Android phones with "Call Completed" issue (info) - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Android phones with "Call Completed" issue (info)
New! JK/U skid plate system.FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 04-12-2015, 09:51 AM   #1
xsdbs
***Moderators, can you make this post a sticky?
I thought that I had posted this information here but guess that I didn't. Chrysler released a TSB (#08-112-14) for this issue and it can eithe rbe done at the dealer or by you. Here's the information:
All of the Uconnect SW updating is done the same as it has been for the last 5 years.
*******NOTE***** this TSB will only work on the following radios -----RES, REQ, RBZ & RHB. it will not work on the 730N radio.
Here are the instructions:
(and the file is below)
1) Download the file from the Mediafire link that I sent you.
2) Save the file to a thumb drive that has been formatted to FAT32.
3) Rename the file by deleting (Android1) so that the file reads uconnect.upn.
4) Place the thumb drive into the USB connector (I’m not sure which radio that you have but if it’s a touchscreen radio, don’t use the USB connector on the radio faceplate. You must use the remote USB connector that is attached to the Uconnect module)
5) Press & release the Uconnect phone button and say “set up, software update”.
6) Uconnect will respond with “starting SW update and you will now start hearing beeps, the beeps will go for about 20- 25 minutes (however, I have been told that some thumb drives have taken a little longer due to their transfer speed). Once you hear that the beeps have ended, the update is finished. Uconnect will go thru a reboot now.
7) If while you’re doing the update, you hear an error message stating “the digital signature is……….”, please try a different thumb drive.
http://www.mediafire.com/download/8z...1)uconnect.upn
xsdbs is offline   Reply With Quote Quick reply to this message
Unread 04-12-2015, 11:58 AM   #2
1222
Make mine a Jeep!
1222's Avatar
Originally Posted by xsdbs View Post
***Moderators, can you make this post a sticky?...
Sorry, no sticky. There are plenty now as it is and if we stickyed every request then everyone would have to go to page 2 just to get past sticky’s. Also it’s a fact that sticky’s just go unnoticed for the most part anyways.
1222 is offline   Reply With Quote Quick reply to this message
Unread 04-12-2015, 01:25 PM   #3
73azbronco
Good point on sticky, how many jeeps have ripp superchargers?
73azbronco is offline   Reply With Quote Quick reply to this message
Unread 04-12-2015, 05:21 PM   #4
goodwrenchdave
X2- I always figured they (RIPP) either paid for free advertising as a sticky or somebody high up got a kickback.
goodwrenchdave is offline   Reply With Quote Quick reply to this message
Unread 04-12-2015, 05:28 PM   #5
xsdbs
Well, I guess it's too bad that helpful information can't be easily found. I just figured that good solid technical help should be up front for people to locate.
I'm curious about what "RIPP superchargers" have to do with the audio section anyway? Seems that would be in a different section than this would be.
