Axle Gussets, worth it or not? - Page 2 - JeepForum.com
post #16 of 21 Old 07-26-2010, 08:08 AM
juiceparn
I have the gussets welded on the C's. A little too late though as mine are already bent but not enough to replace the whole housing. One of mine is much worse than the other but I think they are cheap insurance even if they only make it 10% stronger. Dave at Taboo Customs does these for less than $50 a pair and if your local he'll even weld them on. The EVO gusset is much larger and sits right up against the coils. Taboo's are 3 1/4" plate pieces welded around the C. Home -
07 JK 4DR 3.5" Rubicon Express, C gussets, Front XHD stubby, winch, Taboo Customs rear bumper with tire carrier, Taboo Customs Rock sliders.
juiceparn is offline
post #17 of 21 Old 07-26-2010, 01:57 PM
Armycop
2014 KL Cherokee
I am getting some of these C-Gussets next month. With 35" tires, it will definitely help strengthen a weak point. If you wheel with big tires, it's a good thing to have.
2014 KL SPORT BILLET SILVER l 9-SPEED l 25% TINT l MB ICON WHEELS l OEM SPLASH GUARDS
Armycop is offline
post #18 of 21 Old 07-26-2010, 05:15 PM Thread Starter
takeda54
kind of off the original topic but besides the 4.10 gear, is there any difference between the Rubi rear 44 axle and the ones on the X's and Saharas?
takeda54 is offline
post #19 of 21 Old 07-26-2010, 06:07 PM
Charles
2017 WK
The guy from the project JK pic was running 40's. That's what his profile says anyway. Here's an idea, don't run 40's on stock axles.
Edit: His profile also says that he is running Dynatrac Pro Rock 60 Front w/Competition Shafts & CTM U-Joints. So he may not have had 40's on there when the break occurred, but, I think that that break is something that wouldn't happen on an axle running 35's.
Charles is offline
post #20 of 21 Old 07-26-2010, 07:39 PM
allibaster
Tru-Lock locker.
allibaster is offline
post #21 of 21 Old 07-26-2010, 07:45 PM
nwbronco
2014 JK Wrangler
Also 32 spline vs. 30 spline axles. That's why you see lockers spec'ed for JK Dana 44 except Rubicon and then another listing for the Rubicon.
Bob K.
nwbronco is offline
axle , axle gussets , axle sleeves , JK Wrangler , reinforcement , wrangler
poly performance track bar bracket and c-gussets premo JK Wrangler Technical Forum 0 05-03-2010 01:23 PM
what are used axle shafts worth? soupy6914 Wrangler General Discussion 3 04-13-2010 09:13 PM
Front axle gussets and tube sleeves jacob621 TJ Wrangler Technical Forum 1 03-15-2009 09:16 PM
Off Road Evolution C2 Axle Gussets and Control Arm Skids VegasJeep JK Wrangler Technical Forum 9 06-30-2008 10:30 AM
Are these Axle Carriers worth it? cpleasant TJ Wrangler Technical Forum 2 04-01-2006 08:07 AM
