Any real reason? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Any real reason?
Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Poly Door Hinge BushingsStainless Steel Door Hinge Pins
Unread 06-27-2012, 07:59 PM   #1
Cgibbs
Any real reason?
I am wondering if there is some reason why they didn't extend the seal of the hood all the way to the end? So my second question is will it be ok to replace the one now so it runs all the way to the end?
Cgibbs is offline   Reply With Quote
Unread 06-27-2012, 08:06 PM   #2
JIMBOX
I didit three years ago and also pulled the "hood spring" and I haven't had any "hood flutter" ever since--
JIMBO
Yellow Jeep No. 683
http://i294.photobucket.com/albums/m...10-snow027.jpg
--YA GOTTA HAVE CLASS--
JIMBOX is online now   Reply With Quote
Unread 06-27-2012, 09:37 PM   #3
Cgibbs
Great, thanks.
Unread 06-27-2012, 10:10 PM   #4
jso902
JK Wrangler
that's why the hood flutters!??!
jso902 is offline   Reply With Quote
Unread 06-28-2012, 05:53 AM   #5
LIJeepJC
Air pressure under the hood. Makes sense the seal would help but u should expect some flutter because air pressure in the engine bay comes in under the truck.
LIJeepJC is offline   Reply With Quote
Unread 06-28-2012, 06:16 AM   #6
paul84043
No hood flutter with the 2012. Even after the lift... It's not broke, so I'm not going to fix it.
Blessed is he who expects nothing, for he shall not be disappointed.....
paul84043 is offline   Reply With Quote
Unread 06-28-2012, 07:08 AM   #7
MoreMud
Same here, no hood fluter on the '12
2012 JKU Rubicon
Rugged Ridge Front bumper w/storage ends Rugged Ridge 8500 Winch w/ synthetic rope
PIAA ATP off road lights, full light bar, Terraflex leveling kit, Mygig lockpick
just getting started.....
MoreMud is offline   Reply With Quote
Unread 06-28-2012, 07:16 AM   #8
TCHPET2
My 2012 has plenty of hood flutter. It was really bad yesterday going down the interstate in 20-30 mile in hour winds...
TCHPET2 is offline   Reply With Quote
Unread 06-28-2012, 07:24 AM   #9
JIMBOX
Three things that are apparent to "hood flutter"
1) loss of "air dam"
2) partial hood gasket
3) hood spring causes "cycle"/reciprocation as internal air pressure rises/falls--
Cures are--remove spring/install full gasket--or(free)
Buy new Daystar hood latches--or$$
Buy some really cool "Drake" latchs--$$$$
JIMBO
Yellow Jeep No. 683
Unread 06-28-2012, 09:00 AM   #10
jwmbishop
2011 JK Wrangler
On the pass side that allows air to flow to the air box. On the drivers (my guess) it allows airflow to cool the electronics, brake controller etc...
J Wm Bishop EA, ASADE
The Jeep wave - it means nothing. Now I look for the RearView wave. Anyone can cause a guy to readjust his rear view at night. But in the daytime when you roll up behind someone and they adjust their mirror to frame your Jeep straighter - THAT'S a compliment!
jwmbishop is offline   Reply With Quote
Unread 06-28-2012, 09:11 AM   #11
ncb
Plasti Dip yourself!
ncb's Avatar
2009 JK Wrangler
Lift on the corner of the hood and you'll see that the hood bungees are very weak. I can't imagine sealing the ends of the hood will make a difference. The air entering through the grill and under the bumper is what lifts the hood. I installed zip-ties over the bungees a year ago and nobody has ever noticed. I don't have anymore hood dancing with the crazy weather we get in Colorado. For 20 cents you can't beat it.
ncb is online now   Reply With Quote
Unread 06-29-2012, 05:56 AM   #12
LIJeepJC
Originally Posted by moremud
same here, no hood fluter on the '12
x3
Unread 06-29-2012, 06:02 AM   #13
LIJeepJC
The first thing I noticed when I got into the drivers seat of my 12' was the line of sight over the hood was lower. Checking a few sites I found that one of the slight aerodynamic changes to the new one was a sloped hood. They did this along with an increase windshield angle to reduce wind noise. The slope in the hood will reduce the hood flutter as it will create more downforce to counter the positive pressure buildup inside the engine bay.
Unread 06-29-2012, 06:17 AM   #14
ncb
ncb's Avatar
2009 JK Wrangler
If that's true the slight difference is probably gone once a lift is installed and it's leveled.
Unread 06-29-2012, 12:50 PM   #15
1222
Make mine a Jeep!
1222's Avatar
That’s very interesting; do you have a link to the site/sites where you found that info?
1222 is online now   Reply With Quote
