Anybody Add 7-Pin Wiring for Trailer to a JKU - Page 2 - JeepForum.com
post #16 of 32 Old 05-17-2012, 08:50 AM
04 RUBI
2009 JK Wrangler
Originally Posted by mini-me
Not sure why you don't like it, it is an awesome place for the wiring. Its tucked up in there, no issues with trails. You can change the bumper etc and no worries and it works great to keep the wire up and away from carnage with the offroad trailer. I have a modified M100 trailer I use with this and it works perfect and looks OEM. Trust me, this is the way to go.
Can you post pic? I haven't mounted mine yet and you have me curious.
04 RUBI is offline
post #17 of 32 Old 05-17-2012, 08:51 AM Thread Starter
wmshay6
What is the CVCW of a Baja
Originally Posted by planman44 View Post
I have a 7 pin and trailer brakes for the same reason you need them. I pull a jayco baja popup camper. I had rv dealer install 7 pin and brakes for $150
What's that bad boy weigh? And how does it tow? I currently tow my Fleetwood Graphite (2700 GVWR) with a Nissan Titan. It's kind of overkill . . . .
wmshay6 is offline
post #18 of 32 Old 05-17-2012, 09:00 AM
mini-me
mini-me's Avatar
See page 1, pic is there.
2012 Sport in DCR
mini-me is offline
post #19 of 32 Old 05-17-2012, 10:29 AM
04 RUBI
2009 JK Wrangler
Oops. It wouldn't show on my phone. Thanks.
04 RUBI is offline
post #20 of 32 Old 05-18-2012, 09:32 AM
Lynhalla
Lynhalla's Avatar
unloaded weight is 3015 lbs. GVWR is 4,800 lbs. Tows great. I know I am pushing limits but manual trans and 5:13 gears help. Just took 1500 mile trip to Tenneesee mountains and it did well. a couple long 7% grade hills had me down to third gear but was able to maintain 40mph. Looking to add some umph this year by adding Ripp SC
Lynhalla is offline
post #21 of 32 Old 05-21-2012, 01:59 PM
oO_Rogue_Oo
Originally Posted by mini-me View Post
This is the best mod ever. Get the mopar 7 pin harness. Use a hole cut blade and fit it into the body just left of the rear door. Super easy.
Seen this done before and didn't like it for one reason; it gets in the way when trying to access the tailgate with the trailer hooked up. Also don't like running heavy power wiring so close to the fuel filler. I mounted my setup on the bumper, just built a little box for it out of 1/8" sheet. So far it's never been in the way; is very well protected and no worries with wiring so close to fuel.
"The society that separates its scholars from its warriors will have its thinking done by cowards and its fighting by fools."
Thucydides circa 460 bc - c. 400 bc
oO_Rogue_Oo is offline
post #22 of 32 Old 05-21-2012, 06:37 PM
rubicube416
I put a thread up a few months ago about wanting to do it on mine and it was pretty easy, having a car hoist to able to use made the job much easier then crawling around underneath it because i tried it that was and gave up lol
2011 Wrangler Rubicon
KMC XD series Addict rims
"If you don't stand behind our troops, Feel free to stand in front of them"
rubicube416 is offline
post #23 of 32 Old 05-25-2013, 09:33 AM
DocWEFest
2009 JK Wrangler
This is a very interesting way to mod. I am interested in doing this as my first mod followed by a 2.5" lift. What measures did you take to protect the metal once you drilled the holes? How is it fastened on, additional drilling for the bolts I would assume? Did you take precautions to safe guard against water, any sealing, rubber gaskets or silicone?
DocWEFest is offline
post #24 of 32 Old 05-25-2013, 10:46 AM
mini-me
mini-me's Avatar
No need to seal anything, it is all exposed in there anyway, it doesn't change anything. Its one large bore hole in the middle, then once you have that and insert the adapter in there then you mark the other 4 smaller holes and drill them. After all the holes are drilled you can just dab some paint to cover the metal. It won't rust out in your life time. Its really easy and the best mod I have ever done. We have done this to a half dozen Jeeps and no problems.
2012 Sport in DCR
mini-me is offline
post #25 of 32 Old 05-28-2013, 12:40 PM
waterboarder
waterboarder's Avatar
Has anyone added a 7Pin connector / harness to their JKU?
I have, detailed thread here: http://www.jeepforum.com/forum/f96/i...ler-jk-586378/
waterboarder is offline
post #26 of 32 Old 05-28-2013, 08:40 PM
nwbronco
2014 JK Wrangler
You guys are killin' me. I bought a 4 to 7 adapter and it plugs into the stock connector. Done.
Bob K.
His 14 Anvil JKUR-X
Hers 09 Blue JK
Kid's '08 Yellow JKU
'13 Black 10A Rubicon JKU
nwbronco is offline
post #27 of 32 Old 05-28-2013, 09:42 PM
waterboarder
The extra pins on a 7-pin connector provide:
a). Trailer brake control.
b). Reverse lights on the trailer.
c). A "hot" wire to charge the battery on the trailer.
You don't get that simply by using a 4 to 7 pin converter.
post #28 of 32 Old 05-29-2013, 12:13 AM
nwbronco
2014 JK Wrangler
Fair enough. I don't pull anything that needs those.
Bob K.
His 14 Anvil JKUR-X
Hers 09 Blue JK
nwbronco is offline
post #29 of 32 Old 05-29-2013, 12:33 AM
waterboarder
....then it seems rather strange that you would need a 7-pin connector converter. Generally, any trailer that has a 7 pin connector has one because it has trailer brakes. If you're just pulling trailers that have a 7 pin connector on them when they could be using a 4-pin connector...that would just be rather strange.
post #30 of 32 Old 05-29-2013, 12:12 PM
nwbronco
2014 JK Wrangler
Quite a few trailers I have pulled have the 7 pin and no trailer brakes. They were U-Haul and car dolly trailers. You know as well as I that it's a crap shoot on most of those types. I just finished building a quad trailer for a friend. We put a 4 pin on it. Went up to the trailer sales and looked at similar 5x8 trailers. No 2 were alike is a lot of 6. And 2 had 7 pin connectors. Sales guy was useless. I asked him about it and I might as well said it in Latin.
Bob K.
His 14 Anvil JKUR-X
Hers 09 Blue JK
nwbronco is offline
Trailer wiring 95Turtle YJ Wrangler Technical Forum 2 10-06-2009 08:40 AM
Trailer wiring ImpactFabWorks YJ Wrangler Technical Forum 11 08-30-2009 09:46 AM
Trailer wiring Trevor Tj 97 JK Wrangler Technical Forum 3 07-27-2007 04:32 PM
trailer wiring base shakers TJ Wrangler Technical Forum 10 10-21-2005 11:19 AM
Where does Trailer Wiring Kit Splice into existing wiring on YJ gary1 YJ Wrangler Technical Forum 1 07-18-2005 04:03 PM
