Aux light wiring help - JeepForum.com
post #1 of 11 Old 10-10-2012, 06:33 PM Thread Starter
gumbellion
anyone have photos of how they ran the wiring from a light bar back for thier Aux lighting. Just got my front bumper light bar and my KC lights. Wondering where you went around the grill, how you ran them under the hood, and where you mounted the switch and where you went through the firewall or around it
Going to be doing this on the weekend so would like to have a idea
Thanks
gumbellion is offline
post #2 of 11 Old 10-11-2012, 06:51 AM
Spike6901
No pics but I ran them under the hood and followed some factory hoses/wires underneath and then came up throught the floor through a drain gromit.
Future: '18 WK2 or a JL
Current: '97 ZJ - Lots of mods
Past: CJ-7, XJ, KJ, JKU
Spike6901 is offline
post #3 of 11 Old 10-11-2012, 01:54 PM
krutj
2009 JK Wrangler
I went under the grill towards the passenger side, then ran back towards the battery. I did this because my relays mount on the firewall near the battery and it's easy to make the connection there. From there, I ran along the firewall to the drivers side and went through the firewall at the grommet beside the master cylinder.
That will get you here....
Here's my harness, laid in loose, but this is the side I went, then I zip tied the aux. harness to the OEM harness.
My harness is made for my custom built aux. lights, that's why there are two leads(high/low beam) so it's much bigger than one that comes with KC's.
-- Joel --
krutj is offline
post #4 of 11 Old 10-11-2012, 03:04 PM Thread Starter
gumbellion
Thats what I am hoping to do, up the passenger then the switch near my right hand, or near the manual shifter. The harness says to run to the battery, then the relay sits near the battery by the looks of it. Is your dash pulled out or is that just removing the side pannel?
post #5 of 11 Old 10-11-2012, 09:34 PM
JTPhoto
JTPhoto's Avatar
What year of Jeep do you have. 2007-10 has a place to push wires through the end of the firewall by the side panel.
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, D44HD/J8 w/ OX locker and RCVs, 37x12.50x17 Pitbull Rockers on ProComp 2635 Predator Alloys, AEV Prem Bumper, Smitty X2O 12K ETC..
JTPhoto is offline
post #6 of 11 Old 10-11-2012, 10:23 PM
PhatBasturd
PhatBasturd's Avatar
1976 CJ7
Couple of threads for you to read:
http://www.jeepforum.com/forum/f96/e...ource-1253810/
http://www.jeepforum.com/forum/f96/a...ewall-1416640/
Sent from my over priced iPhone.
PhatBasturd is offline
post #7 of 11 Old 10-12-2012, 06:24 AM
krutj
2009 JK Wrangler
Just the side panel, I pushed enough wire through the grommet that I didn't have to contort too much to reach them under the dash. The lower panel under the steering wheel comes off easy too, makes it easy to find the wires.
-- Joel --
krutj is offline
post #8 of 11 Old 10-12-2012, 07:49 AM
Topbanana
2011 JK Wrangler
Maybe way over kill for what your trying to do but check out this product Spod at 4x4spod.com. They even have an installation
video.
Topbanana is offline
post #9 of 11 Old 10-12-2012, 08:18 AM Thread Starter
gumbellion
Sorry I better update my profile. 2007 now, sold the 1990 a few years ago.
How did you run the wire around your grill or under it? Or I guess where abouts and did you have to cut anything to make sure it fit nice?
Thanks guys
post #10 of 11 Old 10-12-2012, 10:52 AM
krutj
2009 JK Wrangler
Nothing fancy, just remove the grill and run the wires, very easy. No cutting of anything, except the tails from the zip ties..lol
-- Joel --
krutj is offline
post #11 of 11 Old 10-12-2012, 07:49 PM
JTPhoto
JTPhoto's Avatar
Take the side panel off the dash. Look inside to the firewall and you will see a button of tan foam insulation. Push a stiff wire (wire coat hanger) through the insulation, tape your lighting wires to the stiff wire and pull it back through the insulation.
Daystar makes a nice 4 switch panel that replaces the lower dash panel behind the shifter.
^^Jeff^^
JTPhoto is offline
