Aux Light Questions - JeepForum.com
post #1 of 19 Old 07-12-2013, 01:23 PM Thread Starter
Thornton93
2009 JK Wrangler
Aux Light Questions
I'm thinking about getting a pair of the Ridgid Duallys and mount them on the windshield and possibly a bar for my bumper. I hear people using the sPod and the dBox5 for all there aux lighting and accessories. I really don't have the budget for the sPod is there any other products similar but for a lower price?
Thanks,
Kyle
Thornton93 is offline
post #2 of 19 Old 07-12-2013, 02:13 PM
TheMercenary556
I use the Rugged Ridge A-Pillar switch pod and love it
http://www.quadratec.com/products/97015_0112.htm
TheMercenary556 is offline
post #3 of 19 Old 07-12-2013, 02:33 PM Thread Starter
Thornton93
2009 JK Wrangler
How do you run your wires for the switchs?
post #4 of 19 Old 07-12-2013, 02:42 PM
TheMercenary556
If you pop the side pannel off your dash you will see a foam filled hole that runs into the engine compartment just above the trail rated badge, a coat hanger pushed through the foam with a hook on the end makes wiring a breeze.
post #5 of 19 Old 07-12-2013, 02:47 PM
TheMercenary556
post #6 of 19 Old 07-12-2013, 03:07 PM Thread Starter
Thornton93
2009 JK Wrangler
But here's the thing I don't want to keep pulling the switch panel off if I decide to run more accessories I want power to the switchs at all times like what u can do with the sPod and dBox5.
post #7 of 19 Old 07-12-2013, 03:19 PM
CJsPerson
I used a Daystar switch panel. I ran all switches at one time and dead ended to ones I donít use yet on the other side of the fire wall. So if I add anything new Iím not going in the dash again.
Never trust a happy man
I off road because I have a Jeep. I don't have a Jeep because I off road. Above all my Jeep is a convertible. That's where my love is for the brand ...convertible overkill
CJsPerson is offline
post #8 of 19 Old 07-12-2013, 03:22 PM
TheMercenary556
Well I can't help you with that, It took me less than a hour to add a set of lights to the A-pillar pod, I guess if you really need that kind of convenience your only option I know of is to spend the coin. If it were me I would rather spend a little more time wiring and put the extra money towards your lighting, but YMMV
post #9 of 19 Old 07-12-2013, 04:39 PM Thread Starter
Thornton93
2009 JK Wrangler
Is there any type of promo code or coupon for the ridgid lights?
post #10 of 19 Old 07-13-2013, 01:24 AM
nam1
2010 JK Wrangler
I see the convenience of the spod but I learned a great deal about wiring by building it myself. I bought the RR A-pillar and wired it into a waterproof box. All circuits are switched and relayed. Pretty simple to wire things in without having to go back to the dash and I was able to clean up a whole lot of wiring. All of the materials and tools that I bought were probably more than what it would have cost to purchase the spod but the knowledge I gained by doing it myself was worth much much more.
I used this mainly for reference.
http://www.jeepforum.com/forum/f96/h...panel-1076574/
________BOOM________
nam1 is offline
post #11 of 19 Old 07-13-2013, 06:33 AM
mello
I also used rugged ridge a-pillar switch panel and pre wired up all my switches. However I did not want power to go to them so I used them as a ground side switches to control relays for my accessories. I ran the wires through weather pack connectors just inside firewall so I could disconnect them if I had to remove dash or diagnose a wiring problem with my accessory circuits.
mello is offline
post #12 of 19 Old 07-13-2013, 06:36 AM
Vin
If you are looking to do what an sPod does with the Rugged Ridge, Daystar, or even if you put a bunch of switches above your speaker, then you need to mount and wire a bunch or relays/fuses in your engine bay. When the time comes to add an accessory, you would power them from the relay. It's really not rocket science. The sPod makes it nice and neat, but it can be duplicated if you understand automotive electronics.
Vin is offline
post #13 of 19 Old 07-13-2013, 07:03 AM Thread Starter
Thornton93
2009 JK Wrangler
I'm not the best with electrical
post #14 of 19 Old 07-13-2013, 07:17 AM
xSoFx
1987 XJ Cherokee
A little bit of research goes a long way, that sPod sure is a neat $450 gadget. Anyone with a brain and spare time could do that for less than $100.
xSoFx is offline
post #15 of 19 Old 07-13-2013, 07:24 AM
jmb6420
Engr. & Mechanic 08 Rubi
jmb6420's Avatar
I did the same in my 08. I've used three of the switches now and the forth is getting hooked up this weekend. Ran all the wiring at one time, hooked up all the switches and grounds and dead headed the ones not used at the time. It really makes adding things later much easier and quicker.
Mike
08 Rubicon
"You can't fix stupid" Ron White
°ɹǝʌo ǝɯ dıןɟ 'sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
jmb6420 is offline
