Anyone with a Truetrac in their 2012/2013 - JeepForum.com
post #1 of 31 Old 12-09-2012, 08:12 PM Thread Starter
xzy
I'm trying to figure our two things. Can I put TT's in my 2013 JKUS. Eaton's 2013 application guide only go to 2011 for the JK. Front part # 912A585(g) ( 3.73 up ) Rear 913A589 ( all ) I've heard the carriers must be drilled from 7/16 to 1/2" which will take a machine shop I'm guessing. I can find someone to drill them ( I hope ) but I'd like to know if anyone has either of these on a late model JK.
I'm also looking for someone who does competent work for the installation. Any recommendations would be appreciated ( assuming the TT's will work in the first place )
I'm not here to debate Lockers vs LSD. I know the difference. Yes Lockers are great, but they're not for me.
This is a great forum.
xzy is offline
post #2 of 31 Old 12-10-2012, 07:09 AM
tslewisz
2010 JK Wrangler
I guess I can't give you an absolute answer, but I will say that I've heard of no differences between the diffs of 12/13's and earlier ones. I double-checked your part numbers, and they're correct.
If you're using OEM gears, yes, the rear carrier will have to be drilled. Some say it's no big deal, some say it's a bear. My aftermarket ring gear (Yukon) was drilled for both sizes so I just bought 7/16" bolts.
I love my TT's.
tslewisz is offline
post #3 of 31 Old 12-10-2012, 07:27 AM
RobsYJeep
i was planning on doing f&r truetracs but I'm a lil concerned about their behaviour and performance in snow and slick conditions. My worst nightmare would be the traction device locks up and pulls to a side and into a ditch or oncoming traffic.
does anybody have real world experience with the TT front and rear in snowy and icy conditions.
thanks
guys
Rob
My JEEP is just a project until it becomes an obsession...
RobsYJeep is offline
post #4 of 31 Old 12-10-2012, 02:39 PM
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
Can't say for sure about 12/13 taking TT's, but if you find out they can (which I think you probably will as I do not think there is any difference between 11 and yours) I can recommend a place just north of Detroit. The place is called "Ring and Pinion Shop", located at 36180 Groesbeck Hwy., Clinton Twp. Mi 48035. Phone 586-792-2560. They put TT's in my WJ, both axles, and I had no problems with them, put about 275,000 miles on them. I had them also install and regear my 2011 JKU from 3:73's to 4:10's with TT's. It would be a little bit of a drive for you, probably about 100 +/- miles, but they do good work. Give them a call and they will be able to tell you if yours will take TT's. What axles did your window sticker say you have? If it is next generation 30 and 44 then they are the same as the 2011's.
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline
post #5 of 31 Old 12-10-2012, 02:44 PM
michiganmaveric
Got Beer?
2011 JK Wrangler
thanks
guys
Rob
I had TT's in both my axles on my WJ, and they were the best set up I could have asked for. You will not even know you have them, their operation is undetectable. They will not pull you to the side when they lock up, it is if they do not lock up that you will skew to the side. In the snow I was unstoppable, I would cut off the tops of snow drifts. On ice they are like anything else. On ice it is hard to control any vehicle. I liked the TT's so much that one of the first mods to my JKU was to put TT's in both axles, I highly recommend them.
Lifetime member #13
post #6 of 31 Old 12-10-2012, 02:59 PM Thread Starter
xzy
I've got next gen 30/44. Sounds like I'm good. Thanks for the help. I'm running 3.73 with 285/70/17 BFG AT's. No plans ever going bigger. I've heard a lot of good things about the ring and pinion shop. I'll give them a call.
xzy is offline
post #7 of 31 Old 12-10-2012, 10:22 PM
djm
my apologies for drifting off topic for a minute, do you run the 285/70/17 on a stock vehicle or do you have a lift ?
Thanks
Dan nj/pa
djm is offline
post #8 of 31 Old 12-11-2012, 05:50 AM Thread Starter
xzy
No lift, and don't plan on ever doing that. The wheels/tires came with it. AEV Savegre. The tires/wheels are heavy. Probably twice that of the stock set ( 255's ) No issues with clearance. I'm guessing there would be no problem with the stock wheels either.
Size: 17" x 8.5"
Bolt Pattern: 5x5
Offset: +10mm
Approximate Backspacing: 5.2"
xzy is offline
post #9 of 31 Old 12-11-2012, 09:49 AM
djm
Thank you very much! I am looking to put 285/70/17 Goodyear Duratracs on my 2012 4dr Sport. Just trying to make sure I can without a lift at this point. When I add the winch I will do something to compensate for the added weight hanging off the front.
Thank you very much for your reply
Dan pa/nj
P.S. nice looking rig ya have there !
djm is offline
post #10 of 31 Old 12-11-2012, 04:06 PM
gsaxe
well I came hear for the lcoker dicussin but....my 285/70/17s hancook mts rub even more than my 285/70/17 mtrks did, and I have a 2.5" ome lift. Now I a talking aired down disconnected flexing but also at full turn on pavement at 33 psi.
AKA Catfish
gsaxe is offline
post #11 of 31 Old 12-11-2012, 08:58 PM
djm
My apologies - you are correct this is about lockers.
Dan nj/pa
djm is offline
post #12 of 31 Old 12-12-2012, 09:57 AM
gsaxe
no worries here...I should apologize to the op too
AKA Catfish
gsaxe is offline
post #13 of 31 Old 12-12-2012, 10:55 AM Thread Starter
xzy
No worries here either
Everyone's comments were very helpful.
My rear TT will be here today. I just called Ring & Pinion to set up an appointment. Right now I'm going to wait on the front.
Thanks to all...
xzy is offline
post #14 of 31 Old 08-12-2013, 05:04 PM
gsaxe
how you liking the tt?
AKA Catfish
gsaxe is offline
post #15 of 31 Old 08-13-2013, 10:51 AM
SLADE
I just had 4.88's and TrueTracs installed front and rear in my 2013 JK Sport. For the rear Dana 44, JK's use a 3.73 and down carrier for all gear ratio's. The carrier is not JK Dana 44 specific.
Rear
EAT-913A589
Front
EAT-912A585
Now would be a good time to regear and avoid having to drill out the rear ring gear bolt holes.
Here is a good price on Yukon Gears.
http://www.4ws.com/jeep-wrangler-jk-...ront-rear.html
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is online now
