auto door locking - Page 3 - JeepForum.com
post #31 of 38 Old 11-05-2006, 04:44 PM
Scooter_Trash
Originally Posted by NaeKid
I have just changed the FAQ to reflect the Key/Lock sequence. Can someone who has tried it please confirm the information?
Thank you
The auto door-locks drive me crazy. How do I make not automagically lock the doors? - Shut the doors and turn the key from "off" to "on" (stop turning the key at the point just before the engine starts). Do this five times. On the fifth time the key should be in the "on" position, push up on the power door lock.
To re-enable, follow the same proceedure, except press up on the power door lock 2 times.
Look's good except that I believe if you press up once it shuts the whole feature off. If you press up twice, the auto lock is still on but opening the drivers door will unlock all four doors at the same time. I'm not sure how you can return it to stock since I haven't played with it. I got it to do what I wanted and stopped for fear of not finding my happy place again.
From what I understand you can also take it to the dealership and they can configure it to do exactly what you want via the computer.
Good luck, Rich
Scooter_Trash is offline
post #32 of 38 Old 11-05-2006, 08:07 PM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
Good luck, Rich
Thank you for that extra note. The FAQ now says:
Originally Posted by FAQ
The auto door-locks are driving me crazy. How do I make them not automagically lock the doors? - Shut the doors and turn the key from "off" to "on" (stop turning the key at the point just before the engine starts). Do this five times. On the fifth time the key should be in the "on" position, push up on the power door lock.
To set for all doors to unlock together, follow the same proceedure, except press up on the power door lock 2 times.
Does this seem a little better? Also, would pressing down on the power-lock once set the auto-magics to work again?
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #33 of 38 Old 11-05-2006, 09:49 PM
Diesel0312
Awesome, that's one thing my truck did that I really miss on the jeep. Will be able to change that tomorrow.
Diesel0312 is offline
post #34 of 38 Old 11-10-2006, 10:35 PM Thread Starter
csmith46
thanks
since I posted the original question I thought a thanks to all for the help was in order. I got it set up so that it still auto locks but when I open my door all the doors unlock at the same time. That is perfect for me. Thanks again
csmith46 is offline
post #35 of 38 Old 12-17-2006, 01:19 AM
Ventura911
Ventura911's Avatar
Well, I went out and tried this and successfully disabled the autolock feature. Unfortunately, that wasn't my intention; I wanted to set it to unlock all four doors when I open the driver's door, as mentioned above.
Now I'm unable to get autolock enabled, let alone set it up like this. A few questions:
1) How do I enable the autolock again? (I'll be double-checking my manual tomorrow, but I didn't see anything about it.)
2) When ready to follow the steps listed above, are the doors supposed to be locked or unlocked when I start?
3) When I cycle the power lock switch, do I unlock twice, or do I unlock, lock, unlock? (Or some other variation?)
Thanks!
Ventura911 is offline
post #36 of 38 Old 12-17-2006, 10:51 AM
Scooter_Trash
Well, that's a first.
1) If you remember the steps that you did, I would imagine doing the exact steps again will enable them.
2) The doors were unlocked when I did it.
3) I pushed it up (unlock) twice, but since then some others have said that it didn't matter because it worked for them and they only did it once.
Hope that helps, and good luck. And if all else fails I'm still pretty sure the dealer can set the locks to do what you want.
post #37 of 38 Old 12-17-2006, 11:18 AM
Ventura911
Ventura911's Avatar
I'm known for firsts like that!
Thanks for the info.
post #38 of 38 Old 12-17-2006, 10:32 PM
Ventura911
Ventura911's Avatar
Well, I ran through variations of these steps and somehow 1) got the autolock to work and 2) got the doors to unlock together.
While I had some difficulties, they weren't caused by the instructions provided. Thanks for the help, FireMedicXL
Questions about Half Door and Full Door Locking Mechanisms... atticus_ar TJ Wrangler Technical Forum 8 12-04-2009 02:26 PM
Locking door lugs? Deadhorse TJ Wrangler Technical Forum 10 06-04-2009 12:17 PM
auto door locking sportman JK Wrangler Technical Forum 6 01-04-2008 09:30 AM
Locking the D30... selectable or auto? Ryuu600 TJ Wrangler Technical Forum 5 11-21-2006 01:19 PM
Where to get door locking mechanism... seanw YJ Wrangler Technical Forum 1 01-24-2004 11:41 AM
