Anybody change the rear axle fluid in their JK? - JeepForum.com
post #1 of 32 Old 08-26-2011, 11:33 AM Thread Starter
MrMundo
I am looking for any words of wisdom.
MrMundo is offline
post #2 of 32 Old 08-26-2011, 11:46 AM
Tireguy
2009 JK Wrangler
Pretty simple. A 3/8ths ratchet, drain/catch pan, new fluid, favorite beverage.
Remove drain & fill plug, drain fluid, enjoy beverage while fluid drains, replace drain plug, fill with clean oil, replace fill plug, clean up mess, take nap.
Tireguy is offline
post #3 of 32 Old 08-26-2011, 12:24 PM Thread Starter
MrMundo
Thanks Tireguy
Sounds like it should be fairly straight forward. I already have inclinations on the type of beverage I will enjoy, any suggestions on the axle fluid?
MrMundo is offline
post #4 of 32 Old 08-26-2011, 12:53 PM
tavic
2010 JK Wrangler
80W90
If you have Trac-Lock don't forget the additive.
tavic is offline
post #5 of 32 Old 08-26-2011, 12:59 PM
BigNunz6
2015 WK
http://www.jeepforum.com/forum/f96/c...ahara-1004085/ here's a link ..
If you like it, buy it!!!!
BigNunz6 is online now
post #6 of 32 Old 08-26-2011, 01:36 PM
Tireguy
2009 JK Wrangler
Lots..and lots...and lots..of good products on the market, and even more threads about who-likes-what in their Jeep.
Tireguy is offline
post #7 of 32 Old 08-26-2011, 01:38 PM
JIMBOX
I'd drive for 15 minutes first, then try to drain on a level and let it drain, while you take a 10 minute break, then use a good Synthetic 75w-90, unless you tow, then use 75w-140 and most of the good synthetics have the LSD additive anyway--
I use Valvoline 75w-140 !!
Good luck
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #8 of 32 Old 08-26-2011, 02:23 PM
jrmandryck
I agree to drive it for a bit just to warm it enough so that it comes right out
truth is so precious that she should always be attended by a bodyguard of lies...
jrmandryck is offline
post #9 of 32 Old 08-26-2011, 03:27 PM
OH9JK
2009 JK Wrangler
god I love the smell of gear oil in the morning!
OH9JK is offline
post #10 of 32 Old 08-26-2011, 04:48 PM
DontFearJeeper
Vendor
2011 JK Wrangler
if its a rubicon i suggest removing the diff cover and cleaning it out with some brake cleaner. this will help the locker work better, if you have a lsd i would still do the same, it gets really nasty in there this will help keep things togather longer.
make sure you use synthetic fluid this helps a ton.
just my
Brandon
Thank you for considering us,
"I like the idea and business ethics that you stated.. Tread lightly..tree planting it's all a big part of keeping the wild..well... alive" ocTJ
DontFearJeeper is offline
post #11 of 32 Old 08-26-2011, 07:28 PM
Ajaxxx
2010 JK Wrangler
Wear some disposable gloves. The old gear lube stinks...
IowaAndy
2010 JK Unlimited Deep Ocean Blue, Auto, Cruise, Softtop, Half-doors, A/C
Ajaxxx is offline
post #12 of 32 Old 09-10-2011, 02:16 PM
bigapplephx
2009 JK Wrangler
If you have a Dana 35, you have to remove the differential cover to drain the oil. Spray with carb cleaner and let drain thoroughly.
If you have a Dana 44, just remove the upper and bottom plug and drain. Spray some carburetor cleaner into the upper and lower drain holes, and drain thoroughly. Service with 75w90 diff oil. I prefer Mobil 1 Synthetic.....
bigapplephx is offline
post #13 of 32 Old 09-10-2011, 04:31 PM
CoriolisSTORM
WHAT?!
CoriolisSTORM's Avatar
2010 JK Wrangler
just my
Brandon
At 30k my Sahara with LSD the fluid looked terrible on the way out! The magnet was covered in crap! Probably gonna get a lubelocker gasket next time I do it and pull the whole cover.
1998 TJ Wrangler SE - Stone White, 2.5Ls of screaming lifter clacking power, AX5, 31" BFGoodrich All Terrain T/A KOs
2010 Wrangler Unlimited Sahara - Deep Water Blue, 3.8Ls of oil consuming fury, NSG-370, BFGoodrich Rugged Terrain T/A 265/70/R18s
CoriolisSTORM is offline
post #14 of 32 Old 09-10-2011, 06:46 PM
tulsarob
I'd sorta suggest a pump that fits on the bottle so you can pump in the gear oil. This worked great till I had to change to the next bottle. Then it got a little messy lol. It's kinda like stinky honey. Gets on yer fingers, then on yer jeans, then in your hair, etc etc.
2008 JK Silver Rubicon, 2 dr, 6 spd, pwr windows, tow package, slush mats, lockin gas cap, lug nut locks, shorty antenna, woven-wire grill guard, Cobra 75WXST, Wilson 3' Flex Antenna, Teraflex ant bracket, Highrock element doors, RR Grab Handles,RR Fire Ext Holder, RR bumper,Smittybilt 8k winch,Daystar 3/4 coil spacer on front, Kilby engine skid, Rockhard transfer case skid, Poision Spyder evap skid
tulsarob is offline
post #15 of 32 Old 09-10-2011, 07:19 PM
JIMBOX
I'm having a hard time trying to figure out your troubles, in the diff. fluid installation !
They make the qt bottles with a narrow spout and a trimable tube so you can just insertit in the fill hole--I haven't had any troubles !!
JIMBO
Yellow Jeep No. 683
JIMBOX is offline
differential , differential fluid change , rear axle , rear axle lubricant
rear diff fluid change 4montecarlo YJ Wrangler Technical Forum 16 06-27-2011 06:15 PM
fluid change on d44 rear bottlerocket91 TJ Wrangler Technical Forum 2 12-05-2010 05:01 PM
Change axle fluid every 12K ?!?!? ...and other maint. questions 05Unlimited TJ Wrangler Technical Forum 48 08-16-2010 01:13 PM
Rear diff fluid change question leolufse TJ Wrangler Technical Forum 10 12-08-2009 03:23 PM
When to change rear diff. fluid? rayar3 TJ Wrangler Technical Forum 7 10-20-2006 09:32 PM
