Annoying service lights. Procal didn't fix it. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Annoying service lights. Procal didn't fix it.
Income tax season is upon us. We got what u needGet 5% Back On Rugged Ridge-Omix-ADA-Alloy at ExtremeTerraGibson Exhaust Rebate - ExtremeTerrain!
Unread 04-21-2013, 08:53 AM   #1
GeorgiaJK07
So randomly my esp/bas, traction control, and abs lights came on the other day. I've tried removing the battery cable for 20 min, reset everything with my AEV procal module ( all worked except when I tried to reset DTC codes, the horn never blew to let me know it has been corrected ) I'm a little stumped at the moment. Just curious if anyone else has had this problem. Bad sensor in the tires? My traction control will randomly engage when I pull out of my driveway. Not wet or slick.
GeorgiaJK07 is offline   Reply With Quote Quick reply to this message
Unread 04-21-2013, 08:56 AM   #2
SoK66
2009 JK Wrangler
Do you have a lift? Is your steering wheel centered?
Jeeps: Where my 401(k) went to die!
SoK66 is offline   Reply With Quote Quick reply to this message
Unread 04-22-2013, 08:55 AM   #3
GeorgiaJK07
Yea 3.5 inch RC. I'm pretty sure the dealer did all of that before I got it. He gave me the procal module with the jeep. So I'm assuming they did all that. But I reset everything with the procal and then set the axle ( which is stock ), tire size and I tired to clear dtc codes but for some reason the horn never blows and it never corrects it.
Unread 04-22-2013, 10:06 AM   #4
SoK66
2009 JK Wrangler
If the horn doesn't blow the system isn't being programmed by the Procal. Be sure you're following the instructions to the letter. If it still isn't working either the Procal is defective, or it isn't the right one for that vehicle. Once they're used on a specific VIN they have to be reset to work with any other. I think they have to go back to AEV for ther eset, at least they used to.
Unread 04-22-2013, 10:52 AM   #5
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Also, the Procal will only let you set one parameter at a time. Each time you must remove it from the port, turn the ignition off, wait a few minutes and start over for the next parameter...they do not tell you this in the instructions, but that is the way it works.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline   Reply With Quote Quick reply to this message
Unread 04-22-2013, 11:08 AM   #6
222Doc
Be sure you are setting Dip switches correctly. I have made that error, bad eyes, big fingers.
http://www.parker4wheelers.net
www.bullhead4wheelersinc.com
222Doc is offline   Reply With Quote Quick reply to this message
Unread 04-23-2013, 10:16 AM   #7
Jeepjet
I would think resetting the lights/Procal would just remove the light not the reason for it coming on? Don't know about 2007 but on my 12 (auto)those lights came on and it was a sensor that oddly enough is mounted in the center console under the cup holders. The connection is VERY susceptible to spilled drinks. You could clean up the connector and try that, it worked on mine. Good luck.
2012 JK Sport, Deep Cherry Red , 3.6 Penastar, 5 spd. auto, 3:21's, 285/70x17 DuraTrac's , Teraflex leveling kit, U.S. Alloy 1.5 spacers, ACE rock sliders, Rugged Ridge front dif skid, quadratec mats, K&N element,+80 headlamps...
Jeepjet is offline   Reply With Quote Quick reply to this message
Unread 04-23-2013, 10:17 PM   #8
GeorgiaJK07
I understand how the procal works. The horn blows for everything else but the DTC correction as stated in the original post. I'm 100% positive I'm doing everything correctly as far as Procal goes. Other then that I don't know what else I can do to correct this issue. I don't have time, money or patience for the stealership.
Ill check under the cup holder and see what happens. Thanks!
Unread 04-23-2013, 10:19 PM   #9
GeorgiaJK07
Was your TC acting up at all when these lights were on?
Unread 04-24-2013, 12:19 AM   #10
joe002
So is your steering wheel perfectly centered? You can use your ProCal to check if it's centered properly.
2008 Rubicon - 2 Door - Flame Red - Automatic - MyGIG - Power Group - Deep Tint.
AEV Pintlers, BFG KM2s 35x12.50x17, Bulldog Fab Stubby Bump, Currie F/R Adj Trac Bars, Daystar Upper Dash, FireStik FireFly antenna, Kilby Rear Shock Skids, LoD Sig Stubby Bump, Midland 75-822 CB, Mopar Filler Door & Locking Gas Cap, Rancho LCA Skids, Rancho Oil Pan Armor, Riddler Diff Covers, custom Rubi Sliders, Sylvania X-treme Headlights, TeraFlex 2.5" Spring Lift, Warn PowerPlant HD, Woods Evap Can Relo, Woods SS Relo, Yukon 5.38s
joe002 is offline   Reply With Quote Quick reply to this message
Unread 04-24-2013, 11:14 AM   #11
Walle
Soccer Mom and Jeep Hater
Walle's Avatar
I had the same issue. It is more than likely a wheel speed sensor. I had to replace two of mine. The dealership had to reset the ABS light. I could be wrong, but from what I understand...the Procal won't clear ABS codes.
| Walle's Build | 2014 JKOTY | Instagram |
Walle is offline   Reply With Quote Quick reply to this message
Unread 04-24-2013, 04:45 PM   #12
SlyDawg64
SlyDawg64's Avatar
2014 JK Wrangler
I had the same problem after a week of running trails. I checked
the wiring at each wheel, feeling for loose connections/shorted wires.
Could not find anything wrong and started up the Jeep to check lights again and they were off.
If/when I get the lights again, I will check for lights after checking each wheel to narrow it down more.
New:
2014 JKU Rubicon, Copperhead Pearl, 3" TerraFlex lift, Toyo MT 35x12.5x18 tires, Warn Powerplant,
Old:
2010 JK Rubicon, 2 dr., 3" Terraflex lift and adjustable rear track bar, Toyo 35x12.5 tires, custom bumpers, Warn Powerplant, KC lights, B&M trans cooler, etc.
SlyDawg64 is offline   Reply With Quote Quick reply to this message
