ARB Twin Rear Cubby - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > ARB Twin Rear Cubby
Black Friday Sale - Deep Discounts from ExtremeTerrain.com6th Annual, Beat Your Wife to the Credit Card Sale!FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome Effect
Unread 11-25-2014, 11:05 PM   #1
christensent
ARB Twin Rear Cubby
Is there a reason I've only seen one or two people try putting a compressor in the rear cubby? My only concern is thermal due to the relatively poor air circulation even with a fan. I can't imagine it'd be worse than a hot engine compartment, but who knows. Anyone have experience with this? Does it overheat real quick?
The spot will be under my toolbox so would otherwise be useless anyways, seems like a perfect place to put the compressor.
christensent is offline   Reply With Quote Quick reply to this message
Unread 11-25-2014, 11:11 PM   #2
LeighP
Use the lid as a pattern....cut a new cover out of expanded mesh (steel or alloy). It'll support your toolbox, but also vent the compressor.
Just a thought.
Regards,
Leigh
2013 JK Overland/Sahara 3.6L
LeighP is offline   Reply With Quote Quick reply to this message
Unread 11-26-2014, 08:41 AM   #3
duneslider
You do need some vent for the heat to escape but I also think without venting it you might have trouble with the pumps getting enough air to pump, you could relocate the inlet filters to outside the cubby though.
If you have stuff pilled in the back you could block all the air in and out of the cubby and that may not make for a good pump location.
I have mine in the engine compartment and it does get pretty hot in there but 90% of my use is for the lockers and so it runs very little for that reason. When I am inflating tires and such I have to open the hood to connect the hose anyway. So, it seems to work out just fine.
duneslider is offline   Reply With Quote Quick reply to this message
Unread 11-26-2014, 10:44 AM   #4
D700
D700's Avatar
2014 JK Wrangler
I mounted mine under the hood and it works fine. I believe that in the back compartment it would get hot due to air restriction.
D700 is offline   Reply With Quote Quick reply to this message
Unread 11-26-2014, 11:55 AM   #5
mrwhipple
D700
Is that twin mounted to a special bracket?
silver jkur
mrwhipple is offline   Reply With Quote Quick reply to this message
Unread 11-26-2014, 01:39 PM   #6
D700
D700's Avatar
2014 JK Wrangler
Originally Posted by mrwhipple View Post
D700
Yes it is.
http://www.mountainoffroad.com/_e/Ai...o_Current_.htm
Unread 11-26-2014, 01:51 PM   #7
JIMBOX
Mine is also in the engine compt.,but
I only useit with the hood--OPEN !
The compressor gets "HOT", I can't imagine how hot the "Dual" comp. gets--needs free airflow !
JIMBO
Yellow Jeep No. 683
http://i294.photobucket.com/albums/m...10-snow027.jpg
--YA GOTTA HAVE CLASS--
JIMBOX is offline   Reply With Quote Quick reply to this message
Unread 11-26-2014, 01:55 PM   #8
D700
D700's Avatar
2014 JK Wrangler
Never had an issue with it. It gets plenty of air flow.
Unread 11-26-2014, 04:24 PM   #9
mrwhipple
Originally Posted by D700
Thanks for the link.
That's a nice setup. I didn't think you could get one in there and still be able to close the hood.
silver jkur
