Any JK's on 15" Wheels? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Any JK's on 15" Wheels?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineForever Wave Flags at JeepHutRubicon Express lift kits w/shocks are on sale!
Unread 02-25-2007, 11:39 AM   #1
2007_X
Please post up! Wanna know if I can run 15's on mine to save some dough on mud tires.
[CENTER][B]2002 Wrangler Sport 4.0L
6" Rough Country Lift on 35x12.50 Pro Comps, SYE, Warn Bumpers, Cold-Air intake, Jet Chipped, KC Rack up top and Snorkel kit (in box to be installed soon)! [/B][/CENTER]
[CENTER]"WHO THE HELL?...POL!"
"WHAT THE [email]F@#$?...BIG[/email] GREEN TRUCK!"
USAF FUELS!!!![/CENTER]
2007_X is offline   Reply With Quote Quick reply to this message
Unread 02-25-2007, 01:14 PM   #2
barry1me
no you can not brake package is to big for a 15inch ID rim.
Sport TJ build
everything below has a hyperlink to the install/review
Rubicon Express Long Arm
D30 Alloy axle shafts with Alloy U joints
D30 Powertrax no slip locker
Skid row skids engine- gas tank - radiator- steering box
Expidition one trail series rear bumper and carrier
Edge Trail jammer install/review
Bestop Trailmax Aqua seat
Bestop Super top
Before you ask about a product in the Technical forums check out the product review section!
barry1me is offline   Reply With Quote Quick reply to this message
Unread 02-25-2007, 01:46 PM   #3
bryans98tj
Yes you can you just need to have the properly spaced wheels. If you get them with 4" BS they will work.
[SIZE="1"][B]98 TJ-bought-not built
[url]www.PNWJeep.com[/url]
كافر - Infidel[/B][/SIZE]
bryans98tj is offline   Reply With Quote Quick reply to this message
Unread 02-25-2007, 02:22 PM   #4
2007_X
15" on the same bolt pattern with 4" BS correct?
Is anyone running this setup? If so, please post some pics so I can see what it looks like! Thanks!
Unread 02-25-2007, 02:25 PM   #5
bryans98tj
the BP is 5 on 5 and yes 4" BS. Search the JK area and you will find some pics and links.
Unread 02-25-2007, 02:28 PM   #6
2007_X
Thanks Man!
Unread 02-25-2007, 04:19 PM   #7
corey3589
I have Pro Comps 15"X8" wheels with 3.75" backspacing. 35X12.50-15 BF Mudterrains
http://i127.photobucket.com/albums/p...3589/wheel.jpg
corey3589 is offline   Reply With Quote Quick reply to this message
Unread 02-25-2007, 04:22 PM   #8
FutureJK
FutureJK's Avatar
[QUOTE=corey3589]I have Pro Comps 15"X8" wheels with 3.75" backspacing. 35X12.50-15 BF Mudterrains
any wider angle shots that show the whole jeep from the side?, I'll post them up for you.
FutureJK is offline   Reply With Quote Quick reply to this message
Unread 02-25-2007, 04:36 PM   #9
corey3589
Here's a couple more.
http://i127.photobucket.com/albums/p...9/IM000014.jpg
http://i127.photobucket.com/albums/p...9/im000013.jpg
Unread 02-27-2007, 07:19 AM   #10
2007_X
Did you use wheels spacers?
Unread 02-27-2007, 07:29 AM   #11
FutureJK
FutureJK's Avatar
clicky free.....
edit: i took out the sideways one
Unread 02-27-2007, 01:51 PM   #12
JayDLT
Corey,
Thats the exact tire/wheel setup I want to run. Two questions:
1. What lift do you have?
2. Have you done any wheelin? any rubbin?
OK three questions.
JayDLT is offline   Reply With Quote Quick reply to this message
Unread 02-27-2007, 07:00 PM   #13
thundercat900
I'm running procomp street lock wheels with 33 12.50's
the wheels are 15 by 10 with 3.75 backspace.
Any less backspacing will hit. but I have had zero problems so far...I even ran a week without a lift with no rubbing. I now have a 2 inch lift and everything looks great.
They do stick out past the flares about 3 inches and make the jeep really wide.
I would stick to 3.75 or maybe 4 inch backspacing with the 15's any more backspacing than that would stick out a ton.
thundercat900 is offline   Reply With Quote Quick reply to this message
Unread 02-27-2007, 07:09 PM   #14
otizzy
Thundercat...any chance you have a pic of two of your setup pre-lift? That is the exact same tire/wheel size combo I would like to go with. Even if you only have pics after the lift that's fine..I mainly want to see how that nice wide stance looks with 3.75 backspacing. Do you know what offset the wheels are?
Thanks
otizzy is offline   Reply With Quote Quick reply to this message
Unread 02-27-2007, 07:37 PM   #15
corey3589
I have the Teraflex 2.5 BB with skyjacker shocks. I have no spacers and it only rubbed the airdam at full turn but I trimmed the ears off of it with a hacksaw and no more rubbing. The bumpstops do a pretty good job of keeping 35's from bottoming in the wheelwell when stretching. I have had no problems with the lift or the wheels.
