Anyone ever throw these codes? - JeepForum.com
post #1 of 17 Old 08-06-2013, 09:51 PM Thread Starter
CMEvans79
P2172 and P0430
If you have, please, let me know what was done. Thanks all.
They say your jeep will eventually earn itself a name... Mine has now done that... ladys and gents, meet "Strife" because lately, that's all its given me.
CMEvans79 is offline
post #2 of 17 Old 08-06-2013, 10:41 PM
aznjeep
2014 WK
P2172-HIGH AIRFLOW/VACUUM LEAK DETECTED (INSTANTANEOUS ACCUMULATION) This information is a little beyond my comprehension, but maybe it can help you diagnose: http://www.chargerforumz.com/showpos...85&postcount=3
PO430: Catalyst System Efficiency Below Threshold (Bank 2) Here is some info on this: http://engine-codes.com/p0430_jeep.html
I would also suggest a Google search to see what others have said...
-Ken
'96 XJ Sport
'14 WK2 Overland EcoDiesel
'13 JKUR 10A (sold)
'10 JKUR (sold)
'99 TJ (sold)
aznjeep is offline
post #3 of 17 Old 08-06-2013, 11:13 PM Thread Starter
CMEvans79
OK ... I opened my engine bay this evening... Apparently after my mechanic "PUT IT ALL BACK TOGETHER" it wasn't all tight and it looks like one of the bundles of electronic cables was laying down on my steering shaft!!!! SOoooooo I think that was ONE of the codes... but could one of these codes cause the other?
post #4 of 17 Old 08-07-2013, 10:20 AM
PaXJ
remove the neg battery cable. Plug the cable that was on your shaft back in. reconnect battery cable. Start and see if any new codes come up.
PaXJ is offline
post #5 of 17 Old 08-07-2013, 12:59 PM Thread Starter
CMEvans79
I don't se where anything is unplugged ... If I didn't have a migraine, this day would be perfect day to be driving a good running jeep!
post #6 of 17 Old 08-07-2013, 02:36 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
What did your mechanic have apart? A vacuum leak is usually from the intake plenum being loose, a bad seal where the PCV pipe connects to the top of the plenum or where the MAP sensor O ring is located...The O2 sensor below efficiency is caused by the vacuum leak IMO.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #7 of 17 Old 08-07-2013, 03:57 PM Thread Starter
CMEvans79
I haven't found anything that seems "Out of place" or un plugged...
post #8 of 17 Old 08-07-2013, 04:28 PM
RockyClymer
RedRock4Wheeler
Again, what did your mechanic have apart? The items I listed would not be apparent from casual observation alone.
NRA Life member
post #9 of 17 Old 08-07-2013, 05:18 PM Thread Starter
CMEvans79
Again, I have looked and felt around, nothing seems out of place. the hose going from the air intake to the valve covers was a bit loose, but not a lot...
post #10 of 17 Old 08-07-2013, 06:56 PM
RockyClymer
RedRock4Wheeler
Last time. What did your mechanic take apart? You cannot see or feel a loose gasket or seal dude.
NRA Life member
post #11 of 17 Old 08-07-2013, 08:18 PM Thread Starter
CMEvans79
I've felt around, wiggled and gotten under the dagum thing, nothing looks out of place. I've reached where I couldn't see and tried to make sure everything felt like it was in place that I could find. The valve cover's both got new gaskets, they seem fine. I'm not just "LOOKIN" with my eyes I got up on my bumper and dove into the thing. I'm not mechanically inclined but I'm not an idiot either. My original question was HAS ANYONE HAD THESE CODES... I appreciate you trying to help with the suggestions but its getting redundant. SO THE ANSWER TO YOUR QUESTION IS NO, I CANT FEEL ANYTHING OUT OF PLACE OR A LOOSE GASKET! DUDE.
post #12 of 17 Old 08-07-2013, 09:02 PM
RockyClymer
RedRock4Wheeler
Yes I have had the codes. The fact you think the valve cover gasket is the place to look for a vacuum leak illustrates your genius. You have to disassemble and examine your PCV connection for a leak and see if the seal is tight, not wiggle or look at it. Same for MAP sensor or intake manifold and/or air plenum dude. You look but you do not see grasshopper
As for my 'tude. See my sig.
And last of all. What your mechanic did will give you and the rest of this forum a clue for what to look for. If he/she removed the PCV pipe to get to another part ie. a valve cover, then it makes sense to look (disassemble and examine) that part.
NRA Life member
post #13 of 17 Old 08-07-2013, 11:47 PM Thread Starter
CMEvans79
I've "Felt up" the exhaust system but don't have the means or the time to pull isht apart... I'm taking it to the same mechanic so that they can possibly run the codes and see what the hell is going on. Mechanic did take apart the engine to the valve covers and didn't ... I just realized, I you haven't seen my MAIN problem... I'll post a link to the video... a tapping in the upper end of the engine but they didn't find anything when they were in there the first time... they'll not charge me to go that deep again...
https://www.facebook.com/photo.php?v...type=2&theater
You have to understand my situation. I'm usually an easy going happy guy who speaks fluent sarcasm with the best of em... but for the last two weeks I've been having to borrow vehicles from others to make it to one of my two jobs and money isn't just growing on trees for me. Stress and migraines are getting me down, I'm worn thin. My sarcasm filter is in need of repair.
post #14 of 17 Old 08-08-2013, 10:08 AM
RockyClymer
RedRock4Wheeler
Finally, well, he probably did not get the PCV pipe to intake plenum sealed properly...it is one of the most common areas for vacuum leak and is tricky to get sealed again. I had to use a new seal between the pipe bracket and the plastic plenum....
see....when you finally take some time to give specifics, we can help a lot better. Let us know what the mechanic finds, or, show your knowledge and point him to a potential problem area.
NRA Life member
post #15 of 17 Old 08-10-2013, 06:25 PM Thread Starter
CMEvans79
OK ... Mechanic read the codes... said one of my cat's are shot... I asked if it could have been from a loose gasket, he wasn't sure. Then when he put the valve gaskets back on he was having a problem getting them to stick so he used an automotive glue? And I can't pick it up till Monday because they are closed on the weekends. Tapping has been discovered that they were the stuck/broken lifters... going to cost me upwards of almost $800 just to fix it.
