Automatic Hot Oil Problem - JeepForum.com
post #1 of 3 Old 10-15-2011, 12:02 PM Thread Starter
jft99Wrangler
2010 JK Wrangler
I recently bought a 2010 Sport (automatic) after a few years of owning a TJ. I've enjoyed the Jeep so far and just recently started to make a few minor cosmetic mods. I was searching the forums for a few things, and saw a number of alarming posts about automatic transmissions overheating pretty easily while off-roading. I don't do any serious off-roading at this moment since the Jeep is my DD, but I'm a little concerned that people had their trans. overheat with light off-roading (logging trails), which I primarily do. Is this a big problem or just isolated to a handful of Jeeps? I don't want to dump a lot of money into the Jeep and then have to worry about the tranny burning up every time I go off-road. I know I can get a trans. cooler, but I've heard it voids the warranty. I also read some of the tips about using 4-Lo, turning off OD, etc.
jft99Wrangler is offline
post #2 of 3 Old 10-15-2011, 12:25 PM
ronjenx
ronjenx's Avatar
It's 4hi uphill or on sand that overheats the transmission the quickest.
There are several things you can do.
Install an additional transmission cooler.
Use 4lo, O/D off, transmission in "D", as much as possible.
Install a transmission temp gauge so you can keep an eye on the temp and take action before it overheats.
Your best bet is the cooler.
ronjenx is offline
post #3 of 3 Old 10-16-2011, 07:45 AM
cidd
If your worried about it just throw a cooler in takes 1 hr and about $50 - $75 cheap and easy mod and itll save your tranny.
cidd is offline
1993 yj 4.0 ho automatic problem Perturabo YJ Wrangler Technical Forum 3 03-19-2009 12:38 AM
Automatic tranny problem cj847 TJ Wrangler Technical Forum 3 11-25-2007 07:18 AM
99 Automatic transmission problem jeepgirl1272 TJ Wrangler Technical Forum 8 12-11-2006 08:08 PM
Automatic shifting problem dr200059 TJ Wrangler Technical Forum 0 09-30-2004 05:16 AM
3 speed automatic problem bende030 TJ Wrangler Technical Forum 2 04-06-2004 05:42 PM
