Audio Issue - '08 w/premium sound - JeepForum.com
post #1 of 7 Old 11-26-2010, 09:10 AM Thread Starter
Mol
Disclaimer: I'm Polish
Mol's Avatar
I'll try this again, I found some more info that may be helpful, and no answers last time
My '08 Rubi (infinity sound) has had intermittent audio trouble - speakers crackle and pop, LOUDLY, but I am 99.9% sure that the speakers are not blown. This issue is much more frequent when listening via HDD or iPod (aux jack), and almost never happens when listening to the radio. The dealer supposedly corrected this issue, diagnosed as a bad speaker, under warranty when it was still my dad's lease. It now has 39K on it, and is mine.
Any ideas what might be causing this?
Mol is offline
post #2 of 7 Old 11-26-2010, 09:32 AM
nwbronco
2014 JK Wrangler
Sounds like you have answered your own question. At least, a troubleshooting guide to proceed with. If it happens with any device hooked to the aux jack and not the radio. It's with the aux jack, or the aux jack cable.
nwbronco is offline
post #3 of 7 Old 11-26-2010, 10:30 AM Thread Starter
Mol
Mol's Avatar
It also happens with the HDD, and it does happen with the radio, but not nearly as frequently as the hard drive/auxiliary devices.
Mol is offline
post #4 of 7 Old 11-26-2010, 01:32 PM
nwbronco
2014 JK Wrangler
Might be time to check all the phyiscal connections to the head unit. Does the unit show any symptoms of power interruption?
nwbronco is offline
post #5 of 7 Old 11-28-2010, 10:03 AM Thread Starter
Mol
Mol's Avatar
I'll do that - and to answer your question, no...no flickering or loss of function, just make you jump out of your seat static interruptions, and it seems that base-heavy songs are more prone to this (which lead me to believe that the speakers were the issue originally, until I found that it was only with the HDD and the auxiliary, very infrequently with FM/AM/Sirius).
Mol is offline
post #6 of 7 Old 11-29-2010, 11:12 AM
brtzworld1
2010 JK Wrangler
Chassis ground.
Not an expert but it sounds like there may be an issue with static build-up in the unit. Check the radio case to ground and you can add a ground strap while you have it open. It won't hurt a thing.
brtzworld1 is offline
post #7 of 7 Old 11-29-2010, 11:49 AM
MacK
2015 JK Wrangler
I had the same issue when using MP3 cd's in mine, and I re-encoded all my songs in a higher bitrate and it sounds good now. There is a level that is simply too "high".
I would go with that, as I basically had the same exact issue. But sadly it's not easy to re-encode your music.
Let me guess, the songs on the HDD are the same/similar (or same source) as the songs on the iPod. If that is the case, find a new download source. Just saying but using those P2P sources are not the best way to do it.. of course buying them is the only way =)
I don't want your d**n lemons! What the hell are these?! Demand to see life's manager! Make life rue the day it thought it could give Cave Johnson lemons! Do you know who I am? I'm the man who's gonna burn your house down! WITH THE LEMONS! I'm gonna get my engineers to invent a combustible lemon that BURNS YOUR HOUSE DOWN!
Mango Tango 2010 JK Wrangler Rubicon
Silver 2000 TJ Wrangler Sport
The 2008 Jeep Wrangler is not so much an SUV as it is an experience. It's slow and loud, handles poorly, has crummy interior materials and features doors that provide virtually no crash protection. But when it comes to off-road performance, the Wrangler is simply the best choice available.
MacK is offline
Oil pressure issue and knocking sound katdaddy1999 YJ Wrangler Technical Forum 9 12-30-2009 07:50 PM
transmission issue ? drive shaft issue ? clutch issue..where to begin ?..... rthompson48082 YJ Wrangler Technical Forum 7 09-28-2009 05:07 PM
SHOULD be an easy one: What does this sound mean? (Complete with audio/video!!) phelan YJ Wrangler Technical Forum 12 08-24-2009 05:51 PM
Sound like an alignment issue? thejafe TJ Wrangler Technical Forum 0 10-07-2007 12:42 PM
Sound audio Iquois YJ Wrangler Technical Forum 1 01-22-2007 07:51 AM
