Almost bought my lift..... UGH help - Page 2 - JeepForum.com
post #16 of 35 Old 01-14-2014, 11:16 PM
Bear9494
2011 JK Wrangler
You have two paths. The one you are on is to move the axle farter away and provide clearance. The bump stop extensions effectively relocate your travel range to keep the axle from moving far enough up to hit anything. The second path is to move the items that could be hit when the axle moves up and your taller ( larger ) tires eat up the space. Adding flat fenders will increase your clearance without the lift. Depending on your wheels you could clear everyithing without the lift just by going to flat fenders. Then use the lift to create the suspension needs (stiffer for the added weight) but evaluate the need for bump stop extensions. Just a thought.
Bear9494 is offline
post #17 of 35 Old 01-15-2014, 03:59 AM
HOKIES2010
2011 JK Wrangler
I think you would be hard pressed to find someone who says MC or RK have bad quality or unreliable. And sorry I can't see paying AEV prices to begin with on a lift that maintains the stock CAs.
My Build
Couldn't have done it without
HOKIES2010 is offline
post #18 of 35 Old 01-15-2014, 09:09 AM Thread Starter
grangerdw
My shop just contacted me and is suggesting the following teraflex kit:
http://www.quadratec.com/products/16194_001X_PG.htm
In your opinions, where does this fit into the mix of lifts I mentioned and my overall goals?
My rig:
2014 JKU sport with 3:73 gearing
Ace sliders
Rubicon rail take offs
Goals:
95% on road though not a daily driver.
Will also be driven by my non-wheeling wife who only cares about on road performance
Will hit Rausch Creek a couple of times a year, running mostly greens and blues
Want to avoid replacing the front driveshaft until I decide to wheel harder/more often
Don't want to rub.
Wheels/Tires
315/70R17 Duratrac
17" Rugged Ridge Wheels
Other addons:
Teraflex spare carrier
Front bumper, probably Metalcloak 1401 or barricade front
Rear bumper, probably Metalcloak full or Ace pro series
4 People and camping gear
Lift kits I am looking at (grouped by my perceived price):
Lowest Cost:
2.5" AEV with brackets
Middle of the road:
RK 3.5 Flex with fox shocks and steering kit
MC Dual rate with ARB
3.5" AEV
High End:
RK X Factor with fox shocks and steering kit
MC Duraflex with undetermined shocks
MC Game Changer ARB edition
grangerdw is offline
post #19 of 35 Old 01-15-2014, 09:22 AM
TheBoss
2.5" MC with OME shocks ,at 2.5" you will at the limits of driveline longevity.
TheBoss is offline
post #20 of 35 Old 01-15-2014, 09:36 AM
HOKIES2010
2011 JK Wrangler
No adjustible trackbars or control arms. Alot of lifts have brackets to move the rear like the Teraflex but alot of them also come with a front adj one. And even the the AEV has a system for addressing the stock control arms even if they sont replace them with adj ones.
I would be worried about raising an already top heavy vehicle and not being able to get things aligned right. I am sure some others will chime in.
My Build
post #21 of 35 Old 01-15-2014, 09:41 AM
TheBoss
I agree with that and would also add if you are so concerned about sag from weight then stick with a dual rate front and rear spring. Also look ar Synergy suspension 3" springs which would be a better option than the TF imo.
TheBoss is offline
post #22 of 35 Old 01-15-2014, 10:04 AM Thread Starter
grangerdw
Perfect, that was what I was looking for. Leaning towards the MC dual rate ARB or the RK 2.5 Flex or Max travel.
post #23 of 35 Old 01-15-2014, 01:42 PM
XTJake
ExtremeTerrain.com
XTJake's Avatar
If you decide on the Rock Krawler 2.5 Inch Max Travel shoot me a PM. I'll get a good price on that lift with free shipping. You can also let me know if you have any questions at all.
-Ryan
Jake R. |
Off-Road Outfitters
Toll Free: 800-988-4605 | Mon-Fri 10AM-6PM EST
Free Shipping on Orders Over $75!
PM me for our JeepForum Discount Code (must have 25 posts) or Price-Matching!
XTJake is offline
post #24 of 35 Old 01-15-2014, 04:25 PM Thread Starter
grangerdw
Decision made and kit and components are ordered.
Going with the RK 2.5 Flex system
Fox 2.0 shocks
Fox steering stabilizer
Duratrac 315/70R17
Rugged Ridge Wheels
Should be up and running in about 2 weeks.
Thank you all for your help, I really appreciate the feedback and suggestion!
post #25 of 35 Old 01-15-2014, 06:50 PM Thread Starter
grangerdw
Originally Posted by Kyle08JK View Post
I'll let the guys more knowledge help lead you down the path but figured I would throw this in there for you. Northridge4x4 is having a 20% off sale on RockKrawler lifts if you use the code "rockuary". Could save you a couple hundred dollars based on the lifts you are choosing from.
Big help btw, saved me a good bit on the lift!!! Thank you
post #26 of 35 Old 01-15-2014, 08:14 PM
Kyle08JK
Good deal bud! I'm glad I could help out
Kyle08JK is offline
post #27 of 35 Old 01-15-2014, 08:23 PM
eMc9002
2007 WK
I've been doing my head in for the past month on this exact same question and same aspects you wanted. I'm very glad you made this thread lol, My initial setup wanted to be a 2.5 AEV, 315/70r17 Duratracs, Aev Savegre wheels. Wanted to add on the bumpers and winch along with it but hearing on the loss of lift and potential rub I made go with the RK 2.5 aswell. Saves me a good amount too compared to the 3.5 AEV.
eMc9002 is offline
post #28 of 35 Old 01-15-2014, 08:35 PM Thread Starter
grangerdw
Glad this helped. Honestly I was torn between the flex and the max travel. After a talk with RK, I decided to go with the flex as the rear arms would have to be swapped out if I tried to upgrade the max travel to the x-factor lift, which
is my end goal.
I will post back once I have this up and running!
post #29 of 35 Old 01-16-2014, 09:36 AM
sandfan85
I've been flopping back and forth on what kit to go with. Thanks to this post Ive pulled the trigger.
Big thanks to Kyle08JK for coupon hook up. Dude you just saved me $390. I owe you a
sandfan85 is offline
post #30 of 35 Old 01-16-2014, 04:55 PM
Kyle08JK
No problem man. Glad I could help.
Kyle08JK is offline
