Avg MPG Calculator Error: Sign of Other Issues? - JeepForum.com
post #1 of 15 Old 07-19-2013, 08:49 AM Thread Starter
dualtjs
2011 JK Wrangler
All of my searches have returned MPG discussions related to tire size, weight, etc, so I'll apologize if this has been discussed, but I can't find it (either via JF search or google search).
I got home from a trip to the coffee shop this morning and the Avg Eco reading was 18 mpg (not unusual, since I filled up, reset and almost all subsequent driving was highway). I got back in it a couple hrs later with the same reading and went to the store a couple miles away. When I got back in for the trip home, the Avg Eco mpg read 9.0.
I'm not naive enough to believe that these calculators are 100% accurate (in fact, the reading on my JK is usually 1-1.5 mpg lower than actual based on pump and odometer readings at fill up), but this isn't a calculator error. In this case, the system is simply not working correctly and appears to give random numbers when it wants to. Has anyone else experienced similar results? Is there a chance that this is an indication of other possible problems?
dualtjs is offline
post #2 of 15 Old 07-19-2013, 08:56 AM
SoCal_HEMIHead
I find mine varies a lot after a reset. I believe this to be true since it's calculating the "average", so it doesn't take much to throw off the average. The longer I drive, the more it will balance out the highs and lows.
SoCal_HEMIHead is offline
post #3 of 15 Old 07-19-2013, 09:55 AM
222Doc
222Doc's Avatar
THis^^^^^^^
if you are on a steep grade going down hill. Hit the reset on our 012 I can get that thing to read over 1000mpg. who says a Jeep aint like priuse
222Doc is offline
post #4 of 15 Old 07-19-2013, 09:55 AM Thread Starter
dualtjs
2011 JK Wrangler
The problem in my scenario is that I drove almost 40 miles to get the 18 MPG when I arrived at home. The trip to the store was 2 miles. I would have to get less than 1/2 MPG, to get 9 MPG when I got back in for the drive home. No way this is real fluctuations in due to different driving conditions, early after reset.
Edit: upon recalculating, the MPG for the trip to the store would have to be negative, to go from 18 MPG at 40 miles, to 9 MPG at 42 miles.
dualtjs is offline
post #5 of 15 Old 07-19-2013, 01:57 PM
rha600
You absolutely could be getting 1/2 mpg.
Like SoCal said, it varies A LOT when you first reset, and what it will do is that if you are say, at a traffic like, you are still burning fuel, but you're now getting 0 mpg. It factors that in. I've literally watched mine go from 24mpg down to 13mpg while waiting for one red light. Now this was within 1-2 miles of resetting it, but point being, if you did sit at a traffic like, or had the Jeep running while you ran in the store...that's what hosed you.
rha600 is offline
post #6 of 15 Old 07-19-2013, 02:49 PM
JoonHoss
2011 JK Wrangler
probably just hit the reset while driving right before you got home
Hoss
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is offline
post #7 of 15 Old 07-19-2013, 06:03 PM Thread Starter
dualtjs
2011 JK Wrangler
I suppose if I let it idle for 15 min or more, that's possible. I wouldn't bring up the matter, if that were the case. We're talking about a 3-4 min trip to a store ~2 miles away, which means that the trip would have to have negative MPG to get the results.
The accidentally hitting reset is a logical suggestion. I don't think that I did (my system requires at least 1 full second press to reset), but anything is possible.
dualtjs is offline
post #8 of 15 Old 07-19-2013, 09:21 PM
ncb
Don't lose sleep over it. It's not a very accurate gauge if you reset it and immediately check it. To be even close to accurate I've noticed you have to leave it alone and run a couple tanks through it. Checking mpg the old fashioned way is more accurate.
ncb is offline
post #9 of 15 Old 07-20-2013, 08:58 AM
rayder1
I accidentally bump the reset switch from time to time. Maybe that happened.
rayder1 is offline
post #10 of 15 Old 07-21-2013, 12:55 PM
rha600
The distance to the store doesn't matter. it's how long it took to get there.
Read the rest of my post, right after resetting mine, I lose 11mpg just sitting at one red light. I don't believe that would be accurate, but it did do it. So if you did just reset the mpg and went to the store, even it it were 1/3 mile away, if there were 2 red lights in between and maybe it took a while pulling out of your street, it will drop big time.
On a side note, my last jeep did not do this. Sure it would drop as I sat in place longer and longer, but this one drops FAST.
Oh, and it's never been as much as you experienced, but I have been at 18mpg when I get home, wake up the next morning, go to leave for work and it shows 15 or 16mpg. Dunno what's up with that.
rha600 is offline
post #11 of 15 Old 07-21-2013, 06:34 PM Thread Starter
dualtjs
2011 JK Wrangler
Distance certainly does matter. Short distance taking a long time will cause the correct MPG to drop significantly. Sitting an idling in my driveway for 15 min can cause a large drop in MPG. I stated distance and time, to ensure that anyone reading it didn't hypothesize that I sat at idle for a lengthy time period.
dualtjs is offline
post #12 of 15 Old 07-22-2013, 05:08 AM
rha600
Nevermind.
If you keep reading past the part where I lost 11mpg at ONE RED LIGHT then I can't get it through your head that 3-4 minutes is long if you just reset the system.
rha600 is offline
post #13 of 15 Old 07-22-2013, 05:38 AM
murfysflaw
2011 JK Wrangler
I'd bet this is your issue too. Happens to me quite often.
murfysflaw is offline
post #14 of 15 Old 07-22-2013, 08:03 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
Probably not.
JeepCares is online now
post #15 of 15 Old 07-22-2013, 09:09 AM
Wavedatya
2010 JK Wrangler
Talk about mpg. I drove 2000 miles and an average of 12 mpg. Now that sucks.
OF4WD member #7523. Durham 4x4 member.
Wavedatya is offline
