Automatic JK Transmission Problems POLL - Page 4 - JeepForum.com
View Poll Results: Are you having a problem with your JK Automatic?
I have NO problems, my transmission works great 278 90.55%
I am starting to have problems requring a visit to the dealer 15 4.89%
My transmission is a constant problem and has already been to the dealer 14 4.56%
Voters: 307. You may not vote on this poll
post #46 of 93 Old 11-11-2009, 10:07 AM
DBA2GO
40k miles, no problem w/ auto trans; but I've re-geared to 5.13 w/ 35s & used HyperTech to correct tire size & gear ratio. I don't know if that helped my auto trans to work better or not; but I think it works great.
On another note, when my TC locks up, and I want to accelerate w/o mashing the skinny pedal, I usually just disengage the cruise control & then I can squeeze the skinny pedal and accelerate...
Looks like the no problems is almost 95% on the poll now.
One foot in the grave & one foot on the gas pedal!!
DBA2GO is offline
post #47 of 93 Old 11-11-2009, 10:37 AM
Nuts
2009 JK Wrangler
18,000 and no problems here
Nuts is offline
post #48 of 93 Old 11-11-2009, 12:01 PM
juiceparn
35,000 and more than half of that is on 35's, and not a problem 1. 07, 4.10 gears and on 35's.
07 JK 4DR 3.5" Rubicon Express, C gussets, Front XHD stubby, winch, Taboo Customs rear bumper with tire carrier, Taboo Customs Rock sliders.
juiceparn is offline
post #49 of 93 Old 11-11-2009, 07:40 PM
MarcM
40k miles on my JKL Rubicon. No issues with the tranny.
MarcM is offline
post #50 of 93 Old 11-11-2009, 07:42 PM
jeb3
just turned 40k on my 07 Sahara, never had a problem with anything.
jeb3 is offline
post #51 of 93 Old 11-11-2009, 08:04 PM
s1edneck700
22k. Shudders from 1st to 2nd when cold. Starting to give vibration at tc lock up when feeding it in 3rd or 4th. Going straight to the dealer tomorrow before the 35's go on. Why me....
s1edneck700 is offline
post #52 of 93 Old 04-18-2012, 11:16 AM
skinnylemur
2010 JK Wrangler
Already had problems with the transfer case seals (with only about 10K on it). Just yesterday my wife couldn't get it to shift from park (had to get an automatic because the wife didn't want to learn to drive standard). We only have 26K on it now...
Worst part? All my tools are 400 miles away, and the dealerships tell me it will be a week before they can even look at it. FML
skinnylemur is offline
post #53 of 93 Old 04-18-2012, 11:47 AM
LVCapo
2015 JK Wrangler
Occasionally tranny will slip while accelerating.....after doing this it will lock in that current gear and wont shift until I pull over and turn off the engine.
Has been to the stealership twice (for two days both times) and they say they cannot find any issues or recreate the problem.
LVCapo is offline
post #54 of 93 Old 04-24-2012, 10:47 PM
cmashark
2016 JK Wrangler
2011 2 door. Almost a year old. Has 3,500 miles. Can't disengage overdrive with the button. Jeep is at the local dealer waiting to be fixed... Kinda sucks, but I am glad I am having my issue while it is still stock....
2016 75th Anniversary 2 door Wrangler
2013 CVO Road King
cmashark is offline
post #55 of 93 Old 04-24-2012, 10:53 PM
73azbronco
Don't take this the wrong way but I found if you use the remote start it won't shift out of park until you insert the key and tunr key to on, then you can shift.
73azbronco is offline
post #56 of 93 Old 04-25-2012, 08:38 AM
222Doc
222Doc's Avatar
So no one drives off in it.
222Doc is online now
post #57 of 93 Old 04-25-2012, 08:56 AM
mikeinminn
70000 miles no mine. No problems.
mikeinminn is offline
post #58 of 93 Old 04-25-2012, 09:20 AM
countrybassist
2011 JK Wrangler
11k and no problems.
countrybassist is offline
post #59 of 93 Old 04-25-2012, 09:57 AM
jstrubberg
2009 JK Wrangler
45k, zero problems.
TBH, other than some problems with the stock trans cooler, I haven't heard of any issues with the JK tranny. We all wish we had the new 5 speed, but the 42RLE does a good job.
jstrubberg is offline
post #60 of 93 Old 04-25-2012, 10:07 AM
DBA2GO
86K miles & no problemo with the trans. I had the "hot trans" light come on several times over the years; so, I installed a secondary trans cooler. That works great & no more "hot trans" light. Hopefully that really means that the trans fluid is not as hot as it used to be.
DBA2GO is offline
Electrical Problems After Water in Automatic Transmission: 42 RLE TheMasterChief TJ Wrangler Technical Forum 15 05-07-2009 08:27 AM
2004 Jeep Wrangler SE 2.4L Automatic - Transmission Gear Problems? ChrisF84 TJ Wrangler Technical Forum 4 08-17-2008 06:51 PM
What transmission do you have, wiki data poll!!! rustywrangler YJ Wrangler Technical Forum 22 12-03-2007 04:23 AM
Automatic Transmission problems. 4wheel4real TJ Wrangler Technical Forum 15 07-25-2007 10:45 AM
automatic transmission midnight TJ Wrangler Technical Forum 8 03-09-2003 08:10 PM
