Anyone have any gas cap sensor problems? - JeepForum.com
post #1 of 22 Old 05-28-2010, 08:08 AM Thread Starter
Evil_Ed
I have 78k miles on my 07...bought it in for the usual oil/filter/lube service on Tuesday. Drove straight home from there. Wednesday I start it up...it beeps just after startup and the dash display says "gascap". Since I didn't touch the gas cap at all between the service and me starting it, I figured someone at the dealer knocked a vacuum hose loose when servicing the jeep or something. I reseated the cap, and it still beeped at me. I didn't see anything obviously disconnected or loose under the hood.
Yesterday I took it to the dealer, who said "uhh we think it was a loose gas cap...Did you tighten it all the way?" Sure, and explain to me how it got loose when no one touched it? But anyway...
They said they plugged in a vacuum tester and there was no vacuum leak, so they assumed it was just a loose cap, and left it at that. They did say however that it was NOT throwing an error code at the computer.
When I picked it up at the dealer, it didn't bong at all.
This morning, I started it...yep, it bonged.
Before I shove the gas cap down someone's throat at the dealer when they ask me if I was sure I put the gas cap back on (never mind that I haven't touched it), does anyone know where the sensor is for this? A quick google for it doesn't bring any useable results :/
Since I didn't touch it and since they say there's no vacuum leak, I can only assume the sensor's gone bad...
Evil_Ed is offline
post #2 of 22 Old 06-02-2010, 05:01 AM
l8whalefr8
When my jeep had the gas tank replaced due to it puking fuel every fill up, I had the same issue.
Turns out, there was a hairline crack in the replacement tank.
They did a "smoke test" (shoulda been done the first time, but that's neither here nor there - don't take your Jeep to Boniface-Hiers, fyi), and ended up putting another new tank on.
l8whalefr8 is offline
post #3 of 22 Old 12-12-2011, 05:53 PM
mathteach1982
2012 KK Liberty
Hi. I know you posted this a while ago. But I currently have the same problem with my jeep, which is an 07. I currently have about 95000 on it. The gascap light showed up followed by the check engine light. They did a smoke test then told me it was the gas tank neck, repleced it and the problem showed right up again. Now they say it is some senor. I was wondering what your problems was.
Thanks!
mathteach1982 is offline
post #4 of 22 Old 12-12-2011, 06:01 PM
thedude386
2011 JK Wrangler
I had that problem on m 11 with my locking gas cap. That problem went away when I went back to my factory gascap because the salt on the roads here caused the lock to seize on my locking gas cap.
thedude386 is offline
post #5 of 22 Old 12-12-2011, 06:32 PM
gumbydammit
I had it happen on my '07. I replaced the cap and cleared the code & still came back. Turns out it was the little sensor that goes into the evap canister. If I remember correctly it was pretty cheap to replace and easy to get to... at least with a 4" lift & 37's
gumbydammit is offline
post #6 of 22 Old 12-12-2011, 06:59 PM
joe002
Got it when I put a hole in my Evap Can. After I fixed the hole I had a few starts before it cleared the error. If your cap wasn't only all of the way it takes a few starts to clear it, otherwise there’s probably still a problem, somewhere...
2008 Rubicon - 2 Door - Flame Red - Automatic - MyGIG - Power Group - Deep Tint.
AEV Pintlers, BFG KM2s 35x12.50x17, Bulldog Fab Stubby Bump, Currie F/R Adj Trac Bars, Daystar Upper Dash, FireStik FireFly antenna, Kilby Rear Shock Skids, LoD Sig Stubby Bump, Midland 75-822 CB, Mopar Filler Door & Locking Gas Cap, Rancho LCA Skids, Rancho Oil Pan Armor, Riddler Diff Covers, custom Rubi Sliders, Sylvania X-treme Headlights, TeraFlex 2.5" Spring Lift, Warn PowerPlant HD, Woods Evap Can Relo, Woods SS Relo, Yukon 5.38s
joe002 is offline
post #7 of 22 Old 12-13-2011, 06:06 AM
gmuddy
2009 JK Wrangler
you may want to disconnect your batty for 5 min. to reset the computer, if you continue to receive notices after that, then there is a leak somewhere.
gmuddy is offline
post #8 of 22 Old 08-08-2013, 09:56 PM
tonga
I'm currently having the same problem. 9-1-1 help. My warranty is over and I can't pass smog because the system is reading the check engine light on code. Right now the gascap light is on & check engine light due to evaporative emission system leak ( small ) and exhaust gas recircuation ( high ). Which is the cheapest & quickest route? Change gascap, if it doesnt work? Smoke test?
tonga is offline
post #9 of 22 Old 08-09-2013, 07:48 AM
duneslider
I had this issue and replaced the gascap and it was still there. I ended up replacing an o-ring on the evap canister where the sensor is and that fixed the problem.
duneslider is offline
post #10 of 22 Old 08-09-2013, 07:59 AM
Green2007JK
I just ignore it................
2007 JKU Rubicon, RK 5.5 X Factor Plus System with RK 2.0rr's, 37" MTR's, Poison Spyder trail cage, Crusher Corners with LED lights, R-SE Step Sliders, JRC Dagger Tire Carrier Bumper, PCS box and ram, D44 sleaved-trused 5.13's, ORO sway locks and Currie 1" rear.....etc LC9 and 6l80e waiting to be installed
Green2007JK is offline
post #11 of 22 Old 08-09-2013, 09:15 AM
duneslider
That works as long as you don't have emission inspections. It won't pass if it shows that code.
post #12 of 22 Old 08-09-2013, 12:44 PM
gumbydammit
Borrow someone elses gas cap and see if that clears it up, if not I think the sensor & o-ring would be the best bet. As I recall it was fairly cheap and quick to replace.
post #13 of 22 Old 08-09-2013, 12:45 PM
5foot19
2016 JK Wrangler
I have filled up, and between paying, texting, and entering my gas mileage info in my cell phone I forgot to put my gas cap in...
Drove home ~3 miles, no check engine light, ding, idiot lights or gascap messages...
5foot19 is offline
post #14 of 22 Old 08-10-2013, 10:28 AM
orangera1n
2009 JK Wrangler
Happens to me in cold weather only.
orangera1n is offline
post #15 of 22 Old 09-23-2013, 01:40 PM
TBayTelemark
I pulled off the O-ring from the gas cap, cleaned the O-ring and the top of the filler tube with methyl hydrate / methanol, lubricated the O-ring with Seal Saver (a lube for latex/rubber seals), flipped over the O-ring, and put it back on the gas cap. Problem solved. My guess is that the O-ring had dried out and flattened out over time, such that it could no longer keep the pressure seal. Once the other side flattens out, I'll replace it. 2007 JK.
TBayTelemark is offline
TPS sensor problems.. 4wheel4real TJ Wrangler Technical Forum 22 11-02-2008 02:50 PM
O2 Sensor Problems schoena TJ Wrangler Technical Forum 15 02-07-2007 06:46 PM
O2 Sensor Problems?? mattvino TJ Wrangler Technical Forum 1 01-04-2005 05:51 PM
sensor problems again William Burns TJ Wrangler Technical Forum 23 06-27-2004 01:28 PM
more O2 sensor problems... blakkbelt YJ Wrangler Technical Forum 0 05-15-2004 07:20 AM
