.
The dealership knows what I expect and 2 minutes with a rag isn't too much to ask.
LBarcher is offline
post #21 of 21 Old 08-09-2010, 09:05 AM
muttytruckster
Bump,
Bring up an Old Thread but, yesterday I noticed as I change my oil that my driver side rear axle is leaking. Checked the level of the diff with my finger and its maybe a 1/4 inch low on diff oil. Don't want to fill it so I can show it to the stealership.
One: It has 61500 miles on it ( Daily Driver - My Wife)
Two: We off-roaded on Jan 1, 2010 however we didn't touch any water or mud.
Three: Last time I off-roaded in water or mud was right at 2.5 years ago.
SO..... for all you people that have had this problem,.... do you have any post thoughts or suggestions, or you wish you should of done........???
2007 Jeep Wrangler Unlimited Rubicon -JKUR
Rescue Green 6-Spd, 33" KM2s- 17 x 8 BlackRock Series 909 wheels, Stainless Steel Gibson Exhaust & AFE Air Intake, Superchips, Aberle Front Bumper&10.5K Winch, PiAA ATP Lights
muttytruckster is offline
axle seal , JK Wrangler , leak , leaking fluid , wrangler
Leaking Axle seal on the front. Should I upgrade the axle to a dana 44? MWguy101 YJ Wrangler Technical Forum 21 03-01-2012 12:08 PM
Leaking axle seal 8.8 dmock YJ Wrangler Technical Forum 9 08-30-2009 09:17 PM
Axle seal? leaking axle fluid from u-joint ZeroGravity YJ Wrangler Technical Forum 21 02-11-2009 11:10 AM
94 yj leaking axle seal Help turbotempo85 YJ Wrangler Technical Forum 7 04-12-2007 12:27 PM
Axle seal leaking Kajunjeepn TJ Wrangler Technical Forum 1 06-08-2006 04:31 PM
