Auto lock - JeepForum.com
post #1 of 6 Old 12-16-2006, 07:44 AM Thread Starter
Timster32
Auto lock
When I first bought my JK the doors would lock automatically when I began to drive. This feature does not happen anymore and im not sure why or what I may have done to change it. The only thing I could think of is I held the speedo reset while turning the ignition on to see if it worked like my old TJ where it accessed the diagnostics. Any thoughts would be much apreciated.
P.S. I know a lot of people dont like the auto lock feature but I thought it was pretty cool
Timster32 is offline
post #2 of 6 Old 12-16-2006, 01:21 PM
Diesel0312
Did you see this in the FAQ?
"The auto door-locks are driving me crazy. How do I make them not automagically lock the doors? - Shut the doors and turn the key from "off" to "on" (stop turning the key at the point just before the engine starts). Do this five times. On the fifth time the key should be in the "on" position, push up on the power door lock.
To set for all doors to unlock together, follow the same proceedure, except press up on the power door lock 2 times."
Might try the second one and see if that will cause the doors to start locking again. I like it because when you open the door, all doors unlock. Makes it much handier since I usually have something to go around and get out of the passenger seat or the back seat.
2007 Jeep Wrangler Sahara Unlimited
Factory: Silver w/ black soft top, 18" wheels, auto
Mods: Windshield mounted Hella FF1000 driving lights, Rugged Ridge front grab handles, CLC rear grab handles, Teraflex 2.5" BB, Quadratec boor handle covers, Bestop spare cover, Custom front bumper, 17X9 Pro Comp 1079's, 305/17/R17 Buckshot Mudders.
In the works: Custom rear bumper.
Diesel0312 is offline
post #3 of 6 Old 12-16-2006, 04:54 PM
madelko
Auto Locks re-set...........
I just had to try the auto-lock disable, then was sorry I did it.
To get it back, I did the key thing five times, then pushed down on the door lock/unlock button two times, holding it for about three seconds the second time. They now 'auto-lock' again.
madelko is offline
post #4 of 6 Old 12-16-2006, 05:59 PM
gsgreg
how did you turn them off? I tried the key trick and it didn't work.
Greg
gsgreg is offline
post #5 of 6 Old 12-16-2006, 06:12 PM
madelko
Auto Unlock
Do the key thing five times, then press the door switch up two times. Make sure you hold the switch up for at least a second. - a slight pause between the first and second move worked for me - then I held the switch up for about two seconds the second time.
This didn't work the first time, but did when I re-tried it.
I read somewhere that you have to start by getting in the vehicle, close the door, then do the proper sequence to make this change.
madelko is offline
post #6 of 6 Old 12-16-2006, 09:12 PM Thread Starter
Timster32
Thanks for the replys. I tried the twice down thing and hold for three seconds on the second one and it worked like a champ. Thanks very much
Disabling the door auto-lock feature MichaelW JK Wrangler Technical Forum 13 06-08-2014 12:08 PM
Auto door lock/unlock issue with JK Captain56 JK Wrangler Technical Forum 21 01-11-2011 11:26 PM
D44 to lock or not to lock(Auto Locker) MCJeeper YJ Wrangler Technical Forum 7 02-07-2008 02:31 PM
flippin auto door lock... rwmjeepjk JK Wrangler Technical Forum 2 03-18-2007 09:06 AM
Auto OD lock out TJLAND TJ Wrangler Technical Forum 3 06-24-2006 05:48 PM
