Auto to manual tranny swap info - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Auto to manual tranny swap info
IRON CROSS Jeep JK Front and Rear STUBBY BUMPERS IN STOCK Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Jeep speedometer gears at rockridge4wd
Unread 11-02-2011, 03:08 PM   #1
deftones07
2011 JK Wrangler
I really am considering swapping my 2011 JK tranny from an auto to a manual. I just need a manual and trading it in for a new wrangler would end up costing me tooo much, even though i wouldnt mind having the new engine.
so i found a manual trannys and am just wondering what is all the parts i would need for the complete conversion. hopefully make a bit of money off sellin my auto tranny aswell. any info is greatly appreciated.
I also have someone that could help me do the swap for a case of beer, so i ill be doing it myself with him.
thanks,
deftones07 is offline   Reply With Quote Quick reply to this message
Unread 11-02-2011, 03:25 PM   #2
jstrubberg
2009 JK Wrangler
Uh, good luck.
You are talking about a major change here. This isn't a shade tree mechanic job. You're going to have to change out the tranny, the driveshaft, install the clutch controls, change the electronics and hope the damn thing will even start when you are done.
You don't need a manual, you want one. I hope you want one enough to go through what you're talking about.
jstrubberg is offline   Reply With Quote Quick reply to this message
Unread 11-02-2011, 03:28 PM   #3
5foot19
2011 JK Wrangler
you sure it wouldn't be cheaper to trade it in?
5foot19 is offline   Reply With Quote Quick reply to this message
Unread 11-02-2011, 03:36 PM   #4
Rdlynch2
Why do you want to go auto to manual, shouldn't it be the other way around?
Wheeling is a LOT easier with an auto.
I would kill to have an auto with 5.13 gears and 35's!
08 JK/6 speed/2 Door/soft top--35x12.5x17 GY MTR's--ATX slot's--R.K. Stock Mod--Smittybilt rocker guards--PSC evap skid--PSC tramp stamp--Hella 500 black magic's--RK drag link. Pure Jeep axle knuckle/gusset kit.
Rdlynch2 is offline   Reply With Quote Quick reply to this message
Unread 11-02-2011, 03:38 PM   #5
1AAdam
def not. the new manuals work with the electronic throttle mostly for 'normal person' driveability and i have seen a few posts on here complaining about it. i would think they are completely different harness and ECM. lets try looking at it this way, why do u need a manual transmission? i like them just cause i like to shift and i think it's something of a dying breed.
Adam
1aauto.com
888-844-3393
1AAdam is offline   Reply With Quote Quick reply to this message
Unread 11-02-2011, 03:39 PM   #6
1AAdam
ha! i was going to say this too. it's a lot easier to pre-load the drive train if u are in a tricky spot.
Adam
1aauto.com
888-844-3393
Unread 11-02-2011, 03:54 PM   #7
deftones07
2011 JK Wrangler
well i guess it probably is too hard to do lol. im going to lift my jeep and put 33 or 35s on it, just feels like it has not enough guts in it to carry those. would you suggest getting it re-geared then?
Unread 11-02-2011, 03:57 PM   #8
1AAdam
yah thats the best thing to do when u increase tire size. once u do that u may want to put a superchips on it and it will prob run a lot better than u think. i did some short research online and auto is the way to go off-road. pro rock crawlers use CVT in their rigs! one used the saturn 4 cyl through a CVT straight into the trans case.
Adam
1aauto.com
888-844-3393
Unread 11-02-2011, 04:04 PM   #9
deftones07
2011 JK Wrangler
Superchips is a good idea was thinking the same. now for gearing what would you suggest for 33s and 35s. I would like 35s on it for obvious reasons but most likely going 33s as this is my daily driver and its not the best on vehicle on gas.
Unread 11-02-2011, 04:06 PM   #10
jstrubberg
2009 JK Wrangler
Regear, definitely. 4.88s for 33s or 5.13s for 35s.
Unread 11-02-2011, 04:07 PM   #11
1AAdam
if u re-gear u aren't going to get super mileage. ur actually going to re-gear so the engine can turn more which will burn more gas. people who have re-geared can tell u what they have and what kind of mileage they are getting.
Adam
1aauto.com
888-844-3393
Unread 11-02-2011, 04:12 PM   #12
deftones07
2011 JK Wrangler
yeah my jeep right now wont be able to handle it and would most likely burn more tryin to spin those wheels. i can live with the lower mileage for the better looking jeep anyone regeared to 4.88s ? let me know thnx
Unread 11-02-2011, 04:20 PM   #13
1AAdam
yah i u lifted without re-gearing u would pretty much be using the same amt of extra gas pedaling it to get it to go if not more.
Adam
1aauto.com
888-844-3393
Unread 11-02-2011, 04:20 PM   #14
JTPhoto
JTPhoto's Avatar
Not true with the 3.8 auto. With bigger tires it will get better mileage running 22-2500 rpm then it will running 1700rpm and kicking in and out of OD on every little incline or gust of wind.
No matter how you look at it your mileage will drop as soon as you put bigger/heavier tires on.
There is no programmer available at this time for the 2011-12 that can tune the motor.
^^Jeff^^
2008 Black and Khaki Sahara Unlimited. Auto, Tow pkg, Dual Tops, MyGig, Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, 35x12.50x17 Pitbull Rockers on Blackrock Viper Alloys, Flex-o-lite trans cooler, Mr Grille billet grille inserts, AEV Prem Bumper ETC.. AND a Locked and Lifted Honda Foreman for when the trails get real tight
JTPhoto is offline   Reply With Quote Quick reply to this message
Unread 11-02-2011, 05:26 PM   #15
JIMBOX
Running the auto is Ss great for on-road/off-road/towing and
If your going to pay to have your diffs regeared--go 5.13s, then you'll get better mileage and the O/D will stay locked MOST of the time-with 33s
If you had a Rubi you could go 5.38s and thats pure heaven !
Then an AEV Procal Module for your speedo and you're all set !
Changing from auto to stick in an 07 thru 12 is not even manageable-
JIMBO
Yellow Jeep No. 683
http://i294.photobucket.com/albums/m...10-snow027.jpg
--YA GOTTA HAVE CLASS--
JIMBOX is offline   Reply With Quote Quick reply to this message
