Auto shift column not illuminated? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Auto shift column not illuminated?
New rockridge 4wd sales rep!!!FS: Wranger BRIGHT License Plate LED! Just $3! Great valueTJ BDS 2" suspension lift!! FINALLY a GREAT 2" l
Unread 10-23-2013, 06:34 AM   #1
quadna71
The shift pattern (P R N D and - +) doesn't illuminate on the center shifting column either with the lights off or on. The dash does show the digital readout to say what gear you're in. Are the ones on the shift column supposed to illuminate? Seems odd to me that they don't.
2013 JKU Sahara, automatic.
2013 JKU Sahara - ours
2001 TJ SE - hers, 2001 XJ Sport - ours
2003 TJ Sport - sold, 2000 TJ Sport - sold
1993 XJ Sport - totaled, 1987 XJ Laredo - sold
1987 XJ Chief - sold, 1953 CJ-3B - sold
quadna71 is offline   Reply With Quote Quick reply to this message
Unread 10-23-2013, 07:51 AM   #2
RogueStatus
nope, mine dont light up at all.
Jeep-less again
RogueStatus is offline   Reply With Quote Quick reply to this message
Unread 10-23-2013, 08:35 AM   #3
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
No need for indicator in the console - its in the dash display. They don't light up for this reason.
J Wm Bishop EA, ASADE
I'm cured, I'm CURED - My psychiatrist said there is nothing more he can do for me!!!
jwmbishop is online now   Reply With Quote Quick reply to this message
Unread 10-24-2013, 06:29 PM   #4
Jiblet
Mine do! 2008
Jiblet is offline   Reply With Quote Quick reply to this message
Unread 10-25-2013, 11:50 AM   #5
quadna71
So somewhere between '08 and '13 things changed. Might be time to pop it all open and see if the harness is there and just needs to be tapped in to. Thanks.
Unread 10-25-2013, 12:29 PM   #6
jwmbishop
jwmbishop's Avatar
2011 JK Wrangler
Originally Posted by Jiblet View Post
Mine do! 2008
does an 08 show the selected gear on the dash?
Unread 10-25-2013, 01:01 PM   #7
Jiblet
Yes, has both.
Unread 10-25-2013, 03:16 PM   #8
zjilla
Im pretty sure my 07 does
Sent from my GT-N7000 using JeepForum
2007 Unlimited Sahara
98 ZJ Limited RHD (British spec)
USAF Military Working Dog Handler
www.annirlane.blogspot.com
October 2013 JK of the month
My Slowly but surely JK build thread:
http://www.jeepforum.com/forum/f96/s...hread-1562595/
zjilla is offline   Reply With Quote Quick reply to this message
Unread 10-25-2013, 05:03 PM   #9
jwmbishop
jwmbishop's Avatar
2011 JK Wrangler
Wonder which year they decided the extra 5.00 per vehicle was no longer necessary...
Unread 10-25-2013, 05:22 PM   #10
Ruby_Tuesday
My 12 lights up at the shifter
Ruby_Tuesday is offline   Reply With Quote Quick reply to this message
Unread 10-25-2013, 07:43 PM   #11
Psycho-X-Jeep
2009 JK Wrangler
My 09 does not light up on the shifter.
I did have a similar question. If anyone has auto windows, do the top two switches light up? It looks like there is a tiny space in there for a little light, but they aren't lit up. Everything on the das is pretty easy to see at night except the window switches.
Call me Eddo
09 JKUR - Daily Driver... Prob not for long!
06 Nissan Xterra... Too many mods to list
Psycho-X-Jeep is offline   Reply With Quote Quick reply to this message
Unread 10-25-2013, 08:19 PM   #12
Jiblet
My power window switches have tiny pinhole lighting in the switch. I wish the door handles did! (time to figure out a mod for that)
I seem to remember some thread somewhere about trying to change the little LED in the power window switch. Can't remember if it was possible or if the whole switch had to be replaced.
I'd bet there is an LED inside the shifter console for those whose shifter doesn't light up. Loose connection or bad led.
Unread 10-25-2013, 09:01 PM   #13
Psycho-X-Jeep
2009 JK Wrangler
Dang so my lights are out in my window switches. I have a wild hair in my bu++ right now, so I will tear the dash & console apart to see what I can find
Now that i think about it, I do remember someone posting about an empty connector under the shifter condole not too long ago. I think it was a guy with a manual, and the best guess at what it was for was the overdrive button... I think we might know what it is now!!
Call me Eddo
Unread 10-26-2013, 05:18 AM   #14
drmad7
I've had my '13 since April and I JUST noticed the darkness of the shifter last week. I mentioned it to my wife thinking a wire was lose or something! I do remember my '08 having the shifter letter lit. Wow. I can't believe they been dark all this time and I just suddenly noticed that!
'13 10th Anniversary Rubicon Unlimited..Auto and EVERYTHING but ashtray!
'13 Crush Sahara JKU (replacing w/10A Rubicon???)
'08 Rescue Green Sahara 4dr- Auto and EVERYTHING but ashtray and engine block heater. (GONE)
drmad7 is offline   Reply With Quote Quick reply to this message
Unread 10-29-2013, 06:19 AM   #15
2013CG-JKU
Mine lights up - 2013 Sahara Unlimited
2013CG-JKU is offline   Reply With Quote Quick reply to this message
