Any problems with that Freedom top? - JeepForum.com
post #1 of 7 Old 01-10-2007, 08:48 PM Thread Starter
mr.grumpy
Any leaks or excessive noise? Any one compare to the old style top?
mr.grumpy is offline
post #2 of 7 Old 01-10-2007, 09:36 PM
jimhut2000
So far mine is Air/water tight
2007 Wrangler Sahara Unlimited, Red Rock, 6 Speed Man. Trans., Sirius Radio, 4.10 Gears, Hard Top, 18" Wheels
jimhut2000 is offline
post #3 of 7 Old 01-10-2007, 10:41 PM
SPDSNYPR
Junior Member
+1 - no problems to report.
SPDSNYPR is offline
post #4 of 7 Old 01-11-2007, 05:37 AM
Motocane
Jeepster
I have had no problems with mine. It is much quieter than my TJ.
Motocane is offline
post #5 of 7 Old 01-11-2007, 07:10 AM
rlj
rlj's Avatar
No problems until last week, I noticed during a night of rain that I had a small drip between the two front panels where they connect in the center at the windshield when I got into the Jeep that morning.
I took both tops off and reinstalled them and the problem went away. I've taken it through a car wash and have been in the rain twice since then. Unless it comes back, I think you just have to be careful when installing the tops to make sure the tops are sealed properly.
2011 WK2 Overland
2007 JK Sahara Unlimited
2003 TJ X
rlj is offline
post #6 of 7 Old 01-11-2007, 09:09 AM
FLSeaMonkey
Mine has been great! I did notice a very small drop on the passenger dash yesterday after some torrential Florida rain. After looking though, it looks like I had the panels a bit off last time I put them on. From now on, I am going to get on the running board and look at the panels from the top after I instal. I can see where I was off up there, while inside it looks fine.
'07 Wrangler Unlimited Sahara Rescue Green
'94 Land Rover Defender 90
'64 Porsche 356C
FLSeaMonkey is offline
post #7 of 7 Old 01-11-2007, 10:01 AM
CombatChuk
I went through a very high pressure car wash, Not a single drop of water came through. If anything I got squirted on the side of the Door.
CombatChuk is offline
Freedom Top is fan-tas-tic! CTJeepGuy JK Wrangler Technical Forum 2 11-29-2009 06:08 PM
Freedom Top cburtner JK Wrangler Technical Forum 0 08-20-2009 03:24 PM
JK Freedom top jsantoli JK Wrangler Technical Forum 6 02-26-2007 09:24 PM
Freedom Top jpaddict JK Wrangler Technical Forum 3 11-04-2006 04:35 PM
03 freedom problems tjski TJ Wrangler Technical Forum 2 10-19-2003 08:40 PM
