Anyone fix the Cowl Dent from the door hitting it? - Page 2 - JeepForum.com
post #16 of 67 Old 09-16-2010, 06:52 AM
Filthy-Beast
Great post, My wife's JK with full doors has one on the drivers side. I was trying to figure out what she hit when we were offroading and she swore she hit nothing. I just checked and sure enough it lines up perfectly with the mirror.
For Sale:
97 TJ: daughter 1 - 2.5L, Auto, 2" BB, 31" GY Duratrac
98 TJ: Daugher 2 - 4.0L, 5spd, D44 rear
06 LJ Rubicon: mine - Rokmen full up-armor, 8 adjustable CAs, front bumper, sliders, corners, Shrockworks rear bumper, 3" AEV/BDS lift, Currie HD stearing and Antirock, MT/r - k 35x12.5, SuperWinch, MC Overlines, York OBA
13 JKU Rubicon: Wife's for now, Ace Rock rails & rear bumper tire carrier, Truck Lites, MC Game changer 3.5 lift, RR skids, PSC Brawler front bumper, Warn 9.5cti-s, 35" GY MTRs
Filthy-Beast is offline
post #17 of 67 Old 09-22-2010, 07:16 PM
copperpark
2010 JK Wrangler
I got mine (on the driver's side) last week. Was taking the doors off for the first time, being extra careful, and my four-year-old son had gotten in the other side. He "helped" me by opening the door while I was carrying one of the others over to the side of the garage.
Mine is a small dimple. I have seen some that are two inches across.
The cowling sheet metal is just slightly thicker than aluminum foil, and spot welded on at the bottom so it can't be removed. I may try to work the dent out from the inside with a rounded-end wooden handle I have. The key is not to crease and crinkle it worse than it is now. Would care less if the Jeep was more than a month old.
copperpark is offline
post #18 of 67 Old 09-22-2010, 10:03 PM
Dsx
2010 JK Wrangler
Same issue. The GF wanted to surprise me on a nice day in July by taking the top and doors off herself while I slept in after work. Instead I walked out to the drive way to 2 new dents and her in tears.
The dealership told me $200 to fix them, I decided covering them was just easier.
Warrior Products Outer Cowl Covers
I'm still on the fence with how they look. They're growing on me, but we'll have to wait and see how the build comes along on whether or not they stay.
Dsx is offline
post #19 of 67 Old 07-18-2011, 10:11 PM
jakeswingman
yes, it is. my cousin and I both have 4 door JKs and we BOTH made the mistake of letting the door swing open without the strap to stop it, and the lower corner of the side view mirror makes contact with the body first, denting that spot. they look exactly the same.
jakeswingman is offline
post #20 of 67 Old 07-18-2011, 10:12 PM
BLACKMARKT
Originally Posted by PSYCH0 View Post
I purchased a used 2010 that has matching door dents on each side cowl... just wondering if anyone had luck fixing their dents...
images?
FOLLOW THE LEADER ON TWITTER @RW_PLATINUM
BLACKMARKT is offline
post #21 of 67 Old 07-19-2011, 05:28 AM
mramella
I was quoted $160 for just one side (I only had the issue on the passenger side). I told 'em to go blow... $160 is outrageous! I managed to get most of it out by myself, using a broom handle and a rubber mallet. I just shoved the broom handle in there while the hood is up, and then lightly tapped with the rubber mallet on the opposite end of the broom handle (kinda like the hockey stick trick mentioned above). Much to my surprise, most of the dent actually popped out!
mramella is offline
post #22 of 67 Old 07-19-2011, 08:14 AM
Mol
Disclaimer: I'm Polish
Mol's Avatar
I'll just throw this out there...
Hook up your damn limiting strap! 46Kish and 3.8 years on mine with no cowl dents (uh oh, better knock on wood)!
Mol is offline
post #23 of 67 Old 07-19-2011, 10:00 AM
Scooter_Trash
Funny you should say that. 4.8 years, 58k miles and I dented mine for the first time last week. Just brain farted or something. Heat index was 115˚, the storm clouds were overhead. I hooked the last door on the hinges, then just let go of it. No idea why. Grabbed it just as it hit, but not fast enough. Nickel sized dent on the driver's side.
Click to join
Scooter_Trash is offline
post #24 of 67 Old 07-19-2011, 10:03 AM
Mol
Mol's Avatar
^ Karma's coming for me...I feel it. Should have kept my mouth shut
Mol is offline
post #25 of 67 Old 07-19-2011, 10:43 AM
OregonVette
This is how it was described to me 3.5 years ago:
"oh, you have JK dimples too." in ten years you'll notice every JK will have these.
I have learned to live with it. Fortunately, I only have one on the driver side. But as a post above said, I leave mine on there as a gentle reminder to not be in such a hurry when removing doors etc.
Every Jeep needs dimples, chicks dig it
Originally Posted by smcutter View Post
It's hard to give you good advice at this point. It's almost like you're saying, "I want to have sex, but don't want to get her pregnant. I can't afford condoms, so for now I just want to use Saran Wrap. What brand would you recommend?"
OregonVette is offline
post #26 of 67 Old 07-19-2011, 10:48 AM
Scooter_Trash
In that case mine has one dimple, and couple of acne pock marks, and **** load of laugh lines and crows feet.
Click to join
post #27 of 67 Old 07-19-2011, 10:53 AM
OregonVette
^^^ those are called "smile miles" ^^^
post #28 of 67 Old 07-19-2011, 01:00 PM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
At least it doesn't have leprosy
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #29 of 67 Old 07-19-2011, 01:02 PM
Scooter_Trash
Nope, but my Harley does. I've lost mirrors, kick stands, clutch lever pin, etc. all while riding down the road. Loc-tight is my friend.
Click to join
post #30 of 67 Old 07-19-2011, 06:05 PM
jesah
When I bought my used 2008 I had negotiated the repair of my cowl dents. The dealership tried to tell me somebody had already attempted to fix them. Had they told me before I signed the deal I probably wouldnt care....but, since its part of the deal. I basically told them they had to fix it. At first their "Dent guy" tried to fix it, but the more he worked it the more the paint was cracking. The stealership eventually sent it to a body shop to de-weld(is that even a word) the cowl and fix the dent. Turned into a bigger hassel then it was worth. I guess it was the principle of it all
"Roads, where we're going we don't need roads"
jesah is offline
Cowl Vent Door Flapping (Pic) pendleton TJ Wrangler Technical Forum 10 08-24-2011 07:31 PM
Dent from letting door swing all the way bsteeves86 JK Wrangler Technical Forum 19 08-09-2009 12:50 PM
Cowl Dent Removal CajunHiker YJ Wrangler Technical Forum 6 07-10-2009 09:16 PM
push in or dent on door plyzie JK Wrangler Technical Forum 6 03-22-2007 11:28 AM
door hitting window frame db_17_85 TJ Wrangler Technical Forum 3 03-06-2005 01:07 PM
