Almost ready for 37s....brakes? - Page 2 - JeepForum.com
post #16 of 27 Old 11-29-2013, 10:42 AM
RobsYJeep
hawk pads for the commander and a vented rotor! it made a huge difference for me.
My JEEP is just a project until it becomes an obsession...
RobsYJeep is offline
post #17 of 27 Old 12-03-2013, 10:00 PM
jonboy74
Originally Posted by HappyTrails View Post
I want to go to the TeraFlex Big Brake kit soon. I've heard good things about it's performance. Only problem is the proprietary brake pads...unless someone knows of another brand to replace the pads with.
I'm not using the Tera brake pads. I'm running these on the Tera kit.
http://www.summitracing.com/parts/HWK-HB559Y-695
jonboy74 is offline
post #18 of 27 Old 12-04-2013, 12:10 AM
Imped
Imped's Avatar
This isn't the tuner scene.....
If you want the best brake kit around from the best brake guy around then you want this: http://shop.blackmagicbrakes.com/JK-...BK-JK-VLBK.htm
That'll take a dump on everything else that's been mentioned thus far.
OlllllllO
IndyORV
Imped is offline
post #19 of 27 Old 12-04-2013, 03:04 AM Thread Starter
riverboyTJSport
2009 JK Wrangler
Well the only way to know what I needed was to try it. So I slapped the 37s on and upped the superchips to 93 octane. For my style of driving I actually have plenty of stopping power with the stock brakes. So for now (until I NEED brakes) I think I'm ok.
But thanks for all the suggestions, I can always come back to this when it's time for brakes in the future
riverboyTJSport is offline
post #20 of 27 Old 12-04-2013, 09:35 AM
COLOUXJ
2010 JK Wrangler
I vote for this. Very Very active member here on this forum and makes the best brake kit I have seen for the TJ's. And I can only imagine what it does for a JK. This is probably going to be my next upgrade.
COLOUXJ is offline
post #21 of 27 Old 12-06-2013, 11:45 PM
HOKIES2010
2011 JK Wrangler
Stock brakes haven't shown any signs of not being enough so far. 37s and vehicle weight of 5400lbs here.
My Build
Couldn't have done it without
HOKIES2010 is offline
post #22 of 27 Old 12-06-2013, 11:50 PM
Maertz
2009 JK Wrangler
even offroad in 4lo with the rubi case on a steep climb or drop? Thats when mines noticable theres times i have the pedal mashed and its just barely stopping...
Wishing I Wasn't Part Of The 'JK' Crowd...
Maertz is offline
post #23 of 27 Old 12-07-2013, 12:17 AM
jonboy74
When I put my 37's on my 2012 JKUR it was scary w/ the stock brakes. Going down a hill I literally rolled right through a stop sign because my brakes wouldn't stop. After putting on the Tera big brake up front, slotted rotors in the rear and Hawk pads all the way around, I can finally stop like I should. No way was I going to stick w/ the stock brakes after that incident.
Fortunately the week after I put in the new brakes, I put them to the test. Traffic came to a dead stop and right in front of me was a brand new porsche w/ paper plates. I stopped with about 2 feet to spare. No chance of that happening w/ the stock brakes! (although the brakes didnt' save my shorts...)
jonboy74 is offline
post #24 of 27 Old 12-07-2013, 05:20 AM
bbbradley
Are the stock brakes not able to get into ABS and susceptible to overheating that easiky? Would a fluid and pad upgrade be a cheaper solution?
bbbradley is offline
post #25 of 27 Old 12-07-2013, 06:39 AM
HappyTrails
My ABS works with the stock brakes and 37's (2-dr, but heavily loaded with armor underneath). Never had a problem with my stock brakes holding me on a steep incline in 4LO. Usually, in 4LO going down steep hills, I don't even need the brakes. The engine compression is enough.
However, an emergency stop might buy me a new Porsche. I'd think the Tera Big Brake kit would be a worthy investment vs the alternative.
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel, Rancho 9000XL shocks, 37" Nittos, 5.38's, RR skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
Political Correctness offends me.
HappyTrails is offline
post #26 of 27 Old 12-07-2013, 09:34 AM
RedRubiconLJ
RedRubiconLJ's Avatar
2015 JK Wrangler
I used centric premium rotors with ebc yellows on the front which was part of the Vanco kit. I had zero issues locking up 37's on my LJ.
I had also bought the Vanco brake kit but never installed it because of the performance I was already getting. I sold it to another Jeeper.
I have already ordered the same parts for my Jk just to have better braking. I will also be adding the same pads to the rear.
I understand the black magic is the next best thing from them. I wouldn't buy a brake kit from anyone else if it's needed.
I tried ebc slotted and drilled rotors and they sucked even with yellow pads.
2015 Red JKU Rubicon RK X-factor, Adams, Rockhard4x4, PSC, LoD, BFG, WARN
SOLD 2013 JKUR
Sold 2005 Rubi Unlimited
2004 TJ sold
1993 YJ sold
RedRubiconLJ is offline
post #27 of 27 Old 12-08-2013, 07:11 AM
HOKIES2010
2011 JK Wrangler
No issues on steep declines in 4LO. Driving in FL I have also had to lock by bakes up more than once with no issues so far, hope that stays the case. Actually ended up getting rearended in one case. Have 36k miles on it and still the stock pads, the 37s have been on since 19k miles. I am really suprised by that since I know the rears have a tendancy to wear down rather quickly. I drive a manual and engine brake a good bit so it may have something to do with it.
My Build
