Any JK's on 15" Wheels? - JeepForum.com
post #1 of 16 Old 02-25-2007, 11:39 AM Thread Starter
2007_X
Please post up! Wanna know if I can run 15's on mine to save some dough on mud tires.
2002 Wrangler Sport 4.0L
6" Rough Country Lift on 35x12.50 Pro Comps, SYE, Warn Bumpers, Cold-Air intake, Jet Chipped, KC Rack up top and Snorkel kit (in box to be installed soon)!
"WHO THE HELL?...POL!"
"WHAT THE
GREEN TRUCK!"
USAF FUELS!!!!
2007_X is offline
post #2 of 16 Old 02-25-2007, 01:14 PM
barry1me
barry1me's Avatar
no you can not brake package is to big for a 15inch ID rim.
Sport TJ build
everything below has a hyperlink to the install/review
Before you ask about a product in the Technical forums check out the product review section!
barry1me is offline
post #3 of 16 Old 02-25-2007, 01:46 PM
bryans98tj
Yes you can you just need to have the properly spaced wheels. If you get them with 4" BS they will work.
98 TJ-bought-not built
كافر - Infidel
bryans98tj is offline
post #4 of 16 Old 02-25-2007, 02:22 PM Thread Starter
2007_X
15" on the same bolt pattern with 4" BS correct?
Is anyone running this setup? If so, please post some pics so I can see what it looks like! Thanks!
"WHAT THE
GREEN TRUCK!"
USAF FUELS!!!!
2007_X is offline
post #5 of 16 Old 02-25-2007, 02:25 PM
bryans98tj
the BP is 5 on 5 and yes 4" BS. Search the JK area and you will find some pics and links.
كافر - Infidel
post #6 of 16 Old 02-25-2007, 02:28 PM Thread Starter
2007_X
Thanks Man!
"WHAT THE
GREEN TRUCK!"
USAF FUELS!!!!
2007_X is offline
post #7 of 16 Old 02-25-2007, 04:19 PM
corey3589
I have Pro Comps 15"X8" wheels with 3.75" backspacing. 35X12.50-15 BF Mudterrains
http://i127.photobucket.com/albums/p...3589/wheel.jpg
corey3589 is offline
post #8 of 16 Old 02-25-2007, 04:22 PM
FutureJK
FutureJK's Avatar
[QUOTE=corey3589]I have Pro Comps 15"X8" wheels with 3.75" backspacing. 35X12.50-15 BF Mudterrains
any wider angle shots that show the whole jeep from the side?, I'll post them up for you.
FutureJK is offline
post #9 of 16 Old 02-25-2007, 04:36 PM
corey3589
post #10 of 16 Old 02-27-2007, 07:19 AM Thread Starter
2007_X
Did you use wheels spacers?
"WHAT THE
GREEN TRUCK!"
USAF FUELS!!!!
2007_X is offline
post #11 of 16 Old 02-27-2007, 07:29 AM
FutureJK
FutureJK's Avatar
clicky free.....
edit: i took out the sideways one
FutureJK is offline
post #12 of 16 Old 02-27-2007, 01:51 PM
JayDLT
JayDLT's Avatar
Corey,
Thats the exact tire/wheel setup I want to run. Two questions:
1. What lift do you have?
2. Have you done any wheelin? any rubbin?
OK three questions.
JayDLT is offline
post #13 of 16 Old 02-27-2007, 07:00 PM
thundercat900
thundercat900's Avatar
I'm running procomp street lock wheels with 33 12.50's
the wheels are 15 by 10 with 3.75 backspace.
Any less backspacing will hit. but I have had zero problems so far...I even ran a week without a lift with no rubbing. I now have a 2 inch lift and everything looks great.
They do stick out past the flares about 3 inches and make the jeep really wide.
I would stick to 3.75 or maybe 4 inch backspacing with the 15's any more backspacing than that would stick out a ton.
thundercat900 is offline
post #14 of 16 Old 02-27-2007, 07:09 PM
otizzy
Thundercat...any chance you have a pic of two of your setup pre-lift? That is the exact same tire/wheel size combo I would like to go with. Even if you only have pics after the lift that's fine..I mainly want to see how that nice wide stance looks with 3.75 backspacing. Do you know what offset the wheels are?
Thanks
otizzy is offline
post #15 of 16 Old 02-27-2007, 07:37 PM
corey3589
I have the Teraflex 2.5 BB with skyjacker shocks. I have no spacers and it only rubbed the airdam at full turn but I trimmed the ears off of it with a hacksaw and no more rubbing. The bumpstops do a pretty good job of keeping 35's from bottoming in the wheelwell when stretching. I have had no problems with the lift or the wheels.
20" Wheels & Load Range "E" Tires soundone JK Wrangler Technical Forum 0 04-27-2008 10:54 AM
8" wheels and 12" tires BAD? 10"wheel? Rayvins TJ Wrangler Technical Forum 10 04-03-2008 08:31 AM
Burly looking 33" tires for stock 18" Sahara wheels ChuKronos JK Wrangler Technical Forum 27 02-13-2008 06:57 PM
Attention all "RED JK's" post your pic here!! coyote runner JK Wrangler Technical Forum 3 02-14-2007 07:36 PM
Need pics of new "RAVINE" wheels w/anything but stock tires thejafe TJ Wrangler Technical Forum 9 01-07-2004 08:32 AM
