ARB snorkel? - JeepForum.com
post #1 of 16 Old 08-24-2010, 03:25 PM Thread Starter
Klutz1001
ARB snorkel?
All I can find about this is threads suggesting try mine instead. Just wondering if anyone runs this and how they like it/ how the install was?
Klutz1001 is offline
post #2 of 16 Old 08-24-2010, 07:42 PM
McKBrew
JK Wrangler
Don't run it. I've read some good things about it. The only disadvantage I can see with the ARB snorkel is that it's plastic and if you wheel in areas with tight trees, etc... you might run into issues. If I buy a snorkel it's going to be the River Raider for that reason.
McKBrew is offline
post #3 of 16 Old 08-24-2010, 07:47 PM Thread Starter
Klutz1001
I have the river raider on order! Its just the agonizing wait and the price is causing me to reconsider
post #4 of 16 Old 08-24-2010, 07:56 PM
McKBrew
JK Wrangler
I think it will be worth the wait.
McKBrew is offline
post #5 of 16 Old 08-25-2010, 05:44 AM
bubba2u
2009 JK Wrangler
i have been running the aev for over a year. works great. looks great. it takes a beating. the install is much easier then the RR. just cut a hole in the hood. you don't have to relocate the battery or cut a hole in the fender. plus its like half the cost
bubba2u is offline
post #6 of 16 Old 08-25-2010, 05:53 AM
Warlord2
Do you have a pic of the front of the jeep? Just curious if it would clear my light bar
Looks good! Im interested in the dome dust filter. For all the desert riding I do, it would be well worth it.
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline
post #7 of 16 Old 08-25-2010, 06:00 AM Thread Starter
Klutz1001
i just cant get over the looks of that thing though... once again... not looking for a try this one instead yall... anyone run this??
post #8 of 16 Old 08-25-2010, 03:46 PM
dvdsjk
dvdsjk's Avatar
Although I am a fan of the AEV I did run across this review on the ARB for you.ARB Safari snorkel review for the Jeep TJ wrangler
dvdsjk is offline
post #9 of 16 Old 08-25-2010, 04:01 PM Thread Starter
Klutz1001
im trying to find the jk specific install... the other just go through the fender while the jk one goes through the flare as well... anyone?
post #10 of 16 Old 08-25-2010, 05:31 PM
krutj
2009 JK Wrangler
I've looked around for the same info.....no go!
All that I've found is TJ snorkels, the new Q-tec catalog has a pic, but no new info. The ARB web site was a bust too.
I'm about ready to give up and go w/AEV.....
-- Joel --
krutj is offline
post #11 of 16 Old 08-26-2010, 04:47 PM Thread Starter
Klutz1001
FINALLY i found something! what do yall think?
YouTube - Safari Snorkel Installation Jeep JK
post #12 of 16 Old 08-26-2010, 05:21 PM
DBA2GO
That's an snorkel install for a diesel. Did you see the CRD in the video? This is still not what you're looking for. Unless you are very lucky and have a diesel in your JK.
One foot in the grave & one foot on the gas pedal!!
DBA2GO is offline
post #13 of 16 Old 08-26-2010, 08:09 PM Thread Starter
Klutz1001
The parts appear almost identical though... I was more concerned with how/ where the snorkel enters the body of the JK. I am planning flat flares right now and if it enters the engine compartment like the video show that is out of the question.
post #14 of 16 Old 08-26-2010, 09:53 PM
tavic
2010 JK Wrangler
The only reason why I'm considerig the River Raider is because I encounter a lot of wooded areas, because trees have a tendancy to rip the plastic ones off.
However I do like the Volant and AEV styles because they're a little bit more inboard making them more protected than they were on the TJs.
tavic is offline
post #15 of 16 Old 08-26-2010, 11:34 PM
JLC08JK
What was I thinking?
JLC08JK's Avatar
If I was to even consider a snorkel this would be the way that I would go!
http://www.jeepforum.com/forum/f96/j...norkel-958737/
Jim
JLC08JK is offline
arb snorkel , ideas , JK Wrangler , picture , snorkel , suggestions , wrangler
ARB Snorkel VS. Volant Snorkel None TJ Wrangler Technical Forum 73 02-18-2011 07:50 AM
ARB Safari Snorkel VS. Volant Snorkel pjleslie03 TJ Wrangler Technical Forum 42 07-16-2010 01:00 PM
snorkel for 4.3L jaminb YJ Wrangler Technical Forum 9 11-13-2009 09:55 AM
DIY snorkel mod? wyattarnall TJ Wrangler Technical Forum 3 12-15-2008 10:54 AM
Why I want a snorkel... naviathan YJ Wrangler Technical Forum 14 03-05-2006 07:22 PM
