Auto Dimming Mirror with Homelink - JeepForum.com
post #1 of 9 Old 02-26-2009, 07:40 PM Thread Starter
Expat_J33P_Fan
Just in case anyone is thinking of fitting an auto dimming mirror I wanted to share my (positive) experience and add some pointers.
I bought a Gentek 50-GENK41A off ebay for $169 inc S&H which provides the auto dimming and the garage door/gate opener functionality only. The '08 X has temperature and compass on the EVIC so no need to spend extra for that.
Fitting was easy - it is a direct replacement physically for the existing mirror and just needs a torx driver to remove and refit. Running the cable doesn't require too much effort as it just slips under the trim - I ran mine down the left had side (driver side) and dropped it out by the footwell.
With this mirror there are three connections, a constant live for the homelink, ignition live for the auto dimming, and a ground.
The constant live I piggy backed off the red wire on the diagnostic port connector which is +12v. No problem as the door opener takes very little current and is only operated when the button is pressed. The Ground connection is to the left of that and requires a 10mm socket to remove and replace the nut with the "install ready lug" slipped over the threads.
As for the ignition hot feed, that was more challenging since the actual ignition key doesn't appear to have anything over 5v (ie all signal wires = LEAVE ALONE) - best place I found was the violet/red on the back of the unmarked cigar lighter which is +12v when the ignition is on. Getting to it involves a bit of effort though.
You need to remove the center top dash panel (careful of the compass wires) then remove the two 7mm nuts underneath. Then remove the lower trim panel by the transfer lever (moving to 4L helps with access) and remove the other two 7mm nuts securing the bottom of the center panel. Gently pull it forward. Routing the cable is fairly straight forward along the inner lower edge of the dash below the steering wheel. The supplied cable was about 2 inches short so I made up a small extension cable with male/female spade connectors and a bit of spare wire.
Testing/setting up Homelink is as per the supplied instructions which are again very straight forward.
All in all it looks factory standard (I suppose it is on the Sahara/Rubicon!) Either way looks way better and adds useful functionality - so money well spent.
Expat_J33P_Fan is offline
post #2 of 9 Old 02-26-2009, 07:59 PM
GNNR
2009 JK Wrangler
Good stuff! This is a mod on my short list for the spring in fact. Thank you.
GNNR
GNNR is offline
post #3 of 9 Old 02-26-2009, 08:07 PM
elfamiglia
That is great to know. I want one with compass since my '09 X only has the temperature on EVIC.
Have you found whether the mirror vibrates under acceleration? I bought a similar Gentek one off Ebay for my other car and found it vibrated under normal acceleration. Everything is tight so I don't know whether it's missing a 'stabilizer' (if it had one).
elfamiglia is offline
post #4 of 9 Old 02-26-2009, 08:09 PM
GNNR
2009 JK Wrangler
My 09 X has compass on the EVIC...
GNNR
GNNR is offline
post #5 of 9 Old 02-26-2009, 08:16 PM
GNNR
2009 JK Wrangler
I wonder... wonder if there is another visor that would fit that has homeline and maybe even vanity mirrors. Or if we could swap out the visor from the jeep visor mount/arm assembly.
GNNR
GNNR is offline
post #6 of 9 Old 02-26-2009, 09:59 PM
99TJSport
99TJSport's Avatar
I have one in mine and I've been very happy with it. Looks factory in there too. The auto-dim was one of the TJ features my LJ had that wasn't available on the JK, so I was glad to find one of these. I was really happy beause I shopped and pick it up for $130 right around Christmas time.
Jeff
08 Rubicon Unlimited, 2.5TF Lift, 285/70/17 BFG KM2s, lots of skids, MyGig, and both sets of doors/tops.
Parrothead Jeepers Union #24
99TJSport is offline
post #7 of 9 Old 02-27-2009, 01:57 PM Thread Starter
Expat_J33P_Fan
Haven't seen it vibrate at all - it is all pretty tight - the mounting arm seems much ticker than that of the original/stock mirror and it screws on like the original - certainly doesn't need a stabilizer.
Interesting that your 09X doesn't have the compass - I'm guessing you have the B pack rather than the S pack.
post #8 of 9 Old 02-27-2009, 02:02 PM Thread Starter
Expat_J33P_Fan
LOL - now the visors really are something that I find amusing....they really are about as useless as you could design them. I guess it's difficult with the roll cage etc but I have to say they are probably the only thing that I would redesign if it were up to me. I believe the Liberty has a homelink on the visor option (seem to remember seeing that at the dealership)
Swapping out the visors with something
a) useful (ie work)
b) cosmetically better looking
c) add function (like mirrors, homelink etc)
would probably bankrupt DC...... well if it was me doing it anyway
post #9 of 9 Old 02-27-2009, 02:28 PM
GNNR
2009 JK Wrangler
Something like this homelink rolling code unit in black from ebay... I wonder if it could be hacked into one of the visors. They seem thick enough, but I don't know how they come off the arm or apart (since it seems like it may be two pieces based on a wide seam I saw).
GNNR
GNNR is offline
Auto-dimming mirror wiring harness Yeoman TJ Wrangler Technical Forum 41 12-04-2010 11:40 PM
Installed Auto Dimming Rear View Mirror w/ Compass and Temperature, $70 OEM Slithering_Joe TJ Wrangler Technical Forum 2 06-07-2009 12:17 PM
those with auto-dimming compass temp. mirror JeepMKcomin TJ Wrangler Technical Forum 14 04-19-2007 10:27 AM
Question for those with the stock Mopar temperature/auto-dimming rear-view mirror Rocky529 TJ Wrangler Technical Forum 36 12-15-2005 02:28 PM
Auto-Dimming Rear View Mirror w/ Compass & Temperature sensor Oman Jeep TJ Wrangler Technical Forum 3 10-22-2004 11:30 AM
