Antenna and Car Wash - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Antenna and Car Wash
1993-2004 Jeep Grand Cherokee Steering Damper Trail Boss (50" LED CREE Light Bar Pair With Wiring KitSteering and more from Ruffstuff!
Unread 12-04-2010, 11:58 AM   #1
smooth9883
Quick question. Do you guys take your antenna off before you go into a car wash?
smooth9883 is offline   Reply With Quote Quick reply to this message
Unread 12-04-2010, 11:59 AM   #2
Washi
Rockbiter
Washi's Avatar
2009 JK Wrangler
yes
Washi is offline   Reply With Quote Quick reply to this message
Unread 12-04-2010, 12:08 PM   #3
krutj
2009 JK Wrangler
Could this be why there are so many posts about leaky tops????
The only time my antenna has been off was to paint it black......
(never seen a car wash)
-- [FONT="Comic Sans MS"][SIZE="4"]Joel[/SIZE][/FONT] --
krutj is offline   Reply With Quote Quick reply to this message
Unread 12-04-2010, 12:10 PM   #4
smooth9883
Leaky hard tops?
Unread 12-04-2010, 12:25 PM   #5
Vin
Both the cb and radio antenni come off before I take her through the wash.
Vin is offline   Reply With Quote Quick reply to this message
Unread 12-04-2010, 12:26 PM   #6
krutj
2009 JK Wrangler
Originally Posted by smooth9883 View Post
Leaky hard tops?
Yep....
check around, lots of threads on this, may have no bearing on the leakage, but those high pressure sprays could make it leak.
Make sure to keep the gaskets lubed, I use silicon spray, just don't let 'em dry out.
In the winter, at most I'll use a wand to knock off the crap.
Unread 12-04-2010, 01:03 PM   #7
1222
Make mine a Jeep!
1222's Avatar
Mines been through the car wash many times and so far Iíve never had a leak. Each time they remove my Jeep antenna but my CB antenna always stays put.
1222 is offline   Reply With Quote Quick reply to this message
Unread 12-04-2010, 01:14 PM   #8
krutj
2009 JK Wrangler
Did you ever get a resolution on you torn seat? Any ideas about the leaky tops that we hear about?
Unread 12-04-2010, 03:52 PM   #9
Washi
Rockbiter
Washi's Avatar
2009 JK Wrangler
Dunno. I take mine through a hot water automatic brushless car wash and have NEVER had a leak, kinda. The rear window leaked (oozed) a bit (from purchase, used), just a bit. It was a bad seal on the window and was replaced, now, no leak. I am not sure about the rest of the tops out there, but it could just be bad seals or bad seal installation.
Also, because my wash is brushless, I normally don't remove my antenna. I will if I go through a normal one though!
Unread 12-04-2010, 04:45 PM   #10
1222
Make mine a Jeep!
1222's Avatar
No. They refused to fix it and now of course the warranty is up. Sometimes (most times) the dealer really stinks. Thanks for asking though.
Unread 12-04-2010, 08:36 PM   #11
jstrubberg
2009 JK Wrangler
Answering the OP's question...
Nope.
jstrubberg is offline   Reply With Quote Quick reply to this message
Unread 12-07-2010, 10:01 AM   #12
justjeepinorfw
You mean people actually listen to radio!?! All I listen to is satellite radio, internet radio (via iphone). I've not listened to AM/FM or CDs in years.
I do take mine off when going through the car wash.
-O|||||||O- Have fun out there. Jeep
justjeepinorfw is offline   Reply With Quote Quick reply to this message
Unread 12-07-2010, 10:20 AM   #13
paul84043
I took mine through a regular wash once and tweaked the antenna a tiny bit...won't do that again, and it's not worth the money, I do a better job at the manual wash anyway.
paul84043 is offline   Reply With Quote Quick reply to this message
Unread 02-27-2015, 10:18 AM   #14
baddnuz
You MUST take your radio antenna off
I had taken my '12 JK soft top through the automatic car wash several times without any issues; until yesterday. Since our radio antenna is mounted on the side and not the top the brush was able to grab the antenna mast. It broke the antenna base in half. The dealership got me a new base, base cover & mast for $50. And BTW the top has never leaked in the automatic car wash but I usually hand wash it anyway. Call me strange but I like to touch my Jeep
baddnuz is offline   Reply With Quote Quick reply to this message
Unread 02-27-2015, 10:21 AM   #15
frankthomson
car....wash....????
Q'EST QUE C'EST???
frankrocksjesus.com Want a free cd? PM me!....oh, and im a carpenter, not an auto mechanic, so....
frankthomson is offline   Reply With Quote Quick reply to this message
