Avenger Supercharger Half Top Install - JeepForum.com
post #1 of 129 Old 08-24-2011, 11:04 PM Thread Starter
dvdsjk
dvdsjk's Avatar
Ok. A lot to do for the install. You have to strip the back out first. Think about relocating everything thats in the way such as sound bar speakers, subwoofer which as we know is in the back,so you have to dissassemble wire harnesses etc. Prep and paint the top. Pre fab a lot of spots to make cockpit watertite. I probably will fab a rear floor, as well as cutting sound bar to retain my dome light. Im actually into day two with this so here we go! Day 1 strip the back of carpet, seatbelt assemblies. roll bar padding and foam that they use to make it look beefier, soundbar asembly, sub etc. A few pics.
dvdsjk is offline
post #2 of 129 Old 08-24-2011, 11:17 PM Thread Starter
dvdsjk
dvdsjk's Avatar
Day two the top and bulkhead arrive. But no windows!!! Called and they are being shipped hopefully asap!. Ok lets cut! Jack from avenger gave me some tips on the install as there are no instructions. I chose to cut at an area as to retain the stock mounting point for the sirius antenna. the fender well was cut close to base of roll bar weld area in case someone wants to turn it back to normal. After cutting a little dry fitting.
dvdsjk is offline
post #3 of 129 Old 08-24-2011, 11:27 PM Thread Starter
dvdsjk
dvdsjk's Avatar
As you can see I started messing with the paint a bit. I didnt like the way i sprayed it, a little dry, so I may try to match the grainy look of the freedom panels before i second coat it! I also started seperating the sub wires from the harness that runns to the rear and bring them back into the cab area. The sound bar was cut along with some of the rollbar padding to accomodate the dome light and give it a finished look. heres a couple pics but I have to take more in the morning so you can get the jist of what I'm trying to accomplish. Couple more pics,
dvdsjk is offline
post #4 of 129 Old 08-25-2011, 01:20 AM
jrmandryck
Stupid question but is the bottom part where it meets the floor waterproofed or could it be with some type of weatherstripping? Also how big is the bed area? That looks really really good
truth is so precious that she should always be attended by a bodyguard of lies...
jrmandryck is offline
post #5 of 129 Old 08-25-2011, 04:10 AM
SlvrJK08
Very cool, keep up the good work.
2008 JK X 2-door, 37" MTRK's, Xenon narrows, 3" Synergy frankenlift, Prorock 44 front with 5.13's/rcv's/rubi locker, Rock Jock 60 rear w/ 5.13's and a Detroit, and lots of armor...
SlvrJK08 is offline
post #6 of 129 Old 08-25-2011, 07:32 AM
Vin
You, sir, are my hero!
Vin is offline
post #7 of 129 Old 08-25-2011, 07:45 AM Thread Starter
dvdsjk
dvdsjk's Avatar
I nevermeasured the bed yet. But I will and post it. I have to purchase some diamond plate for the floor. It isnt watertight yet, but it will be! And Thanks!
Thanks SlvrJK08
Vin, Thanks!
dvdsjk is offline
post #8 of 129 Old 08-25-2011, 07:55 AM
TroutSafari
2010 JK Wrangler
very well done. Looking forward to seeing the finished product!
TroutSafari is offline
post #9 of 129 Old 08-25-2011, 08:03 AM
dsjk
2011 JK Wrangler
Sounds like a really cool project...I look forward to seeing it all done!
Originally Posted by voodooJK View Post
Something you said after the fact exposed that part of me... like a catholic school girl normally would.
dsjk is offline
post #10 of 129 Old 08-25-2011, 08:07 AM
mattlago
If I were go gues, you have the biggest pair on this forum! Wow.
mattlago is offline
post #11 of 129 Old 08-25-2011, 08:51 AM
CGT2358
The build looks great so far... What are you going to do with the tailgate? I'm assuming its not really designed for an exterior application so are you going to seal up the air flow vents or add drainage? Side note, I noticed you painted your fairlead. What did you do for prep? Sand, Prime, and Paint?
2008 Sahara Black 6 Speed
Old Man Emu Lift | Pro Comp 7005 17x9 | Goodyear Wrangler MT/R 285/70R17 | PSC Brawler Lite Front Bumper | Smittybilt XRC 8 | JKS Front/Rear Track Bar | JKS Quick Disco Front Sway Bars | KC HiLite
CGT2358 is offline
post #12 of 129 Old 08-25-2011, 08:58 AM Thread Starter
dvdsjk
dvdsjk's Avatar
Ha Thanks. And its my dailey driver.
I thought about the tailgate and figured on removing the vends and sealing them off. Theres a lot back there that needs attention such as floor areas etc. Some places i'll just pull plugs, others not sure yet. I'll try to post them as I tackle them! The bulkhead and top came primered. I sanded and used a spray like Buldog to make it a bit more sticky!
dvdsjk is offline
post #13 of 129 Old 08-25-2011, 09:01 AM Thread Starter
dvdsjk
dvdsjk's Avatar
Thanks guys!! Looking for a textured paint today.Will start hiding some of the wiring also in the bed. Oh and sand it down again!!!!!!
dvdsjk is offline
post #14 of 129 Old 08-25-2011, 05:43 PM
USAFRecon
Very nice!
USAFRecon is offline
post #15 of 129 Old 08-25-2011, 07:29 PM Thread Starter
dvdsjk
dvdsjk's Avatar
Originally Posted by USAFRecon View Post
Very nice!
Thanks Jason!
Today I finished some of the interior pieces to the puzzle such as getting the sub woofer wires back to the roll bar a well as the hard top wiring. It cleaned up the wires under the lip quite a bit! Started getting the carpet in place and see how mutch more to trim. Also installed the light in the piece of soundbar I cut. I did this because I hated the look of the mopar j8 interior freedom top screws just sitting against the bare bar. Looked out of place! Now I have to make some speaker encosures. Going to place them against the bulkhead after carpet. The sub will go behind console and maybe replace the rear cup holders. [
dvdsjk is offline
Avenger Supercharger install kenny kustom YJ Wrangler Technical Forum 18 12-14-2015 06:19 PM
Avenger Supercharger install pics, Clackamas, Or. mudb8 TJ Wrangler Technical Forum 28 04-12-2012 11:34 AM
Avenger Supercharger 2.4L install W/ pics!! suicide TJ Wrangler Technical Forum 51 04-02-2009 07:56 AM
Avenger Supercharger toastervet TJ Wrangler Technical Forum 8 10-25-2008 08:37 AM
Avenger Supercharger 2DTRAIL TJ Wrangler Technical Forum 15 03-12-2004 10:22 PM
