Any Hella 4000's on windshield mounts? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Any Hella 4000's on windshield mounts?
IRON CROSS Jeep JK Front and Rear STUBBY BUMPERS IN STOCK Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Jeep speedometer gears at rockridge4wd
Unread 05-09-2013, 09:49 AM   #1
jopolly3
jopolly3's Avatar
Hey everybody,
I think the title just about sums it up. I have a set of Hella 4000's off my old WJ sitting in the garage that I was planning on mounting on the Rubi. As most of your know they are pretty large lamps, has anybody mounted these on their windshield brackets?
Joe
2013 JKU Rubicon 6spd: ARB Dana 44 covers F&R, Expedition One front bumper & swaybar skid, Hella driving lamps, JKS adjustable track bars F&R, MBRP SS off-road exhaust, OME HD springs and shocks, OME relocated SS, Rock Hard 4x4 gas tank skid, Rock Hard 4x4 oil pan skid, Rock Hard 4x4 rock sliders, Rock Hard 4x4 transfer case skid, Spidertrax wheel spacers, Superwinch LP8500 Gen 1
2002 Subaru WRX: Cobb intake, Mishimoto aluminum radiator, Kartboy short throw shifter and bushings
1960 CJ-6: Never ending project rig
Build Threads:
JKUR - http://www.jeepforum.com/forum/f96/j...hread-1522982/
CJ6 - http://www.jeepforum.com/forum/f8/jo...hread-1347975/
WJ - http://www.jeepforum.com/forum/f197/...auren-1033184/
"BFG makes some good rubbers, if they sold condoms I'd buy them" -Owen Horner
jopolly3 is offline   Reply With Quote Quick reply to this message
Unread 05-09-2013, 02:05 PM   #2
1222
Make mine a Jeep!
1222's Avatar
You are right they are very large and heavy (6 lbs. each) too. I think that if you can get them to fit that they would look so out of place and look like tumors protruding from the face checks of your Jeep.
1222 is offline   Reply With Quote Quick reply to this message
Unread 05-13-2013, 08:34 AM   #3
jopolly3
jopolly3's Avatar
Haha I thought they might but I have them laying around and figured I would try and put them to use. I guess nobody has them on for a reason
Joe
Build Threads:
Unread 05-13-2013, 09:28 AM   #4
1222
Make mine a Jeep!
1222's Avatar
Yeah it’s a shame though because those 4000’s are really built well; had 4 of them on my ’04 Rubi. Shouldn’t have a problem selling them if you have no use for them in the future.
Unread 05-13-2013, 09:32 AM   #5
jopolly3
jopolly3's Avatar
Yeah, if they look goofy I will end up bolting them to my CJ's bumper.
Joe
Build Threads:
Unread 07-31-2013, 11:47 PM   #6
Zdrisko
I don't mean to thread jack!
Has anyone wired 4000's to their factory switch? Hella says it needs a "required" harness (sold separately). I have factory switch and plugs (no factory lights) and an aftermarket switch and aftermarket lights from the po. They're halogen so I don't see the need for a "required" harness. Thanks!
Zdrisko is offline   Reply With Quote Quick reply to this message
Unread 08-01-2013, 02:22 AM   #7
1222
Make mine a Jeep!
1222's Avatar
To run the 4000s you need to wire them up yourself. It’s best to run them separate from the factory electrical on the JKs and get your power source directly from the battery. You will need a switch, relay and of course wiring.
Best to use 12guage for the power and small (16-18) gauge wire for triggering the relay. Also just as important as the power is the grounding of the lights. Make sure it’s solid and clean plus use at least a 14 -12 gauge wire.
So to answer your question the answer is yes. You can either buy their “required” harness or make up your own.
Unread 08-01-2013, 06:28 PM   #8
MoonyJohn
Mountain Climber
MoonyJohn's Avatar
I like the look of big lights on the bumper, like mounted on the stinger or something.. Windshield mounts are a bit out of place I'd say
MoonyJohn is offline   Reply With Quote Quick reply to this message
