Any one tried the Truck-Lite 7 Round LED Headlamp yet? - JeepForum.com
post #1 of 4 Old 10-02-2009, 10:23 AM Thread Starter
tturkstra
Good Day:
Haven't been able to find this with my search.
I'm looking to upgrade the headlights on my 08 JK 4-door. The *** [Edit: actually Philips Visionplus +50] improved things a bit, but I want more.
Truck-Lite 7” Round LED Headlamp - OK4WD
$330 each? These seem awfully pricey, so I'd love to avoid being the guinea pig and hear a few success stories before I fork over the $$$.
Anyone try them yet? I'd like to know how much better the lighting is and how hard they were to install. Apparently they need a different electrical plug, but that seem's doable to me.
08 JK unlimited Yellow
"When all is said and done, it seems a lot more gets said than done."
tturkstra is offline
post #2 of 4 Old 10-02-2009, 10:55 AM
Hilldweller
2014 JK Wrangler
Find Waterboarder's link to his Cibie upgrade; I think it cost less.
FWIW, if you installed Sylvania Silverstars and think it was an improvement, you're probably mistaken; they put out much less light that your eyes can use to focus. Narva Silverstars work but I don't think they come in an H13.
Phillips makes a couple of bulbs that are good --- Visionplus +50 and +80. Both are Eurospec.
My MINI Cooper uses H13 also; I have Philips Visionplus +50 bulbs in both.
Driving down the road in the Mini, it looks like daylight; same bulbs in the Jeep and I'm wondering if I remembered to turn the lights on....
Must be the reflectors or something.
Safety fast,
Security is mostly a superstition. It does not exist in nature, nor do the children of men as a whole experience it. Avoiding danger is no safer in the long run than outright exposure. Life is either a daring adventure, or nothing.- Helen Keller
Hilldweller is offline
post #3 of 4 Old 10-02-2009, 12:04 PM Thread Starter
tturkstra
Oops, you're right, I actually switched to the Philips Visionplus +50. OP edited...
No luck on the search though, suggested key words?
Thanks,
post #4 of 4 Old 10-02-2009, 12:42 PM
waterboarder
waterboarder's Avatar
Thanks,
Here you go:
http://www.jeepforum.com/forum/f96/d...-my-jk-858502/
Screw trucklite. Go with the Stern solution (:
waterboarder is offline
Delta 7" Round Quad Bar Xenon Headlamp Kit rob4607 JK Wrangler Technical Forum 20 02-01-2012 08:12 AM
pak-lite?? lumpster Wrangler General Discussion 12 04-26-2009 09:12 PM
4wd lite goes on.but won't go in 4wd Decscorpion YJ Wrangler Technical Forum 13 02-24-2009 05:02 PM
4x4 lite comes on JT2.5 TJ Wrangler Technical Forum 6 07-22-2005 10:14 PM
4WD Lite TimLCap TJ Wrangler Technical Forum 2 08-25-2004 02:26 PM
