Another light bar wiring question - JeepForum.com
post #1 of 2 Old 06-20-2011, 01:25 AM Thread Starter
Chinadoc
2010 JK Wrangler
I got a rugged ridge light bar that mounts to the front bumber. It came with three lights but only installing two. I'm not yet brave enough to install the third. Pretty much figured out the mounting and most of the wiring. I'm stuck on the harness that has the switch on it. There is a red wire, black wire and white wire. The diagram states to connect white wire to head lamps. So it brings me to ask:
1. Where are my headlamp wires?
2. I want to be able to use them independently,will it do this?
Now please remember, up to this point I have attributed anything that went wrong with my Jeep JK to solar flares. That's about how much I know about electrical. So please explain it at a Pre-K level:P
This is what I have:
http://www.quadratec.com/products/97...googlemerchant
Any help would be greatly appreciated. This is my last Jeep mod until I finish my motorcycle and 4-wheeler. Thanks.
Chinadoc is offline
post #2 of 2 Old 06-20-2011, 07:33 AM
Vin
You can either the white wire to the Aux power port on the right, It's constant (on even if the engine is off), or the power port/lighter or the left (ignition only) depending on whether or not you want the lights on with or without the engine running. If you use the headlamp power wire, the switch will only be hot when the lights are on.
Vin is offline
light bar , rugged ridge , wiring
02 fog light wiring question ImNotStuck TJ Wrangler Technical Forum 28 05-16-2012 08:35 PM
Fog Light Wiring question BobKnake TJ Wrangler Technical Forum 8 07-19-2010 03:46 PM
Light Bar Wiring Question. Help! jmbrewe2 TJ Wrangler Technical Forum 12 08-04-2007 11:27 AM
Fog light wiring question for my LJ yj_ryn TJ Wrangler Technical Forum 3 06-17-2006 02:58 PM
KC light wiring question Jeep14636 TJ Wrangler Technical Forum 6 08-26-2004 08:56 PM
