Auto Tranny skips a gear when downshifting - JeepForum.com
post #1 of 11 Old 10-25-2015, 06:29 AM Thread Starter
HappyTrails
HappyTrails's Avatar
Recently, I have had auto tranny problems.
If I am cruising along in OD (4th gear) and I press the gas enough to try to get it to downshift, it momentarily downshifts to 2nd gear (revs almost to redline), then shifts into 3rd gear. The same thing happens if I am in 3rd and need 2nd (it goes to 1st gear).
The only solution I've learned is to let off the gas for a moment, then step on the gas, or to push the overdrive OFF button while I have my foot off the gas.
This is NOT right. Something has changed. It used to downshift into 3rd/2nd smoothly.
I have checked the transmission fluid level recently.
Any ideas, oh JK Jedi's?
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel, Rancho 9000XL shocks, 37" Nittos, 5.38's, RR skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
Political Correctness offends me.
HappyTrails is offline
post #2 of 11 Old 10-25-2015, 06:38 AM
Neo1130
2015 JK Wrangler
Try resetting the computers by removing the battery cables for a bit? Other than that, I had mine start acting up once like that. A few days later, I was out in the middle of nowhere and it would start to slip out of whatever gear it was in. Then went into limp mode...
I had to limp it a few miles to get a cell signal and get closer to home... Well, it was stuck in 3rd gear (I think that's the limp gear) and kept slipping if I went higher than 30 MPH... Turns out my torque convert and valve body somehow went at the same time. I dunno if one took another out or what... But I ended up having to rebuilt the trans. If resetting doesn't help, then I'd take it to a trusty trans shop before it turns into a total rebuild. If I were in town when mine happened, I would have called a tow truck and would have been about half the cost of what I spent. All my clutches were fried from the slipping as well...
Neo1130 is offline
post #3 of 11 Old 10-25-2015, 07:42 AM
JIMBOX
Oh Oh, sorry HT, Mine hasn't done anything like that-
Remember how we've learned that the ECU is "trainable"/"relearnable" ?
Could be the additional SC load on the TQ/tranny has changed the programing without digital influence-
You may have to visit the dealer for OBD11 trouble shooting-
Good luck
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #4 of 11 Old 10-25-2015, 02:18 PM
1222
RIP John
1222's Avatar
That brings back memories. My ’08 JKRU would do the same thing at times, I just figured it was normal. I sure didn’t like it but figured there wasn’t much I could do about it. I wonder now.
(2011-2016)
1222 is offline
post #5 of 11 Old 10-26-2015, 01:26 PM Thread Starter
HappyTrails
I'll try the battery disconnect first.
If that doesn't work, to the stealership it goes.
After that, some serious "drunk sailor cussing", and then to the transmission shop.
Thanks guys!
post #6 of 11 Old 10-26-2015, 01:37 PM
JIMBOX
Good luck--HT
Thanks guys!
JIMBO
Yellow Jeep No. 683
JIMBOX is offline
post #7 of 11 Old 10-26-2015, 03:00 PM
duneslider
Mine used to do that a lot and years ago I got a flash at the dealer and it seems that it hasn't done it since then (that I recall anyway). I only have the issue occasionally though, not all the time and it was more likely to happen when I mashed the pedal. I have kind of learned to roll it on and I get better response from the whole beast.
I really don't know/think that the transmission programming on these is that wonderful.
duneslider is offline
post #8 of 11 Old 10-27-2015, 06:42 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
Hey HappyTrails,
TSB 21-018-08 REV. A may relate to your vehicle:
SUBJECT:
Flash: Diagnostic Trouble Code DTC P0740 Or P1798 And Automatic Transmission Shift
Improvements 1-2 Or 2-3 Cold Shift Improvements
OVERVIEW:
This bulletin involves selectively erasing and reprogramming the Powertrain Control
Module (PCM).
MODELS:
2008 (DR) Ram Truck
2008 (HB) Durango
**2007** - 2008 (JK) Wrangler
2008 (KA) Nitro
2008 (KA) Nitro (International Markets)
2008 (KK) Liberty
2008 (KK) Liberty (International Markets)
2007 - 2008 (LE) 300C/300 Touring (International Markets)
2007 - 2008 (LX) 300/Magnum/Charger
2007 - 2008 (ND) Dakota
NUMBER: 21-018-08 REV. A
GROUP: Transmission
DATE: September 17, 2008
NOTE: This Bulletin applies to LX/LE models equipped with a 42 RLE transmission
(Sales Code DGV) built before April 28, 2008 (0428XXMDH). This Bulletin
applies to all 2008 KA/KK/HB/DR and 2007 - 2008 **JK**/ND vehicles
equipped with a 42 RLE transmission (Sales Code DGV).
SYMPTOM/CONDITION:
The software contains the following improvements:
· 2008 LX 3.5L 1-2 Shift Improvements
· Cold (Transmission Fluid below 80° F) 2-3 Shift Improvements
Let me know if you have any further questions.
JeepCares is online now
post #9 of 11 Old 10-28-2015, 09:27 PM Thread Starter
HappyTrails
Originally Posted by JeepCares View Post
Hey HappyTrails,
SUBJECT:
OVERVIEW:
Module (PCM).
MODELS:
2008 (DR) Ram Truck
2008 (HB) Durango
2008 (KA) Nitro
2008 (KK) Liberty
GROUP: Transmission
SYMPTOM/CONDITION:
THANK YOU! I will contact my local dealer to look into this. Hopefully this beats a transmission rebuild.
post #10 of 11 Old 10-30-2015, 08:26 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
Hey HappyTrails,
No problem, I am glad I was able to supply you with a useful TSB. If you have any further questions, please don’t hesitate to reach out again.
post #11 of 11 Old 11-07-2015, 05:24 PM Thread Starter
HappyTrails
Okay, aftermath report....
Today I disconnected the battery for about 10 minutes. Then took it into town. Looks like that worked! Downshifts are smooth and easy.
However, I did not really step on it.
Small steps...
If it gives me problems next time, to the dealer it goes for the re-flash!
